I have wasted 4 hours with 1 of your so called (experts) i want answers not excuses
  • 2 more comments
  • matthewwater Jan 23, 2009
    I have been downloading movies of mininova and then using nero burning them onto dvd , thet burn no worries can watch them on any computer , my problem is when i try and watch them on my dvd player on t.v, the dvd player does read them ?. Computer is a Hewlett packard and my dvd player is Lg.
    The movies are dowloaded as avi. and then i use nero and make bootable dvd. is this correct ???
  • matthewwater Jan 27, 2009
    thanks for your help, but i downloaded the divx programe and converted my avi movie unfortunately the dvd player does not read the disc.
  • Muhammad Ali May 11, 2010
    Hi
    I think, it is the avi. format that LG machine is having problem reading.
    Speak to someone at LG helpline. My guess it is the format and not anything else.
    I will also check here and hget back with further info.
    Ali
    If only one writes the problem, make and model, someone can try to help.
    Problem Solver:
  • 5 Answers
Don't know if I can help or not, but this what I do.
I've downloaded the DIVx player and converter software (free) to my computer. I can download mpeg, avi movies, etc, and convert them to DIVx format if I need to. The DIVx player has a 'burn' feature that is fast and burns them in a DIVx format. My old DVD Recorder will not play DIVx format but my 'cheap' Phillips will. I just keep it hooked up to my old DVD recorder through the front RCA input jacks. When I want to play a DIVx movie and watch it on the TV, I use the cheap Phillips player. I have to change the input on my old DVD Recorder to 'Front Input. I usually record the movie on a DVD R in my DVD Recorder while I'm watching it if I want to keep a copy to play later on the DVD Recorder. Most of the time, I burn the movies to RW DVD and erase them later.
I don't remember the web site for the DIVx players and converters, but you should be able to find it with a search.
Hope this helps.
Posted on Jan 25, 2009
What configuration do the output power wires look like. Do I connect to 3 and 4 , slots etc. What is meant by "load" in the instructions?
1) You posted under ET104C DPST (double pole single throw) 24-hour 4-ON and 4-OFF per-day selectable-voltage timer
DPST means that timer will turn off two wires going to 240Volt Load or two separate 120V Loads
Open following link for example Intermatic ET series wiring diagrams and manual:
http://waterheatertimer.org/How-to-wire-Intermatic-ET-series-timer.html
2) Load means whatever electrical device is controlled by timer. ie fan, light, motor, pump, alarm-bell, water-heater, bowling-ball-machine etc.
Line means cable coming from breaker box.
3) If you have a different timer, then add a comment with photo of inside of timer door for possible identification and complete answer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
4) Selectable voltage means you have to choose voltage.
Timer come preset for 240Volts.
If you have 120V 208V or 277V, then follow the vague instructions shown on page 2 #2 of manual.
5) Do not apply voltage to this timer before matching selectable voltage setting with circuit breaker voltage.
6) ET104C has 6 terminals and can be wired many different ways depending on Load voltage, etc.
This timer can do a lot of different things.
If you have ET102C with 4 terminals, then add a comment and clearly explain voltage, color of wires, and what breaker you have and what Load you are controlling for best answer.
7) ASSume you have 240Volt cable coming from breaker box, and that you are controlling a single 240Volt Load like a water heater or pool pump.
240Volt cable from breaker will have 2 hot wires called Line 1 and Line 2
Line 1 black wire will attach to both terminal 1 and terminal 3 (use a jumper wire between terminal 1 and 3)
Line 2 red or white wire will attach to both terminal 2 and terminal 5 (use a jumper wire between terminal 2 and 5)
Your 240Volt Load will also have 2 wires.
Load 1 black wire will attach to terminal 4
Load 2 red or white wire will attach to terminal 6
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 23, 2011 | Intermatic INC ET104C 24 HOUR ELECTRONIC...
My oven takes over an hour to preheat. What can I do?
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Aug 08, 2010 | Maytag CWG3100A Gas Single Oven
I dont know this one is idiotic
Mar 10, 2010 | Thinkfun Rush Hour Board Game
What number do i call to get a rebbot **** for my emachine computer?
Whether you're buying Answers by eMachinesSM services as a gift for dad, grandma, a friend or yourself, we have three money-saving options:
30 Minutes1
$5999
90 Minutes1
$12999
1 Year — 15 Incidents1
$19999 To Order:
Call 800-237-6483 To Use:
Call 877-721-7314
Subscribers to our Answers by eMachinesSM service should call 877-721-7314 for assistance with their covered technology. Our experts are available 24 hours a day, 7 days a week. Long-distance charges may apply, depending on your calling area.
Dec 24, 2009 | E-Machines T3504 PC Desktop
Fossil wristwatch: hour and minute hand not in sync
Aug 30, 2009 | Casio Waveceptor WVA104HA-1AV Wrist Watch
Traeger Grill has inconsistent smoke temperature
May 16, 2009 | Traeger Industries BBQ070 All-in-One Grill...
Garmin gps 276c plus won't acquire satellites
Apr 11, 2009 | Garmin Gpsmap 276c Portable Marine/Auto...
Freezer alarm beep can't reset showing CE then -10/CE 0 food ok
Mar 20, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
RCA 25205 wont answer correctly
Yeah, I've wasted all morning messing with this. My personal outgoing message keeps reverting back to default. I just got off the phone with RCA and here's the fix for that part of the problem. Go into "Configure Out-Going Announcement" (page 23) and then select "personal," This finally made it stay there. The number I called for help is 1-800-511-3180, or 1-866-285-4651. Good luck!
Oct 27, 2008 | RCA 25205RE1 Phone
Jabra bluetooth headset
how do I set up the phone to discover jabra vbt185z?
Dec 29, 2007 | Jabra BT350 Bluetooth Headset Headset
Televison & Video Logo
192 people viewed this question
Top Televison & Video Experts
Electro Med Services...
