Question about Asko W660
Trying to find asoap despenser tray for ASKO W660, ASKO parts replacement? web site or phone#?
Go to repairclinic.com
Posted on Mar 07, 2009
Controls don't work after ASKO W660 "fault indication overflow"
Check that water has not got into the very bottom of the machine. Many machines have a drip tray that will shut the machine down if water is present to reduce the risk of f
Nov 09, 2013 | Asko 24 in. D3120 Dishwasher
Door won't open. tried to turn it on and off.
Try a hard reset of the op system by unplugging the machine and waiting a few minutes then plugging it back in. If this does not work, your door lock mechanism may need to be replaced.
Dec 29, 2010 | Asko W660
Asko washing machine won't drain.
Further on to this F3 problem I had the issue on model W6461. There is a short cut to the fix, instead of taking off the grey pipe from the drain pump (the hose clips are pre crimped in the factory so as stated above are difficult to remove) try this.
Stages as follows:
1) Open drain pump door (bottom left of machine).
2) Remove black pipe and drain residual water.
3) Unscrew coin trap and remove, use a container to hold the water.
4) Leave the container underneath and make sure you have some towels ready (I didn't at the time)
5) Where the washing machine drain hose connects to the outlet or U bend connector remove this and expose the end.
6) Blow into the drain hose as hard as possible......hopefully the blockage will clear through back the coin trap.
Result:
A large lump of sludge, three of my 5 year olds small counter coins and about a litre of water.
Just ran the machine now and fault cleared.
Good luck
Jurgo
Apr 30, 2010 | Asko W660
My asko frontloader squeeks when the drum turns
It may be the seal needs to be greased (waterproof grease) where the drum shaft goes into the support bearings in the outer drum case--major tear-down! Check the front bearing for looseness or roughness while you are there. Make sure the motor drive belt is not causing the squeak first. Good luck!
Dec 16, 2009 | Asko W660
Asko front load washing machine
The door lock mechanism. You have to quote your model and number while ordering.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Mar 31, 2009 | Asko W660
ASKO w660 Parts
lick on this link and contact the parts warehouse they will be able to help you. http://www.askousa.com/buy-asko/contact-us/
Jan 16, 2009 | Asko W660
Asko D1706
I live in Australia, My one had the same problem, I found them in e-Bay.
Jul 06, 2008 | Asko D1706 Built-in Dishwasher
Washing Machines Logo
70 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
