Question about SanDisk Sansa e200 MP3 Player
Sansa e200 My problem started when i was listening to some music. Then when i went to change the song it said bad track then the screen dissolved away and kept restarting. And when it restarted the SanDisk beggining thing stayed they dissolved away like ive never seen before and restarted again and did the same thing over and over. And i do not know how to fix this problem. I cannot just go and delete the song on my computer. Oh and the song that was a bad track was fine before.
    Problem Solver:
  • 15 Answers
I would try formatting the drive/player. Why can't you delete the bad file?
Posted on Jun 19, 2007
SOURCE:
Windows mEDIA PLAYER SAYs my sansae260 is full, but device won't sync. It says no song. I tried to reset, but still says no song
change the usb modes also....MSC will allow you to see the expansion card ( 2Gig E200 series 4gig Fuze) mtp won't.....MTP shows you your music folder in the media folder thats where you put your music plus expansion.....
Delete songs and Format (Helps with trying to delete BAD TRACKS and folders that will not delete full memory(Some ripped CD folders).. Go to my computer scroll to sansa or your MP3 player and open the music folder and open each sub folder and delete Songs manually then delete the folders themselves then format a couple of times hope this works
Jun 21, 2010 | SanDisk Sansa e260 MP3 Player
Deleting songs.
Your DB might be corrupt. Folow the delete procedure one more time:
Delete Music Files
1) Connect your Sansa to the computer.
2) Select Open device to view files using Windows Explorer on initial
connection.
3) Select the place where you want to delete music files from
4) Highlight and delete the music file/s or folder from My Computer\Sansa
e200\...\MUSIC
folder. (You can also select from a variety of music
software programs to transfer/synchronize your files).
If that fails, go ahead and update the firmware - it will delete everything, and allow you to start over from scratch among other things.
-Tha Mp3 Doctor
Feb 16, 2009 | SanDisk Sansa E280 MP3 Player
Bad track
To delete songs from your device follow the steps below
You have to make sure that the device is on MSC mode...then make sure your device is plug in to the computer..Then go to programs - accesories - windows explorer, find the SanDisk in my computer, go to media, music and delete them from there.
Either under sync panel in your windows media player it will show your music when it's connected. just click the plus signs for what song you need to get rid of, right click and click delete.
To format it..on your device..go under..menu, setting and there should be a format option option there..let me know if that doenst work for you...
Hope this helps
P.S.Please rate accordingly...
Thank You
Computerrep
Aug 20, 2008 | SanDisk Sansa e200 MP3 Player
LOST SPACE!
same thing happened to me it still doesn't work and mine is supposed to hold 500 it only holds 150
Mar 11, 2008 | SanDisk Sansa e250 MP3 Player
My sansa e200
-Plug in your mp3 player
-Go into 'Limewire', select a song and go 'Locate file/Open Containg Folder', you should be in your folder with all your songs. or go 'My Music' and find your music files.
-Either select all your songs, open them with 'Windows Media Player' and transfer them that way.
-Or 'Open My Computer' then open 'Sansa e200' and drag the songs from where your songs are located [My Music] to the 'Music' folder in your Sansa e200 folder.
[MyMusic] Song.mp3 >drag to> [MyComputer/Sansa] Music.
Dec 26, 2007 | SanDisk Sansa e200 MP3 Player
Sansa e200
omg! i have the same problem and its so annyoying. so i just formated it and added my songs back its a major pain in the ass but it worked, but now having limewire made my sansa all maessed up and i cant fix it :(
Dec 20, 2007 | SanDisk Sansa e200 MP3 Player
E200 problem
Where is the music coming from? If you have lots of Bad Tracks errors, the music is usually encoded incorrectly and the device does not know how to decipher it. If the device still connects to the Computer, try to format it. My Computer, Right click on Device name (e200) and select format. I would also update the firmware. It is available from the SanDisk website. http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Best of Luck.
Sep 12, 2007 | SanDisk Sansa e200 MP3 Player
Can't delete songs from the e200
I had this same problem with my Sansa e280, I did some research and found that MTP mode is used when syncing with Windows Media Player.  So if you plugged in your player under MTP and simply tried to drag and drop using Windows Explorer the player won't recognize.  I have heard that you should be able to view them on the Sync tab in WMP but I personally have not tried.
The way I got rid of the songs was by going into my Sansa Settings and changing the USB mode to MSC, opening the Player by going to My Computer, then (if using Windows XP) click on Tools > Folder Options.  Click on the View tab and Select "Show Hidden Files and Folders".  Click "OK" Then Right click on the MUSIC Folder and Select "Properties"  Uncheck "Read Only" and "Hidden".  Unplug your Player and it will restart.  Viola, no more ghosted songs.
Apr 30, 2007 | SanDisk Sansa e200 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
87 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
