I got the code from dealer it didnt work i called and got another code it doesnt work someone said to take stereo out and get a code off it i dont no which numbers to use can you help
Okay, the first thing is , there is no code on the radio. the numbers on the radio if you pull it out are the model # and the serial #. most of the time the dealer needs the serial # to get you the code. know if you enter the wrong code three times it will lock you out and instead of it displaying CODE It will display LOC.
is your radio displaying CODE or is it displaying LOC.
let me know and i will help you. good day
SOURCE: cant get the radio to
hi.
the dealers usually trace these codes through the registration number of the car. they also assume that the radio is the original and has not been changed in the last 11 years. you may have to take the radio itself to the dealer so they can check the serial numbers and make sure they have given you the correct code.
they should not charge you for this, if they did not give you the correct code in the first place.
