Could you tell me how do i get the pump out to check for blockage please
At the back of your machine there is a plate at the bottom . Removeit and the pump is on your right. The machine does have a filter which may be blocked rather than the pump. The filter is located in the pipe which runs from the pump to drum at the drum end.
Hope this helps, do post back if more info needed.
Posted on Jan 16, 2009
Unscrew and remove lower rear cover of washer.
On the bottom right hand side, you will see the pump located, it has 2 hoses going to it.
Remove both hoses, unplug wires going to it, and slide the pump to the left, it may or may not have a fixing screw at bottom,remove pump and check.
If you need to check the filter, then remove large black hose going to bottom of tub, remove plastic filter ,and clean
Refit filter and hose, and test.
Plz rate my solution.
Thanks.
Mar 05, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Jan 28, 2010 | Hotpoint Aquarius WD640 Front Load...
Dec 29, 2009 | Hotpoint Washing Machines
Dec 28, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Nov 20, 2009 | Hotpoint Aquarius WD640 Front Load...
Nov 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
May 19, 2009 | Hotpoint Aquarius WD63 Front Load...
Jan 16, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Feb 27, 2008 | Hotpoint Aquarius WD63 Front Load...
Dec 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Mar 28, 2016 | Hotpoint Aquarius WMA42 Front Load Washer
