Question about Brother HL 1430 Laser Printer
Error 50 I shut the printer off by disconnecting the power cord for several hours. Then I repluged it. Error 50 code returned. I checked to see if any paper was stuck somewhere in the printer. There was none.
    Scholar:
  • 35 Answers
Error 50 is a fuser unit fault code. You can take apart the fuser unit and see if the fuser lamp is functional. Also check some of the other thermal parts on the fuser. If everything checks out, you will probably have to replace the thermistor. You will need to see if it will be cost effective to replace the necessary parts (Brother parts are not cheap), or to buy a new printer. Hope this helps. Good luck.
Posted on Jun 21, 2007
Hp officejet pro 8500 error messages
This seems to be Hardware issue. However we can give it a try.
Disconnect the power cord from back of the printer ( Do not turn off power ). Hold the Power and Cancel button and connect the cord and release the buttons after 2-3 seconds
Regards,
Sean
Apr 22, 2013 | HP Office Equipment & Supplies
Canon Pixma MP530 multifunction printer
HI,
1.Power off the printer
2, Unplug the printer's power cord, wait 5 seconds then replug the power cord in.
3, Hold the Power button for 6 Beeps
4, Release the Power Button
Sep 15, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon mx310 error message 5b00
If the device is not functioning properly or to clear memory, reset it. important.gif Important: If resetting the printer's power does not clear the error or return the machine to a functioning state, it may be necessary to attempt a service reset. for instructions to attempt a service reset.
  1. On the operator panel, press and hold the button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Service Reset:
  1. On the operator panel, press and hold the button for one second to power off the printer. (The display will go blank.)
  2. Confirm the printer is not on and then unplug the power cord from the back of the printer.
    If the power cord was disconnected (as stated in step 1) in order to shut off the printer, go to step 3.
  3. Press the button repeatedly five times.
  4. Re-connect the power cord.
  5. Press the button to power the printer back on.
  6. Wait until the device has completed its cycling process before submitting another job request.
    • This procedure will not resolve a physical hardware issue.
      For example, a paper clip is wedged between the paper feed rollers or gears; or, the scanner assembly is detached from the inside housing.
    • This procedure will not resolve all service errors or LCD related anomalies.
      Service errors appear as four characters (a combination of alpha and numeric codes).
Aug 27, 2011 | Canon PIXMA MX310 All-In-One Printer
HOW i get engine code for t522..i have engine code/900 rip error??? \r\nMy email address is Heikki.Rossi@huoltoverkko.com
The 900 error usually indicates a software or communications problem. The first thing to check is the base printer.
  • Turn off the printer and disconnect every cable, except for the power cord.
  • Turn on the printer and see if the error returns.
  • If the error does not return, try to print a test page from the Test Menu.
  • If the test page prints correctly, the printer
Jun 05, 2011 | Lexmark T522 Laser Printer
Error Code 9000 on my mp600
its worth trying this aswell:
1, Power off the printer
This will reset the printer and should resolve incorrect cartridge detection problems
Error Code 9000
The USB Host VBUS is overloaded.
Replace Logic board
Feb 24, 2011 | Canon PIXMA MP600 all-In-One InkJet...
50" plasma panasonic 720p tv has several colored
Flashing error codes could be the Direct tv box itself.Because tvs have problems within itself don't flashes error codes on the tv screen,the problems,just show up.Tries tv and Direct tv satellite box unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting and the Direct tv box updates it softwares data's.The problems should be solved,if have the same problems,first call Direct tv for a replacement box,see how it work out.Than turn ur attention to the tv.
Feb 08, 2011 | Panasonic TC-P50X1 50 in. Plasma HDTV
Printer does not power up.....
check out the power cord or replace the power cord with new one
Nov 27, 2009 | Office Equipment & Supplies
Print error code 50 on a brother dcp-330c
Error code #50 refers to a paper jam. Although you may not see any paper in the feed channel/chute, there is either a small fragment of paper or dust interfering with your machine's ability to feed. A good way to ensure there's no blockage is to blow it out with compressed air including the rear panel where dust/dirt tends to hide. Short of that, you can try to reset the error code by disconnecting all cords (including power cord) for 10 minutes or so and upon reconnecting, the fault should clear but keep in mind, if there is an obstruction, the error will return. Hope this clarifies you error message. Best of luck!
Greg
Nov 08, 2009 | Brother DCP-330C All-In-One InkJet Printer
Km-2030 Checksum error f1
my copier is displaying error code 100, whats the problem km 2030
Jan 21, 2009 | Kyocera FS-2000D Laser Printer
Brother HL 1430 Laser Printer Logo
650 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
