Question about Gateway M350 Notebook
Hard Disk using Hard-Drive enclosure is recognied as CD-ROM Drive
I bought a new AcomData Hard drive enclosure and am trying to use it to read data from one of my Old computer's Maxtor 200GB internal drive. According to the AcomData instructions, I changed the Maxtor drive configuration to MASTER. But whey I try to plug it with my laptop (with XP and SP2) using the enclosure's USB cord, it is recognized as a CD ROM drive. I have tried following steps to resolve this issue but with no Luck:
1. I have tried chaning the drive letter for this external drive enclosure, thinking that the default drive letter might be conflicting with something. But the problem still remains.
2. I have tried it plugging to a Vista machine and another XP machine with SP3 installed.
Any help will be greatly appreciated.
Not seeing new hard disk or reading XP cd-rom
It can use any 31/2" IDE hard drive. 30 Gb should be OK
If the BIOS cannot detect the hard drive or the CD drive then the drives maybe faulty or the disk controller in the computer is faulty.
Apr 29, 2012 | IBM ThinkPad A30 Notebook
My external hard drive fell off my desk and since it has been beeping and not operating correctly
You broke it. Does the Acomdata warranty cover self-inflicted damage?
Did you buy it with a credit-card that adds "all-perils" insurance?
All you can do is to disassemble the enclosure, remove the disk-drive,
buy a similar, compatible, disk-drive, install it into the enclosure,
and thus "revive" your external storage device.
Nov 02, 2010 | Acomdata 1TB Puredrive USB Esata 1 TB Hard...
Trying to install XP when disk selection comes up it reads, "Unkown disk. There is not disk in this drive". NOt sure what that means.
your drive is not being read,
have you set BIOS to boot from CD ROM,
is your CD ROM working,
is your XP CD working
Do the following
1 go to BIOS and re-set to BOOT from CD ROM
2 use another copy of XP/Win98/Vista etc to verify if CR ROM is reading the CDs else...
if you doubt CD ROM drive has a problem....
3 use a USB external CD ROM, and to do that u need to re-set the BIOS to boot from USB CD ROM
Dec 07, 2009 | IO Magic Corporation GigaBank (I250HD35)...
My acomdata 500gb harddrive will not connect to any PC. I can hear the indication that somthing has connected, and then about one minute later the tone for something disconecting can be heard. Any ideas in...
Power supply failure. Check the voltage on the 12V and 5V rails of the power supply (a DM-5127?) Make sure that the AC voltage is ZERO. If there is AC ripple current, the enclosure will seem like it should work, but will fail. Best to transfer the drive to a new enclosure if the unit is still under warranty.
Nov 18, 2009 | Acomdata HybridDrive E5 Hard Drive
My Acomdata E5 500GB External Hard Drive cannot be read!
Hi Spookie,
Sounds like you've already tried most of the usual steps without success. Based on what you've said the unexpected kicking out of the power has most likely fried one of the circuits. First things first, take the drive to your local PC shop and either have the techs there move the Hard drive inside it to a new enclosure or if you know how buy an enclosure and move it yourself then test the drive in the new enclosure.
If it works you're rocking again, if it doesn't you will need some professional help to recover the lost music. If you need a pro, reply with your location(Country, State, City) and I will advise you as to a facility near you that can handle this type of repair for a reasonable price.
Hope this helps FixYa,
Chris
Sep 24, 2009 | Acomdata HD500UHE5-72 Hard Drive
Flashing red/blue acomdata 1 terrabyte external hard drive. computer won't recognize
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Jul 06, 2009 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Old cd/dvd rom for new netbook
u may find a dvd drive usb enclosure from ebay and then try ur dvd drive in that
but it is available in desktop dvd drives but laptop i am not sure if it is there on ebay but pls check it out
PLS RATE ME WELL !
Regards
Zohail
May 29, 2009 | LG DRN-8080B DVD Drive
External hard drive will not turn on
Try a new enclosure, the case is just that. A hard drive cannot actually repaired. You cant open it and fix it. It's either reliable and functioning or not. Purchase a new enclosure and test the old drive. Data recovery should be the last option..most places charge a down payment on a car, and most of the time ( in my 12 years ) its the cheap enclosure.
Keep me posted.
Oct 08, 2007 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Gateway M350 Notebook Logo
77 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
