Question about Motorola Mobility HT820 Wireless / Cable Headset
My bluetooth headset Motorola HT280
I have a Motorola HT280 and Im using it with a Pocket PC 6700 from Sprint. Why can't my music play(i have saved on my phone) out of my headphones? This is the reason why I bought it. PLEASE HELP.
    Scholar:
  • 130 Answers
A small correction to the other solution, the Left M Symbol will not Blink in pairing mode, but will stay Solid. Also, to pair the device, you will need the bluetooth security code for the Headset. It is 0000. You cannot change this. The Pocket PC will ask for this code.
Posted on Aug 17, 2007
  • 3 Answers
Have you paired it with the Pocket PC yet? If you haven't.. press and hold the left-side M emblem for about 3 seconds until it starts blinking. This will put it in pairing mode. I'm not sure how to work Bluetooth on the Pocket PC, but wherever Bluetooth settings are, you need to turn on 'Find me' or something similar to that. Allow them to find each other, and they will ask for your approval, and then automatically pair. Hope that helps, goldfinger
Posted on Jun 19, 2007
SOURCE:
Forgot my keypad unlock code
i have a sprint pocket pc-6700 i forgot my keypad password how can i unlock
Apr 11, 2009 | RIM BlackBerry Pearl 8100
Unlock sprint?
keypad of my Sprint 6700 is locked. even the touch screen
Feb 23, 2009 | Audiovox PPC 6700
Motorolla earphone plugin wont work on my sprint touch
im pretty sure the touch is an htc product htc and motorola are in conpatible when it comes to headphones the plugs may both be mini usb but the connections are different htc utilizes more of the connections you can buy an adapter at semsons.com to hook up regular headphones i found out the hard way and looked all over good luck
Feb 11, 2009 | iLO (2 GB) MP3 Player
Music won't play on my bluetooth headphones.
If your handset does not support stereo music on blue tooth headset, then you can not hear music on blue tooth head set. However you are able to answer and make calls through blue tooth headset.
Jan 08, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola W755 2.5mm headphone adpater connectivity problem
It actually has to do with the 2.5 mm adapter. I had the same problem and went to buy a new one because I thought the adapter was bad. Went to Radio Shack and the guy said there are 4 wires within the audio input so that you can add a microphone too if you want. You have to buy an adapter that grounds that 4th microphone wire and it'll work just fine. I got the more expensive adapter (about $10) and haven't had the redial problem since.
Dec 22, 2008 | Motorola Mobility MOTO W755 Cellular Phone
Touch screen not working
You Will need to Hard reset the phone but make sure you back up your info first, because a hard reset will delete all info. To Hard reset the phone hold the two Soft keys which of Dots on them and then while holding those buttons press the reset button located on the bottom of the phone by the Charging port.
Mar 20, 2008 | Sprint Vision PPC-6700 Smartphone
Email Sending
if the email address has more than 32 charchters then sprint will reject it. I ditched my outlook on the phone for GMAIL mobile you can setup all your POP email addresses with gmail and never have problems like the ones your having. gmail is google email. the added benifit to using gmail is that you can free up your on phone memory to store email for other things like slide to unlock s2u2 which will prevent pocket calls and save your battery.
Jan 25, 2008 | Sprint Vision PPC-6700 Smartphone
Saving music on my micro sd..
The only way the music can be played on a cell phone is if it is in mp3 format. you also have to list the songs individually (they cannot be separated into folders). to listen to the music you should have some sort of music player on the phone that will play the songs.
Nov 24, 2007 | HP iPAQ H1910 Pocket PC
Music files
I have e800 and there is no problem with mp3 music files. You can save it on PDA directly or even on SD card. The only thing is sound quality. The PDA speaker is not the best one. If you want you can use stereo headphone.
Sep 11, 2005 | Toshiba e350 Pocket PC
Motorola Mobility HT820 Wireless / Cable Headset Logo
678 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
