Question about Novelty Manufacturing Polyconcept USA Novelty SOSL MK4 Field Phone
S.O.L. Mark IV corded phone
Dead Will no dial tone no ring. I put new batteries in it and clock doesn't run eather
I found and replaced a fuse on the pone line input board.
Posted on Jan 21, 2009
I have a panasonic cordless phone modle # KX-TGDA20. The phone has no dial tone. It is on mute and I can't get it off. I have unpluged the phone but no change.
See itf you can find someone who can try a different phone on that phone cord.
It may be a bad battery, or the phone line may be dead.
That is why I suggested you try another phone to see if a dial tone will come through that one.
If you get that dial tone on another phone, then suspicion a bad battery or battery charger.
God bless your efforts.
Apr 11, 2017 | Panasonic Lands Phones
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Lands Phones
Plantronics ct12 phone no dial tone
It is possible that the replacement battery is no good or was installed incorrectly.
Dec 29, 2013 | Plantronics CT 12 Cordless Phone (CT12)
Dialtone but no ring only beep
Sounds like its either going offline maybe checking the outlet and the cord that plugs into the base. It may also be the battery needs replacing,it has been run down and charged again too many times.it may hold enough for a dial tone but not enuff to even ring,just beep I stead
Jul 01, 2013 | Lands Phones
Merlin BIS-10 no dial tone and can't answer but phone rings
I have a dial tone but can not make calls. and if the phone ring they can hear me but I cannot hear them
Apr 01, 2013 | Avaya MLS 12D Corded Phone
Line one wont ring
Call a tech in, name change will not harm a line period.
Oct 09, 2012 | NorStar T7316E Corded Phone
We cannot get a dial tone on all three of our phones. We tried unplugging them from the wall, taking out the battery and waiting 4 minutes then putting back the power source and putting in the batteries...
Have you tried a corded phone that does not have any batteries? Unplug all phones and try a phone with no batteries one jack at a time.See if you get dial tone on the phone with no batteries.
Jan 11, 2011 | Lands Phones
How do I program different ring tones for the KX T7220. THere are 6 to choose from I believe.
1 Press program key
2 Dial 99
3 Press line key or intercom key twice
4 Dial 1-8 for tone type
5 Phone will ring with new tone
6 Press store button(autodial)
7 Press program key to end
Dec 07, 2010 | Panasonic KX T7220 Corded Phone
My fourth line doesnt ring and doesnt show a dial tone....
Issue with your Line...Cherk wire phone line for bad connection from the wall to the unit .... Check for Power Corde .... try normal phome on avery single line check for tone ...If you do have tone reset your phone on default ...then re-program it Check also for backup Battery it a little rond Battery 3volts that preserve your memory in your phone ....
Sep 28, 2010 | Avaya Corded Phone avaparp18d
The phone is not ringing and it is plug on charge and my wife got new battery for it too. What can i do to get it working? What size of Batteries cani use for this cordless phone
You need the specific battery pack: 5-2814 for the handset. This is a 850 mAh Nickel Metal hydride battery.
When I see a cordless phone that doesn't ring, the first thing I recommend checking is the phone jack and line itself with a second phone. I prefer to use a corded handset with a new phone cord to check for dial tone. If no dial tone at the jack, check for dial tone at the service entry box. If you have no dial tone at the service box, contact your provider. If it's only a problem at the jack, you will need to check your inside wiring.
To check the base, try a new cable (RJ-11) (double check the power as well).
To check the handset, first make sure the handset is fully charged (16 hours) and that the battery is fully installed. Does the handset beep when the Talk button is pressed? Next check that the handset ringer software is on. With the phone off (not in the talk mode), press the Mute/menu OK button. Use the Caller ID/volume (up/down) buttons to get to the Handset setup menu. Press the Mute/Menu OK button to access the menu. Use these buttons to check the Ringer Volume (should be on) and Ringer Tone. Press Mute/Menu OK to save the settings at each sub-menu. Check that the Do Not Disturb function is not on - this toggles with the Do Not Disturb button and should be noted on the handset screen when on.
If you have multiple extensions on the phone line, try unplugging some of them.
I hope this helps.
Jul 07, 2010 | GE T28821FE2 19 GHz Twin 1Line Cordless...
Novelty Manufacturing Polyconcept USA Novelty SOSL MK4 Field Phone Logo
187 people viewed this question
Top Novelty Manufacturing Lands Phones Experts
Are you a Novelty Manufacturing Lands Phone Expert? Answer questions, earn points and help others
