Question about Bionaire BW2300 Window Mount Fan
How to set the temperature
Bionaire BW2300 Twin Window Fan with Remote Control hi. i have a Bionaire BW2300 Twin Window Fan with Remote Control. without setting the temperature i want to run the fan. because it stopped for 2 to 3 minutes interval or how to set the temperature properly, can u pls. help me regards raj
Look up this fan on amazon.com. In the comments/reviews a gentleman posted instructions for fixing the thermostat (it involves opening up the fan and repositioning the thermostat wire).
Posted on Aug 11, 2007
SOURCE:
I just want to know the wire color code for a bionaire window fan motor
Contact Bionaire directly and request the color code.
Aug 11, 2018 | Bionaire Dryers
Fan fuse location
i bought a bionaire fan today and was looking at the manual the fuse is located at the end of the cord where it plugs into wall you have to open the square piece holding the prongs there you will see it good luck
Jul 24, 2014 | Bionaire BW2300 Window Mount Fan
How to change remote control battery for a Bonaire heater
The remote for Bionaire® 20" Ceramic Mini-Tower Heater with LCD Control uses BUTTON cells (Disc type, 3 volt, CR2025)..
Open the remote as shown in page 4
http://demandware.edgesuite.net/aamb_prd/on/demandware.static/-/Sites-bionaire-ca-Library/default/dw869fb9a8/documents/instruction-manuals/BCH9208-CN_EN.pdf
Jan 12, 2014 | Bionaire BT200RCU Tower Fan
After cleaning the fan it won't power back up
wow... you must have got it really wet ! but if that is why it is not working now, then set it out in the sun for a few hours, or put it in front of another fan. hope this helps. post if it does. There are other problems it could be and I may be able to help with that as well. first things first. good luck. Tim
Sep 12, 2012 | Bionaire BW2300 Window Mount Fan
My Bionaire Tower fan is Switching the sitting by itself from 1 speed to 2 speed. is it a defect?
I don't think it is a defect, but you may want ot check with the store.
I have a similar one that starts at a higher speed and switches down to low after a few seconds.
After that I can select the running speed.
Mar 31, 2011 | Bionaire Tower Fan w/ Ionizer and Remote ...
I have a sony (model KP61V75) a split screen came on (two pictures) and I cannot figure out how to get it back to one screen. Im going crazy!
Some television remote controls have a PIP OFF button, while others only have a PIP button that needs to be pressed repeatedly until the PIP/Twin-View window disappears.
NOTES:
  • Some Sony rear projection televisions have a FLASH FOCUS button that will turn off the PIP/Twin-View feature.
  • Some Sony universal remote controls, if programmed to operate a Sony TV, can disable the PIP/Twin-View feature by pressing the REC or ENT button.
  • If the original TV remote control is not available or is not functioning properly, auto programming the television tuner orperforming a power reset may deactivate the PIP/Twin-View feature.
  • If pressing the appropriate buttons on the TV remote control does not work, then the PIP/Twin-View window might be from a two-tuner cable or satellite set-top box. If this is the case, use the remote control provided with the set-top box to remove the PIP/Twin-View window.
Jan 25, 2011 | Sony Televison & Video
Hi, I have a problem with bionair widow fan 2300, it´s the R1 RESISTOR, but the over heating erase the color code of the resitor, you can help me?...sorry for my english
There is a major problem with the fan's electronic board. There is most likely a shorted capacitor, or some sort of fried transistor somewhere. depending on your electronics know how, try troubleshooting the circuit starting with it's power supply/input. but depending on the price of the fan, and the amount of aggrivation, I would just get a new one. Remember, most of the newer appliances today are ment to only last a few years, then die. I don't care what it is. all the companies want to do is make them as cheaply as possible, so they can sell more of them, and make more money. so don't be surprised if you can't fix it. some things are just not fixable.
Aug 12, 2010 | Bionaire BW2300 Window Mount Fan
How to use a SUNBEAM twin window fan with
Intake brings the air outside into your room, exhaust pushes the air inside your room out.
What setting you use depends on your personal taste of temperatures and the temperature inside vs outside. If you set the thermostat to 72 degrees and it is more than that outside then I would use the exhaust setting. If you set it to 72 degrees, and it is 68 outside but 84 inside then I would set it onto intake to cool the inside air.
Jun 21, 2009 | Dryers
Not right
The controler electronics are probably failing, or the motors are starting to pull too much current. Get in contact with Bionaire to find out who their local service is in your area for parts and repairs.
Jerry G.
May 27, 2008 | Bionaire BW2300 Window Mount Fan
Bionaire BW2300 Window Mount Fan Logo
598 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Kardoc
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
