Question about Sanyo PLC XP21N Multimedia Projector
Sanyo projector PLC-XP21N does not start up properly.
When we turn on the unit, an normal start-up takes place, but approx 13 seconds into it- the unit shuts down completely. No Sound or picutre.
Fan is heard running until shut down.
    Sergeant:
    Champion:
  • 435 Answers
Is the lamp good in it ?
Did you change any lamps recently ?
Posted on Jan 25, 2009
  • 1,031 Answers
The projector may be shutting down because it is overheating.
1. Are the air filters dirty? Most Sanyo Projectors have two filters that protect the
LCD screen from dust. Dusty buildings or simply grounds crews stirring up dust with
lawn equipment can clog filters fast. Clean filters.
2. Is the projector under or near an AC or Heating vent? Many projectors are installed
in the summer when the AC is on. When it gets cold and the heat kicks on, it can
shoot hot air at the projector causing it to overheat. Try blocking the heated air or
moving the projector.
Posted on Jan 16, 2009
  • Starnley Johnwells
    Starnley Johnwells Jan 16, 2009
    . Filters should be cleaned every 3 to 6 weeks.
    Your filters should be located on the top of the projector. To access the filters, lower the
    Activboard to the ground. Locate the two, gray rectangles on the projector. Gently pull
    the filters out of the projector. Gently clean the filters by blowing on them or use a soft
    cloth to wipe the dust away. Insert the filters back into the projector when finished
    hope this helps if you have further issues on this do let me know am here for you.
    Brigadier General:
  • 3,614 Answers
May i kn0w h0w 0ld n0w the unit.
have u d0ne changing lamps
Sanyo plc-xp30. Lamp turns on but has a yellow tint , in a circle that does not quite take up th ewhole screen. the color looks normal around the edges.
U need to unplug unit and turn on its back replace filter . blow out. sounds like its getting hot and dusty. u need to clean before u burn out your optical engine like i did.
May 25, 2011 | Sanyo PLC XP30 Multimedia Projector
Hello.... Sanyo PLC-SU20N projector....shuts down within 3 seconds of turning on.
If the lamp doesn't strik, it will.
Check the ballast unit and lamp age.
Mar 19, 2011 | Sanyo PLC SU20N Multimedia Projector
Replace lamp
unplug unit.
undo screw on lamp cover and open.
remove 2 screws and pull out the lamp.
install new lamp and do in reverse.
reset lamp timer
press menu, go to setting, and press the select button.
select lamp age
click yes to 'lamp replace monitor reset'
OK is displayed, select yes
then select no
quit
Mar 03, 2011 | Sanyo PLC XP21N Multimedia Projector
I just replaced the lamp on my Sanyo PLC-XP55 projector and reset the lamp counter but now it won't turn on. When I press the power button, it goes into a cooling mode for 90 seconds and then never turns...
did you get the bulb from sanyo, or from another company that sells aftermarket bulbs? some of those are cheaply made and malfunction shortly after if they work at all. find your reciept, take it back and get a new one.
Jul 22, 2009 | Sanyo PLC-XP55 Multimedia Projector
Projector turns off after 5 seconds
You have a classic temp sensor problem. Its a fail safe on theprojector, basically a fuse that bridges the main power cables. Lookslike a little pot, With a white ceramic head.
Now what it does, Is the white ceramic head rises as the unit getshotter, and thus breaks the power circut. All you need to do is, openup the unit, locate the sensor (its mounted next to the lamp on yourprojector) And push the little white head back down, thus closing thecircut, and restoring power supply.
Here is the full repair schematic to guide you. :)
http://yama.co.za/forum/index.php?topic=146.0
Jul 12, 2009 | Sanyo PLC-SW30 Multimedia Projector
Sanyo plc-xp46 lcd projector
In the on-screen menu...
Press MENU, go to SETTINGS ICON, Move to Lamp Reset
Also, to see lamp hours used, press and hold the UP ARROW (on the unit, not on the remote) for 30 seconds while projector is on
Feb 10, 2009 | Sanyo Projector Lamp for PLC-XU100,...
Sanyo plc sw30 help
i had a sanyo plc sw30 wich had the same problem and it turned out to be the bulb replaced it with new one and this seemed to solve the problem. Theres a few places to get new ones but they are not cheap looking at between £150 to £180 hope this helps
Nov 02, 2008 | Sanyo PLC-SW30 Multimedia Projector
Sanyo PLC XP21N Multimedia Projector Logo
137 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
