Question about RELIANCE ELECTRIC WATER HEATER
Hear water in the pipes in the walls
Woke up with no hot water, but could hear water in the water pipes(a natural occurance in this older house-=when the water is running) replaced the heating elements, high temp cut off, and the upper thermostat. we briefly have hot water, but can still hear water flowing through the pipes, even when there is no water running. could this be a fault in the hot water heater-allowing water to seep through, or is it a fact that we have a leak in the walls? the hot water heater we are dealing with is 15 yrs old at least.
(my e-mail address has zeroes instead of o's)
  • c00lwhipt1 Jan 16, 2009
    the sound of water seeping through the pipes is only happening whenever the hot water heater is on-=even though no faucets are on. the outlet valve is warm, not hot.Also, when replacing the element, does it matter if the wires are reversed? there is a yellow wire and a blue wire that connect to the new element.
    Sergeant:
  • 216 Answers
Before you can assume you have a problem with the hot water heater you need to find the leak first. If you indeed have a leak you are not only loosing water, but your hot water heater may being trying to heat the tank all the time.
I suggest that you get some help from a friend, First start off by making sure all faucets and toliet valves are turned off. Try to locate the sound of the running water. Now place you help new the sound and go turn off the water to the hot water heater, Have your friend tell you if the water sound stops. IF the water sound stops than this is a leak in a pipe and it is a hot water leak. In this case you will need to turn off the power to the hot water heater or the gas supply.
By leaving the power or gas to the water heater you are mearly tossing cash out the window because the water heater can not heat the amount of water traveling through it.
You will then need to try to find access to the pipe that is leaking, either through removing drywall, hopefully it's in a place that can be accessed easily, but either way you have to repair the leak.
If you have copper lines in the house or Sea tek (plastic lines) you should be able to purchase either soldier copper fittings and some soldier or some plastic couplings to make the repair.
If by chance you have a real old house that is using galvanized pipe you may have a bit harder project in having to remove the old pipe back to the nearest joint..
If you are familiar with soldiring copper pipes than you should have a issue. however because of the relative placement of the leak sounds to be in a wall you might consider finding the leak and calling a plumber or a good friend that has a good deal of plumbing experience to help.
Posted on Oct 18, 2013
  • 19,396 Answers
That may be normal, sometimes the heater may be pumping water into the heating system to keep pressure level.
Posted on Jan 23, 2009
  • 334 Answers
Yes, I'd say you have a leak somewhere.
Do you have a home heater that uses the hot water for its source of heat?
If your dip tube is broken it could also contribute to running out of hot water quickly or near emediatly.
The dip tube is what forces the water to come off the bottom of the tank instead of the top where the cold comes in. If the tube is failed, then you are just recycling cold water and not touching the hot water below it.
But if water is flowing through the pipes and nothing is turned on with no water based heater, then you must have a leak somewhere.
Posted on Jan 16, 2009
  • Danny Clark
    Danny Clark Jan 18, 2009
    About the element. no it doesnt matter if the two wires are reversed.
    When you say it only happens when the heater is on. Do you mean when the electric power is on to the heater, or when the water from the heater (shutoff valve) is on?
    If you mean the shut off valve, then these must be a leak. If you mean the electric, then you are probably hearing noise made as a result of water heating up, pressure building, and circulation from that.
    Also, does your system have a recirculation loop?
    Some units have that to ensure that the water in the pipes is always hot. That way, you don't have to wait seconds to even minits for hot water to come out of the tap.
    If you have a recirculation loop, then thats the source of your sound.
    President:
  • 1,990 Answers
Welcome to Fixya! You need to Replace that Hot Water Heater. After this is Done Hopefully, You will not here the Water inside the Walls. Either way the Water Heater is Bad. Could STILL be a Leak in the Wall though! Make sure and check!
    Genius:
  • 2,920 Answers
It sounds like you have a leak in the wall somewhere. you should not hear water running when it isnt. i would try to track down the leak before it becomes more major.
  • Ronnie Houston Jan 16, 2009
    the wires could be reversed the only thing i can suggest it that you switch them and see if that dosent solve the problem
    Brigadier General:
  • 5,158 Answers
I would suggest if you hear water running but nothing is on that there is a leak in the pipes in the wall..
Also is the outlet pipe on the water heater hot ?
Robert
  • Roberta Smith
    Roberta Smith Jan 16, 2009
    My suggestion about the water heater tho you may not want to hear it is to replace it. a new water heater will be more energy efficient and durable.
    As for the noise in the walls... i suspect the leak is in the hot water side and although you haven't noticed the water leaking you will.
    a quick way to tell is to compare the water pressure between hot and cold.
    Robert
I hear a knocking noise behind the wall when I use the hot water. What could it be and how do I get rid of it?
I had something similar, but I would call the noise more like 'ticking'. The problem was that hot water would heat up the plumbing vent piping (plastic) for that bathroom and it would expand and then contract (after shutting hot water off). As the pipe 'grew' it would make noise sliding through the opening in the ceiling header. It seems that builders had stuffed loose fiberglass around the pipe there that served to let the pipe move freely. The fiberglass had fallen out and the pipe was rubbing against the wood and making noise. Stuffing new fiberglass in the opening around the pipe fixed it.
