Question about Logitech Quickcam Chat Webcam
I get this window when using the logitech quickcam: Error code = 0x80004005
    Genius:
  • Logitech Master
  • 1,102 Answers
You get this error when an antivirus or back up utility interfere
you can try and uninstall your program then reinstall
Posted on Jan 16, 2009
3 Suggested Answers
dante777
  • 623 Answers
SOURCE: can someone help me fix this
Using a Webcam like Logitech QuickCam® Messenger onWindows Vista, Internet Explorer 7 sometimes an error such as0x80004005 / 0x80040606 appears.
Try this workaround and disable UAC.
Goto Start Menu > Start Search > type: "msconfig" >
Tools Menu > Disable UAC > Launch > Apply > OK > Restart.
In general though - you should not have to disable this security featureof Vista in order to install and operate the Logitech software.
If this workaround works, then it is a flaw in the program and you should contact Logitech customer support directly.
Sorry for not having "the" solution on hand, but I've seen many people having that problem. Some changed to a prgram called "splitcam" becuase they were tired of Logitech's sloppy software.
yooperbud
  • 8637 Answers
SOURCE: Can you help me solve this problem
Normal 0 Probably has corrupt driver.
Try disconnecting the Camera from the USB port and reinstall the software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web do this.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype (http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/ ) set it up as follows:
  1. Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if Installed Properly will come up and show a video picture.
  4. Then, on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now be able to see and her to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger (http://www.soft32.com/download_30.html ) set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 31, 2009
ERROR CODE 0X80004005 WITH VISTA 64 BIT ..ONLY GET THE CODE IF I TRY TO USE THE SHADE...LIVE BROADCASTING IS FINE. TALKED WITH LOGITECH..THEY HAVE NO CLUE WHY IT'S NOT WORKING
Quick Cam 9000 Error code 0x80004005
I was able to get it to work both by itself and with other software on my (HP Media Center Win 7) by lowering the image quality to 640 x 480 VGA.
Apr 03, 2009 | Logitech QuickCam Pro 9000 Web Cam
Problem in Installing Logitech QuickCam Connet to MAC OS. Previously I was using QuickCam Family.. it was working fine. Anyone can tell me from where I can get softwafe for this which is MAC compatible, As...
Problem in Installing Logitech QuickCam Connet to MAC OS. Previously I was using QuickCam Family.. it was working fine. Anyone can tell me from where I can get softwafe for this which is MAC compatible, As Logitech Site has only for Windows.
Feb 28, 2009 | Logitech QuickCam Connect Webcam
Can someone help me fix this
Jan 16, 2009 | Logitech Quickcam Chat Webcam
Cant record video-- keep getting error code
Never mind--- Just needed to restart the computer-- works fine now!
Sep 29, 2008 | Logitech Quickcam Chat Webcam
Microphone not recognized
I have a new HP with Vista and the camera works, but not the sound. Plus, I can't seem to get it to show on MSN Messenger.
Jun 10, 2008 | Logitech QuickCam Pro 9000 Web Cam
Code error 0x80040606
Can you try the following to see if it works? 1st, Make sure QuickCam Version 11.0.0.1218 is installed. 2nd, Make a copy of the "C:\Program Files\Common Files\LogiShrd" to "C:\Program Files\Common Files\Logitech". After you make a copy of this folder, under C:\Program Files\Common Files you should see both a "LogiShrd" and a "Logitech" folder. Both folders should have the same content under them (ie. "LVMVFM" directory, "KAudP" directory, etc...) 3rd, Uninstall Logitech QuickCam Version 11.0.0.1218, and the QuickCam Drivers in Add/Remove programs. 4th, Reboot. 5th, Reinstall 11.0.0.1218 See if this works... Also, an alternative: instead of "uninstalling" Logitech QuickCam version 11.0.0.1218 in Step 3 above, you can try "Repairing" it from Add/Remove, and do not uninstall the drivers. Background: Working with a forum poster, we found a problem with a path-resolution function that maybe triggered by a Windows Update. Basically, it seems a Windows Update is added some extra folder attributes that causes the path resolution function to fail. When the path resolution failed, the code was set to failsafe to a "Logitech" directory instead of "LogiShrd" directory. This would also explain why these problems don't happen 100% of the time (because it seems the path resolution function doesn't fail 100% of the time) and the errors started appearing in 10.5 and above, when the Logitech folder was renamed to LogiShrd. Hope this helps!
