Question about Sony Cyber-Shot DSC-P52 Digital Camera
My camera is showing the error code E:61:00
WHEN THE CAMERA IS TURNED ON, I HEAR A NOISE INSIDE LIKE A MOTOR AND THE MESSAGE IS SHOWED ON THE DISPLAY
    Problem Solver:
  • 7 Answers
On Sony equipments this error code seems to be dedicated to focus and lens errors. You may have either some dirt or anything like this inside the lens or focus mechanism, or a broken mechanism (any drop of your camera lastly ?).
If you can open it properly, you should check for "foreign body" inside the mechanism (focus and zoom mechanism, but but code 00 means focus normaly).
Posted on May 13, 2009
When I turn the power on, the screen shows "turn
This type of problem can be caused by either a lens issue, or power problem. The following web blogs delineates things you can try to get the camera working again. They say about 50% of the time they can be fixed trying their suggestions:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If none of those things helps, try these steps:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
If the camera still doesn't work, you can take it in to a local repair shop, but get an estimate first. Repair can be high, and justify just going ahead and buying a new one.
Good luck, and hope this helps.
May 27, 2011 | Sony Cyber-shot DSC-N1 Digital Camera
My sony Camera (DSC -W110) is showing "Turn the power off and on again" while switch on the camera,it appers again & again after switching the camera on and off
I'm sorry that the Camera is displaying the error message. "TURN THE POWER OFF AND ON AGAIN" displays on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset. Please follow the below steps to perform a power reset.
· Turn off the camera.
· Remove the battery pack.
· Press and hold the power button for 30 seconds.
· Allow the camera to remain without power for 60 seconds.
· Reinsert the battery pack.
· Turn on the camera.
Also tryinitializing the Cameraif you're able to access the Menu items on the Camera. The Initialize option will be available under Setup or Main settingsSub Menus.
If the issue persists again, service is required. Please click hear to locate the service center near your area.
Thanks for understanding. Please let me know if your require any clarifications.
Mar 21, 2011 | Sony Cyber-shot DSC-W110 Digital Camera
There is an error showing "Error Code 6a80" tells
Hello
I would rather just navigate you to this link with the illustrations.
Click HERE.
Please feel free to let me know if you need any further assistance.
Kind regards
Lock123
Mar 16, 2011 | Nikon Cameras
Keeps showing on screen, "camera error # "
If this camera just show blue screen it means that the LCD or he mainboard of the camera is defective., is this error code display also a number., usually it will also display the error code number.
If you have this error code please call tech support toll free 1 800 235 6325 and send the camera for repair
Nov 13, 2009 | Kodak EasyShare P850 Digital Camera
When turn on, lens won't extend-error message Canon SD 600 digita
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Oct 10, 2009 | Canon PowerShot SD600 Digital Camera
Nikon d100 locked
Have you tried to reset the camera? I seen this a few times .. and the camera reset did the trick. I've never heard of the motor noise though.
Oct 20, 2008 | Nikon D100 Digital Camera
Camera shows an error E30 message
Hi Chittu, This error usually happens when there's problem reading and writing from the Flash memory card (CF). Did you try to pull the memory card before the camera finished writing data? Here's what you should do - try using another memory card. If it works, it means that the original one is damaged. Let me know if this helped. Please rank this post.
Mar 05, 2007 | Canon PowerShot A75 Digital Camera
System Error message
So you have any other memory cards? You may want to try that first. What batteries are you using? Can you try a new set of NiMH batteries? not alkalines but NiMH try these things first because they are easy. If you have tried different memory, and different batteries then it could be a connection problem inside the unit. These cameras dont have may circuit boards so they use ribbon cable to connect the different componets together. These can sometimes work loose. An impact can vibrate them just enough to cause the problem. It could also be the lens mechanism. Sand and grit can work into the gears and bind them up. If it zooms in and out smoothly then this maynot be the problem. If you hear any change in the speed of the motor when its zoomed in and out that could be it.
May 06, 2006 | Panasonic Lumix DMC-LC33 Digital Camera
The camera screen displays error message
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card. CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Sony Cyber-Shot DSC-P52 Digital Camera Logo
347 people viewed this question
Top Sony Cameras Experts
Larry Spears
Larry Spears
Are you a Sony Camera Expert? Answer questions, earn points and help others
