Question about Hotpoint Aquarius WMA42 Front Load Washer
Hi, my hotpoint aquarius wma42 washing machine washes ok but will not empty, i have took the filter out of the back and cleaned it, but its still doing it. can you advice
  • irenewilton Jan 16, 2009
    can you tell me how can i get the pump out to check for blockage
  • Hotpoint Master
  • 3,463 Answers
Make sure there is nothing stuck in the pump, and that the outlet hose is not blocked or kinked.
If o/k , then you need to confirm that the pump itself is working
Select drain only. or drain and spin, and you should be able to hear the pump running, if you are satisfied that there is no blockage any where and the pump is running, but no water comes out,
Then fit new pump
Plz rate my solution.
Thanks.
Posted on Jan 16, 2009
Where is filter on my hotpoint aquarius wmf540 washing machine, im getting white fluff over all my clothes everytime i put a wash on, im guessing the filter needs cleaning and just wondered where it is
http://laundry.manualsonline.com/manuals/mfg/hotpoint/wma58_wma56_wma54_wma52_wma50_wmm59_wmm53.html?idRes=599752
see last page.
also, you should try run a cycle without any clothes (add a bit of bleach) in it in cold water for once to rinse out the dirt.
Oct 02, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius extra 1000 spin washing but when spinning, clothes coming out still soaking wet. Help!
Check the machine filter, clean it and this problem might go away. Use manual for locating the filter.
Feb 28, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
The washing machine wont empty the water out and spin but the belt is ok
hi
you need to clean the filter that is in the exit
of the washers water
Jan 13, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine doesnt empty or final spin
You need to check the filter.
Remove lower rear cover of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Fit back and test.
Mar 12, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
WMA54 won't empty water? We've emptied filter but
Could be the pump, but they do not often fail.
I would check the main hose or the pump itself for a blockage.
Try blowing down the hose to see if it is clear.
Mar 03, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Water is coming out of powder draw everywhere and washing machine is not emptying propley
You need to clean the filter.
Remove lower rear panel of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean the plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Dec 21, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Machine full of water and towels. Spinning at same rate then stop
Check pump filter located at rear of washer, remove rear cover, locate and remove large black hose, remove and clean filter.
Please rate my solution.
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius extra filter
Normally in front of machine.Remove down plastic cover and then you see pump/filter,open and clean and make sure pump rotor is free to run.Jan
Feb 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius mwa42 will not empty
The pump itself should not be hot to touch, only warm, I would suggest a new one needs to be fitted.
Thanks.
Jan 16, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Aquarius wf541 model
The sypon tube needs cleaning, you need to poke it clear with something, the tube is part of the dispenser , thouroughly clean every part.
Sep 06, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
226 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
