Question about HP PSC 1610 All-In-One InkJet Printer
My HP 1610 thinks there's a paper jam - when there isnt one.
Paper feed seems to malfunction. sometimes feeds paper all the way through.. some time part way. Believes there's a paper jam even when the offending page is removed.
Any suggestions?
  • 4 more comments
  • alexharperny Jan 26, 2009
    A paper jam or carriage jam error-message is persistantly occurring. The paper jam error is a mystery since there is no paper anywhere in the machine-and yes, I've gone throught all of the troubleshooting steps concerning paper jams.
    I don't know what would cause a carriage jam (other than poor engineering).
  • keith L Jan 27, 2009
    I have the same problem. My printer was working perfectly until the other day now it feeds the paper half way without printing anything then says it has a paper jam. Like you I have checked and there is not paper jammed in the printer. I have tried un installing the printer then re installing. tried to reset the printer no luck.
  • Anonymous Feb 06, 2009
    I have the very same problem and it started within the past few days. I'll try the card stock trick and hope it helps, but with three people having the same issue around the same few days, it almost seems like planned obsolescence.
    With hope, I'll try again ...
  • Anonymous Feb 07, 2009
    I'm having the same problem.
  • lisah1186 Mar 06, 2009
    Wow, I had the same type of problem early in February. I bought a new printer, but am now trying to fix this one as a second. Every time I try to print the paper goes half way through and stops. Then the screen reads "paper jam". I cannot find any reason for the paper to be stopping.
  • Anonymous May 22, 2009
    it won't let me do anything, not even scan because it thinks there is a paper jam!
    President:
  • 8,637 Answers
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 27, 2009
My daughter was having the same problem. There was a tiny piece of paper on the gear inside the printer. After we removed it the printer started working again!
Posted on Mar 08, 2009
My HP PSC 1610 paper feed is malfunctioning. When something is sent to printer the message states Out of Paper but there is paper. The rollers don't engage the paper.
Shut down your computer. Pull the plug from the printer to the computer.Wait two minutes. Start the computer and re insert the printer cables. It should recycle and work. f not re-post question.
Jan 07, 2013 | Office Equipment & Supplies
My HP photosmart PSC2410 XI printer is showing "clear carriage jam"what should I do?
Points to there being paper stuck in the feed rollers, if you have cleared the jam, there may be a shred of paper still stuck, try to examine and remove.
If it IS fully clear and the indicatiors still show a paper jam, check the feed rollers are making contact with the paper, that the paper detector has not been bent upwards ( fooling the printer into thinking that there is still a jam).
Try rebooting the printer, if the problem still shows, this is a job for a qualfied technician
Mar 31, 2011 | HEWLETT-PACKARD PSC 1610 xi All-In-One...
A sheet of paper had remain in the cylinder
  1. Remove the rear cleanout from the printer.
  2. Gently remove any jammed paper or bits of paper.
  3. Close the HP Paper Feed Cleaning Kit software on the computer.
  4. Load plain paper in the printer paper tray.
  5. Press the Power button to turn the printer off.
  6. Press the Power button to turn the printer on.
  7. Try printing again. If the printer still does not pick up paper or if a paper jam occurs again, service the printer.
Other solutions customers found helpful » HP Paper Feed Cleaning Kit -- Clean the Paper Feed Rollers with the HP Paper Feed Cleaning Kit in Windows XP and 2000 » HP Deskjet, Photosmart, and PSC All-in-Ones -- 'Out of Paper' Error Message and the Printer Does Not Pick Up or Feed Paper » HP PSC 1600 and 2350 All-in-One Series Printers -- 'Paper jam: Press OK to continue' Message Displays on the All-in-One
Dec 15, 2010 | HP PSC 1610 All-In-One InkJet Printer
HP 1610 printer photo paper jams
Right click on default printer icon select printing prefrences,click on advanced tab,select the size.or
Click on start menu then click on control panel.
Click on classic view on the left pane.
Double click on printers and faxes from the top toolbar.
Click on add a local printer.
Select the USB 001 virtual printer port from the “Use existing port” and click on next.
Select the manufacturer as HP and printer as Deskjet 990c and click on next.
We are using the generic driver for HP printers.
Use the default name for the printer, or you can change to your printer name and click on next.
Select yes to print a test page and click on next.
Select yes to set as default and click on next.
Select no to “do not share” and click on finish.
Jul 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
Paper Jam, when there are none.HP PSC 1610 ALL IN ONE.
You may have a piece of paper stuck in the paper feed.
It may have ripped off inside and caused the jam
Jul 10, 2010 | HP PSC 1610 All-In-One InkJet Printer
The paper has jammed in my ML-1610 printer.
The paper jams mostly, because the rubber band that feeds the paper to the printer is broken/split. Check the rubber band. It's located within the plastic wheel that feeds the paper.
Mar 09, 2009 | Samsung ML 1610 Laser Printer
Paper jams
Had this problem, too with HP PSC 1610 AIO, paper would pull in part way and stop, then display would indicate: Paper Jam, Clear Jam and Press OK, but there was no paper in the path at all. Found in HP forums that possibly the problem was a broken off piece that may be called the "x-bias" lever which is on a little spring inside the printer just to the left of the carriage bay on the right side of the device. There are two photos of "broken" and "not broken" at this forum site:
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?threadId=1085918
Since HP does not sell the little part to repair it, I phoned HP and got a good "trade-in, trade-up" price for a better device. Hope this helps someone else find the answer to the constant paper jam issue, as I always appreciate the FixYa forum help from everyone else here, too.
Apr 08, 2008 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 All-in-One paper jam
ur printer paper feeder gears r jammed or misaligned. kindly get ur printer serviced from a good technician.dont worry its a normal problem.wish u success
Mar 11, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
HP PSC 1610 All-In-One InkJet Printer Logo
541 people viewed this question
Seeker5211
Seeker5211
