Question about Microsoft Xbox 360 Console
Everything works but wireless remote won't let me start game
The wireless remote is blinking and the game will say "press start", but nothing initiates the game to begin.
  • 4 Answers
Press the sinc button on the xbox and then press the sinc button on the controller if this will not fix the controller then your battery's are prolly dead.
Posted on Jan 17, 2009
Samsung HT F5500W The system worked without a problem. I painted the room so I had to disconnect everything. After connecting back rear speakers does not work and the link light on wireless box is...
with the main unit off. Press and hold the link button on the back of the rear wireless amp until it starts blinking fast. The take the remote and while pointing at the main unit, press 0-1-3-5 enter. Wireless link ready should show on the display. Turn on the main unit, and it should find the rear amp.
Jul 17, 2014 | Audio Players & Recorders
Can not get the mac pro osx 10 5 8 to start with the utility disk or with regular start up my on pilot lite keeps blinking
Put the Mac install disk back in. Try pressing command-option-escape to force quit. If nothing happens, then press command-control-power to force a restart. If that doesn't work, press and hold the power button for five seconds or so until the computer shuts down. Power up the computer again, and hold the option key so you can select the instal disc for startup. Run Disk Utility again. Sometimes you get a tangled file reference that requires several tries to undo - this could be calling the sleep routine instead of what it's supposed to do.
May 28, 2013 | Computers & Internet
Roku 2 remote won't work
If you have a Wi-Fi Roku remote or a bluetooth Roku Remote, the remote needs to be paired with the unit first before you can control the device. To pair the unit with the remote, you can do the following:
  1. Turn off the Roku player for 30 seconds by unplugging the power cord from the power outlet.
  2. Once you have the bouncing Roku on your TV screen, open the battery compartment of the remote and press the purple button there once.
  3. The Led on the remote should start blinking.
  4. Leave the Led blinking and don't press any button on your Roku remote.
  5. Wait for the Led to stop blinking.
  6. Once the Led stopped blinking, try to test any button and see if it works.
Mar 25, 2013 | Roku 2 XS Wireless Streaming Media Player
Just changed the batteries in the remotes.and getting no signal when pointing at the screen to play games
sir think your remote is not working properly... you better try to reset your remote for your nintendo wii console... this is how you can reset your remote...
  1. How to Reset Your Wii Remote
    • 1 First you will need to check a few things, just to make sure what the actual problem is.
      *Check to see that all cords are properly plugged in.
      *Make sure the sensor bar is properly center above or below your tv set.
      *Make sure that nothing is blocking the signal to the sensor bar.
      *Make sure that the batteries in the remote are in good working order.
      *Make sure that there are no wireless devices close by that might be interfering with the signal.
    • 2 If after all this the remote is still not working then it probably needs to be re-synced.
    • 3 Turn off and unplug your wii console for a few minutes.
    • 4 *Turn the power back on and when you see the the safety screen open the small flap on the front of the wii console. Inside you will find the red sync button. Press and hold the red button down for 15 seconds.
      * Then remove the battery cover from the wii remote, inside you will see another red button.
      * Press and release the red button, the blue lights on the remote will start blinking.
      * Quickly press and release the red sync button on the wii console.
      * The remote will stop blinking and it should now be synced.
or visit the links below
Read more: How to Reset Your Wii Remote ' eHow.com http://www.ehow.com/how_4527749_reset-wii-remote.html#ixzz1OyHyruvP
if you think this help you please rate me by that it will help me to... thank you in advance...
Jun 11, 2011 | Nintendo Wii Console
Bought nintendo wii last xmas and had played quite frequently. then after a break in play of a few mths the remote controls dont seem to be being picked up by the sensor. i chenged the batteries and still...
Hello there
Hold the Wii Remote upside-down with the buttons facing downward.
Tap the remote firmly against the palm of your hand three times to remove any dust sitting between the buttons and the electronic circuit board inside the remote.
Turn the remote upright and press one of the buttons. If the problem continues, Open your Wii Remote's battery door
Check that your Wii Remote contains two new "AA" batteries or a charged battery pack. Check that no corrosion is present on the battery's metal elements/connectors.
Use a cotton swab to clean the remote's battery element/connectors if corrosion is present.
Check that the Sensor Bar cable is inserted firmly into the back of your Wii gaming system. The Sensor Bar needs to be centered above or below your television so the Wii Remote can transmit signals to the gaming system.
Stand three feet away from the Wii gaming system/Sensor Bar.
Aim the remote and press any button to test the device.
If the remote is not working, stand five to 10 feet away from the gaming system and try the device. The Wii Remote works best three to 10 feet away from the gaming system/Sensor Bar.
Move any objects blocking the signal from the remote to the gaming system/Sensor bar--candles, other remote controls (TV/cable box) and wireless computer devices/cellular phones.
Also, if any sunlight is coming in through a window, close the curtains or blinds to keep the light from interfering with the remote's signal.
Turn off and unplug your Wii gaming system. Leave the unit unplugged for one minute. Plug the gaming system back in.
If the remote still aint working;
Turn the Wii system on. Press and hold the red "SYNC" button for 15 seconds when the "Health and Safety" screen appears on your television. The "SYNC" button is behind the small door on the front of your Wii unit.
Release the "SYNC" button. Remove the battery cover and batteries/battery pack from the back of your Wii Remote.
Press and release the red button located under the battery compartment. The blue lights on the front of the remote will blink
Press and release the "SYNC" button on the front of your Wii gaming system. The "Player" light on the gaming system stops blinking and stays on, the resetting process is complete
Oct 01, 2010 | Nintendo Wii Console
Xbox wireless controller lights keeps blinking but
If the ring of light keeps blinking, it means that the remote controller was not connected to a receiver which is the XBox 360 console. Try to press the connect button on the console and the wireless controller to sync them together.
Apr 27, 2010 | Microsoft Xbox 360 Controller
Wii Rockband guitar lights keep blinking
Ensure that the receiver is plugged in to the USB port in back of the Wii Console. If the light on the receiver is blinking, too, then with the Guitar turned on, press the white button on the receiver.
Apr 01, 2009 | Nintendo Wii Rock Band Guitar for Wii
Receiver blinks green, wireless controller blinks red and does nothing
hold in the button on the top of the receiver until it is a solid green then press any button on the controller
Oct 30, 2008 | Logitech Wireless Xbox GamePad Cordless...
Wii remote won't work. Just lights up
pair the wiimote with the wii. open the slot where the sd card goes press the red button then open the wiimote and press the red button right after
Feb 25, 2008 | Nintendo Wii Console
Microsoft Xbox 360 Console Logo
41 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