Apr 07, 2008 | Logitech QuickCam Pro 5000 Webcam
Problem installing
During the upgrade installation to QuickCam 11.5 the installer will hault and display error code 2738.
Solution
Windows XP user:
  1. Please visit the Microsoft website and download Window Scrip 5.6.
  2. After installing Windows Scrip 5.6, please reinstall QuickCam11.5.
Windows Vista Users:
  1. Click on Start Button
  2. Click on All Programs
  3. Click on Accessories
  4. Right click on the Command Prompt, select "run as administrator"
  5. At the prompt type "regsvr32 vbscript.dll"
  6. You will now get a message box saying "vbscript.dll" has been registered
  7. Reinstall QuickCam 11.5
This resolve the problem.
Sergio
Mar 11, 2008 | Logitech QuickCam Communicate STX Personal...
I can't get my logitech quickcam chat to instal...
Which cameras are compatible with MSN 6.0?
Below is a list of cameras that are compatible with MSN 6.0:
ClickSmart™ 820
ClickSmart™ 420
QuickCam® Cordless
QuickCam® Messenger
QuickCam® for Notebooks Pro
QuickCam® Pro 4000
QuickCam® Zoom
ClickSmart™ 510
QuickCam® Traveler
QuickCam® Web
ClickSmart™ 310
QuickCam® Express
What are the Minimum System Requirements?
The minimum system requirements for MSN 6.0 are the following:
  • 233MHz processor or faster (500MHz recommended)
  • Microsoft Windows 98, Windows 2000, Windows ME, or Windows XP operating system
  • Minimum 64MB of RAM (128MB recommended)
  • Up to 50MB of hard disk space needed to install — after install, up to 15MB may be needed
  • 256-color VGA or higher resolution graphics card (SVGA recommended)
  • Minimum 800x600 screen resolution
  • Microsoft® Internet Explorer version 5.01 or later must be installed on your computer, though it does not need to be your default browser
Note: If you are not sure if your computer meets these system requirements, please check with your computer manufacturer.
Where can I download MSN Messenger 6.0?
Click here to download MSN Messenger. Note: If you experience any problems downloading or installing MSN 6.0, please contact MSN for further support.
Mar 02, 2008 | Logitech QuickCam Chat Personal Web Camera
Quickcam
Error 2711
When receiving the 2711 error during Logitech QuickCam/Image Studio software installation, please perform the following steps:
  1. Use Add/Remove programs in the Control Panel to uninstall any current installation of QuickCam/ImageStudio software. For Microsoft Windows 95, 98, ME or NT
    1. Click Start, Settings, then Control Panel.
    2. Double click the icon labeled Add/Remove Programs.
    3. Highlight the desired program in the list provided (QuickCam or ImageStudio).
    4. Click Add/Remove Programs located in the bottom right of the list provided.
    For Microsoft Windows 2000 or XP
    1. Click Start. followed by Control Panel.
    4. Click the button labeled Remove located in the bottom right of the program selected.
  2. Navigate to C:\Program Files\Logitech.
    1. Double click the icon on the desktop labeled My Computer.
    2. Double click the icon labeled C:\(computer name).
    3. Double click the yellow folder labeled Program Files.
    4. Double click the yellow folder labeled Logitech.
  3. Delete any folders for QuickCam/ImageStudio.
    1. Select the yellow folder with the QuickCam or ImageStudio names.
    2. Click the menu options for File, followed by Delete.
    3. Repeat for any other QuickCam/ImageStudio folders.
  4. Delete all files located in the Windows temporary directory C:\Windows\Temp or C:\WinNT\Temp
    3. Double click the yellow folder labeled Windows or WinNT.
    4. Double click the yellow folder labeled Temp.
    5. On the menu across the top of the window, click Edit followed by Select All.
    6. On the menu across the top of the window, click File followed by Delete.
    7. Click OK.
  5. Reinstall QuickCam/ImageStudio
    1. Remove and reinsert the QuickCam/ImageStudio CD and follow the prompts OR
    2. Double click on the downloaded ImagStudio file.
Dec 27, 2007 | Logitech QuickCam Express Web Camera
Logitech Quickcam Pro 5000 Video Effect Error Code= 0x080040606
If you're like me, and you have "thinned" out your Windows, or used any of those programs to "speed up" your computer, make sure "terminal" is enabled in your services. For some reason, this wont allow video effects to work. Very common problem. Good luck!
Dec 11, 2007 | Logitech QuickCam Pro 5000 Webcam
Logitech Quickcam Chat Webcam Logo
141 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
