Question about Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens
Camera not recognized by computer
I keep getting a "no camera found" message when my Canon EOS 300 is plugged up to the computer and selecting the download images Tab from the Zoombrowser Ex window.It has worked in the past but now will not respond.It acts like something is locked on the camera but have not discovered anything.The USB cord works with a different camera,so I've ruled it out.Any suggestions would be appreciated..Thanks.
I'm no expert on technical matters but I'd try the following: - make sure the camera is switched on and not in play mode. - are you sure it's the same USB cord for that camera? (there may be subtle differences which means it cannot read the EOS 300). just a thought. - makes sure it's in the right USB port. I think a specific USB port is assigned when you install Zoombrowser - invest in a card reader. They're not that expensive, quicker to upload photos and preserve camera battery life. Quite a few photographers recommend using these. I've got a Lexar multi-card reader which only cost £15 and I've had no probs with it. And since it can read various cards it doesn't matter which camera you use. Hope that helps.
Posted on Jun 19, 2007
SOURCE:
Computer doesn't recognize Canon EOS Rebel when it's plugged in
Having gone over a month with no response, I assume this is no longer a problem.<!-- from fixya rte -->
Jul 05, 2010 | Canon Rebel XT / EOS 350D Digital Camera
I attached the Canon EOS30D to new computer before loading the EOS Utility. Now I get the message Camera not recognized when I attach to down load photos. Can I fix this?
When you installed the utility is not an issue...it doesn't matter. Microsoft updates often prevents some hardware such as your camera from being recognized. Why not use a separate card reader to download your pics?...works every time.
Jan 03, 2010 | Canon EOS 30D Body Only Digital Camera
Canon Rebel XTi not recognized when plugged into usb
Vista is your problem. Solution...buy an inexpensive card reader to download your pics to a folder you create on your desktop. From there, you can send the pics to your photo editing software.
Oct 23, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Computer don't recognize the Canon EOS XSi
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jul 21, 2009 | Canon EOS Rebel XSi Digital Camera
LAPTOP WILL NOT RECOGNIZE CAMERA
a card reared is a device that reads memory cards!
you can remove the card from your camera and plug it into a card reader and plug that into your computer
and example of a card reader image can be found here:
http://www.wwu.edu/techcenter/resources/images/-CardReader-3D.jpg
you can get at any computer or camera shop.
hope this helps
May 07, 2009 | Canon Rebel XT / EOS 350D Digital Camera
EOS Utility does not Recoganize Camera
I am not sure about this matter but it seems there is a problem with your new computer. it might not recognize the usb cable.
try to plug your camera in another USB port and try again.
Jul 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Unable to download photos from Canon 350D
when downloading from my EOS 350D I get the message
'Camera launcher exe has stopped working'
I have Vista Home Edition
I am getting desperate to find a solution!!
Dec 08, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Canon Digital Rebel / EOS-300D Digital Camera with EF-S 18-55mm Lens Logo
168 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
