Question about Panasonic NN-H264 Microwave Oven
Microwave stopped working while cooking. Is there a fuse?
Where is the fuse located for the over the range microwave oven models nn-h264/s254. The microwave is not working. It is plugged in and the outlet that it is on is working. Wondering if there is a fuse somewhere on the microwave that may be blown.
  • krosebud72 Jan 16, 2009
    Thank you for the info. We will give this a try.
    Have a great day!
If unit is built-in reove screws holding unit to cabinet.
Slide out about 2 inches to access 3 screws holding grill.
Remove grill to get to two screws holding control panel.
Fuse is behind control panel,
Posted on Mar 17, 2009
    President:
  • 1,214 Answers
If the display is not working, there is a fuse inside the cabinet. You will need to take the unit down from the wall and open it up.
Chances are, either the controller board has failed, or something having to do with the magnetron, transformer, diode or capacitor (the microwave circuit.). More likely it's the controller, as when the microwave circuit fails, the display usually continues to display.
ALWAYS REPLACE THE FUSE WITH A FUSE OF THE SAME RATING!
Posted on Jan 16, 2009
Discussion on the appearance, aesthetics, form and colur
Hello dutch.
This is an excellent microwave, over the range, white only. Here is a link to all of the features, and even the owner manual http://www2.panasonic.com/consumer-electronics/support/Home-Appliances/Microwave-Ovens/Over-the-Range-Microwaves/Technical-Specification/model.NN-S254WF.T#ts
Microwave Type: Over-the-Range Cooking Power: 1200 Watts Capacity: 2 cu. ft. Convection Cook: Without Convection Cook Dimensions Exterior Depth: 15 in. Exterior Height: 9.5 in. Exterior Width: 23.25 in. Miscellaneous Product ID: 22541798 More Information Details: Over the Range Microwave with Panasonic Inverter Technology provides true multiple power levels. When the user asks for 60% power, the oven delivers a true 60% power, not a pulsed delivery of 100% power 60% of the time. This method is called linear power delivery
Dec 08, 2010 | Panasonic NN-S254WF Microwave Oven
My model is nn-s253wf, micowave stopped working, no power, checked circuit breaker, is ok ?, unplugged, then plugged back in, still no power ?
Inside the external case and usually to the right left ( from Front) in some models There is a 30 amp fuse ( This may vatry on oven output amperage) Replace that and you should be back in cook mode.
Removing the case you should remember to disconnect from the power plug.
Please rate my help++++Thanks for using FIXYA
May 29, 2010 | Panasonic NN-S252WF Microwave Oven
My NN-S254 Microwave comes on intermittently, mostly dead
Try cleaning (pull the power cord plug first) the inner side of the sheet metal waveguide which may have a layer of grease that could short out the microwaves. This waveguide runs from the magnetron base over to the cooking cavity and usually can be removed by undoing some sheet metal screws along it's length. There is a fan-like device called a 'stirrer' that is located near the cavity opening under the wave guide and it should be cleaned also along with the cavity entry window. Hope this helps!
Nov 11, 2009 | Panasonic NN-S254BF Microwave Oven
Panasonic microwave oven
Microwave fuses are normally located either on a filter board near where the power cord comes in, behind the control panel between the door switches, or behind the control panel in a hodler, sometimes on the floor of the chassis.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find an authorized Panasonic servicer here.
You can order Panasonic parts from Tritronics, but if you don't find what you're looking for there, try here.
Nov 04, 2008 | Panasonic NN-H264 Microwave Oven
I have a panasonic range microwave oven model NN-H264/S254 clock cannot be set. (It use to work but no longer can be set)
Sounds like you disabled the clock function. If you do not have the user manual, you can get a copy at this website and use the function keys to reactivate and set the clock...
http://safemanuals.com/user-guide-instructions-owner-manual/PANASONIC/NN-H264-_E
I belive the information you seek is on page 12 of the manual.
Hope that helps...
Aug 13, 2008 | Panasonic Microwave Ovens
Panasonic microwave does not heat , but the rest seem's to work?
High voltage parts are suspect. Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there) Should be getting 120Vac when it goes to cook cycle. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing either the magnatron or the high-voltage capacitor and diode. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Jan 25, 2008 | Panasonic NN-H264 Microwave Oven
Panasonic NN-2501 Microwave Oven range hood
It is possible that the magnatron is bad but hard to say on a no heat problem without checking all components. A lot of model give 5-7 yr warranty on that part.
Oct 05, 2007 | Panasonic NN-S251 Microwave Oven
Modelnn-h264/s254 1100 watts
This door screen as it's called protects the metal mesh screen from moisture and food debris. The door screen must be replaced or the mesh screen can arc and be damaged, which can lead to microwave leakage. You can order a new screen from Panasonic at: http://www.pasc.panasonic.com/Epartr/PartsListChoice.asp It may be this part: F31455H00AP DOOR SCREEN A 5.75 But it might be better to call Panasonic at 800-833-9626 and be sure this is the right part. Be sure to have your FULL model nuber (with suffix) when you call. Be sure to use a cleaner like acetone, etc. to remove all the old adhesive before applying the ne wone, or it will not stick. The door must be squeaky clean and dry.
Sep 21, 2007 | Panasonic NN-H264 Microwave Oven
Panasonic NN-H264 Microwave Oven Logo
1,710 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
