Nad 3140 volumn
I Read your comment on the volumn pot.Tried cleaning no help.Cannot controll volumn at all.Can you locate me one ,which also controlls the balance. Thank you JIM
  • 85 Answers
Hi there funny you should ask that because i do have a second hand one with balance knob and volume knob also ,i dont know where you live but you can have it for 10 gbp plus 2 gbp postage i accept paypal Kind regards Steve
Posted on Jan 18, 2009
  • steve hall Jan 18, 2009
    If your interested send me an email at ...hallsteve88@googlemail.com and i will give you paypal email address
Can you still get a new volume control pot for a nad 310 intergreated amplifier
I don't see why not. Just get the value of the pot off the numbers on the back of it or measure it
Aug 30, 2016 | NAD Audio Players & Recorders
Where is volumn control located on Mac Book
F12 increases volume. You may need to raise the volume on the browser before you go full-screen.
Feb 15, 2014 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Phillips Magnavox 9P5034 C101 can't adjust volumn up or down on tv or with remote controller
Reset the code for r. control download from www. remotecodelist.com
2) clean the contacts battery
3) retight the spring contacts battery with pliers for better contacts.
4) otherwise you must go to the repair shop TV for fix it.
God bless you
Jul 31, 2012 | Televison & Video
On/off switch doesn't turn on or off. It just spins.
Posted earlier that it was volumne and tone control on two stacked pots with a on off contact at the rear. I measured and posted the value of the two stacked potienmometers correctly. But I mislabled the use of them. Correction: the tone control is a different pot located nearby.
Dec 02, 2010 | Grundig Classic 960 Shelf System
The balance pot of my NAD C370 is not working, will the amp still work if I remove the balance pot?
Only if you replace the pot with two resistors of equal value. Both need to be also equal to 1/2 the value of the pot. Then at the point the 2 res tie together -- Tie that point to the middle lead location and the other leads to the other points where the pot was connected. Use 1/2 watt or 1 watt res.
Nov 02, 2010 | NAD C370 2-Channel Amplifier
I have a old NAD 1300 pre amp. I need to replace the volume rheostat where can i buy the part?
Hi, for the price of servisol you may as well buy a brand new pot. The nad uses a dual carbon pot. Any electronics shop should have one.
Is it a pcb mounted type or one with loot solder tags?
A couple of quid, but if you want to upgrade, then spend around a tenner and get an alps conductive plastic pot.
Try this:-
http://www.rapidonline.com/sku/Electronic-Components/Resistors-Potentiometer/Control-Potentiometers/Professional-audio-potentiometer/65228/66-0225
OR:-
http://www.maplin.co.uk/Module.aspx?moduleno=2207
Have a look on ebay, there should be loads.
Just found this mod.
http://www.diyaudio.com/forums/attachments/solid-state/69062-replacing-nad-1300-volume-balance-pot-nadmods.jpg
If you need more help, give us a shout and i'll try harder :)
Regards - Anthony
Feb 11, 2010 | NAD C320 2-Channel Amplifier
I have a old NAD 214 amp. I think its broke. the music sounds like a cheap cell phone in a fringe area. One channel plays at a time, in and out signal bad. What is this?
Sounds like your control pots are dirty. Remove the knobs. Get some good cleaner at Radio Shack. Something with alcohol, and some other ingredients which will remain. Try tuner cleaner, blue shower, etc. Spray the cleaner into the pots and rotate end to end. May have to do this several times to get all the dirt. When it starts to sound like it used to you are done. Let me know how this works out.
hardrocko
Feb 06, 2010 | NAD Audio Players & Recorders
NAD T760 remote control
You could buy a universal remote control and try the following NAD audio remote codes to program it with:
NAD
575 773 975
I read somewhere else that the 'Supplied Code for NAD receivers' was 033, but cannot confirm this. Try the first 3 first.
Universal remotes tend to be pretty cheap, certainly cheaper than buying one from NAD.
Good Luck
Chris (ziraffa)
Dec 20, 2008 | NAD T760
I do not have any volumn control
Open the speaker where the volume control is located then check it if there are lose connections. You can also clean the variable resistor or the volume control with a contact cleaner solution or oil... ^_^
Jan 19, 2008 | Yamaha YST-M7 Computer Speakers
Nad 302 amplifier
sounds to me that the vol control has lost its earth end connection So yes its a problem with the dial control You couls try some contact cleaner But better still lift of the lid and base if possible while the amplifier is not plugged into the power socket and see if you have a dry joints around the vol control pot regards Trev
Mar 14, 2007 | NAD CI9060 Amplifier
318 people viewed this question
 Grubhead
Grubhead