Oct 29, 2014 | Water Heaters
When I run hot water for the tub, it has a brown tint
10 year old homes today usually do not have galvanized pipe. They have copper or pex plastic pipe. These do not rust.
Is rusty water on both hot and cold line, or just hot line?
Just hot line, then check anode rod and flush tank:
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flush
Are you on water well? Well casing can get rusted. Water can have minerals. Call local water well service and describe problem in detail.
Are you on city water or mudd district water? Is pipe coming into house made of galvanized? Look inside meter box or look at pipe coming into house. Sometimes the city water line at end of run can get filled with sediments that will discolor water. Have water company flush the city water line.
May 04, 2013 | Rheem Water Heaters
Is my water heater leaking?
You have water leak that you can hear running water.
Could be broken pipe under house.
Could be water running out of tank at TP valve.
Turn off all water taps and put ear against each pipe at tank.
If TP valve is leaking, then replace TP valve.
If pipe is broken under house, then call contractor.
Copy following links for troubleshoot walk-thru.
http://waterheatertimer.org/images/Ear-against-pipe-200.jpg
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#listen
Aug 28, 2012 | Reliance 606 Series 40 Gallon Electric...
Banging noise when hot water is turned off
plenty of water pipes particularly in older houses where pipes may not be fastened tightly or at all to the frame of the house suffer from what plumbers refer to as waterhammer. This can be fixed by installing a small device inline from your local plumbing shop. It can also often be solved ( I have found) by fastening you water pipes at closer intivals/more securely to your house frame. Hope this helps. Mine stopped doing it once the pipes were locked in place.
May 11, 2012 | Rinnai Water Heaters
Our gas water heater (Rheem Optima Quick recovery 81 series) heats the water as evidenced by the steaming water we can release from the temperature and pressure relief valve but we get no hot water from...
Sounds like a plumbing problem.
Since no tap gets hot water, chances are good the problem lies in the hot water pipes between the water heater to the first Tee.
Look for sediment lodged in water heater hot water pipe.
Or sediment lodged in elbow or Tee.
Other problems can be in play.
Faulty check valve or mixing valve if these are installed.
Faulty recirculation system if this is installed.
Also crossover at single-handled faucet where the cartridge is bad and lets the cold water flow into hot water pipe whenever another faucet is turned on. If you are getting cold water out the hot tap, and you know the hot water heater has hot water, then crossover is suspect > in addition to sediment blockage at hot water heater.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 15, 2011 | Rheem Water Heaters
I have the exact same problem, house is only 6 years old, two handel faucet, Ive turned off the cold side to eliminate it, turn on hot and have to run at full blast and it takes a full 10 minutes to get to...
You have a clog in the water line?
Or a faulty check valve or mixing valve?
Add a comment and say how you fixed the problem, or add more information about size of pipes.
It seems like the cold water is getting into the hot water line somehow. There is no other explanation, as much as I can see from 800+ miles away.
If you have crossover on a single-handled faucet where the cartridge is bad, that can cause this problem.
Slab house can have plumbing in attic. It can be a chore to drop poly pipe down into walls, but it can be done with angle drill. Assuming walls are 8 foot high and pipes can be easily dropped to sink level where the sheetrock is removed and new pipes tied into sinks and tubs.
This kind of DIY project would take a couple weeks working a few hours each night when temps cool off, depending on size of house and number of affected faucets.
I live in Houston on a slab and ran my pipes in the attic when I built the house. Of course I worry about broken pipes collapsing the ceiling and filling the house with water, which happened to lots of homes one year when temps dropped to 4 below. I was in the painting business at that time, which was a boon to business for a few weeks.
Upvote the help.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Dec 17, 2010 | Laing Thermotech Autocirc Undersink...
My water is cooling in long copper runs and flow issues w/tkless
OK Lag the Pipes, you can get insulation that comes in two halves that goes around the pipes and uses "Ties" to hold the sides together. Or you could lag it with Hessian wrap, Anything you can wrap around and "Lag" the pipes with will be better than nothing.
Feb 08, 2010 | Noritz 7.1 Gpm Natural Ng Gas Tankless Hot...
I am hearing a kncking sound from my wall (behind the wall are pipes) and it occurs day and night sporadically - appears to be associated with the Power Vent 2 - is there anything I can do
You can install a water hammer arrestor. They are available at the hardware store or your favorite home improvement store. Also, look for pipes which are not secured tightly to the wall studs.
Oct 02, 2009 | Rheem Water Heaters
Rheem Pronto Hotwater Heater Error
Unplug unit from wall. Disconnect remote wires from circ board, and let unit set for about 5 minutes. plug back in. run water and see if unit comes on.
Jun 16, 2009 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Losing hot water in one facet only
There is something in the line or in the faucet.Are your pipes going to the faucet black iron or galvinze.Some of the pipe will rust up and stop a full flow of water.But I would check the faucet first to see if the screw is loose or somethng in it.
Mar 17, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
RELIANCE ELECTRIC WATER HEATER Logo
46 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
