Question about E-Machines eMachines Desktop PC
Computer turns on, but nothing happens
I can turn the computer on, but the monitor only flashes self-test. Do you think I need a boot disk to get it started, and if I do, where can I get one? Thanks
  • jim730 Jan 19, 2009
    Thanks. I can get another video card to try.
  • BillW50 May 11, 2010
    Only if the screen asks you to insert a bootable disc.
    Some bootable CDs include:
    BartPE (Windows)
    Ubuntu Live (Linux)
    Puppy Linux (Linux)
    All of the above, you will need to create CD on a running systems. You can Google any of the above and go from there.
  • 72 Answers
Looks like you have a bad video card try to reseat the video cable to see it that helps if not tri a new video card.
Posted on Jan 16, 2009
How to reformat r430 samsung
Steps to reformat:
1. If you do not already have the Operating System (OS) software, download and burn it to a cd or make a flash drive bootable.
2. Put in the disk or plug in the flash drive and Turn off the computer.
3. Turn on the computer, and as soon as you see the samsung logo, Press Delete (around 3-5 times). And you should get to the BIOS screen.
4. In the bios, look for startup/boot options and set the first boot device to CDROM or if booting from a flash drive choose Removable Disk.
5. Save and quit the bios and the computer will reboot.
6. Once the computer passes the Power On Self Test (POST), it will automatically check for the first boot device (CD or Removable). If found, it will prompt you to boot from the boot disk. Press any key or Y for yes.
7. Follow the prompts from there.
NOTE: It is usually best practice to do a clean install removing any prior data from the hard drive.
Mar 03, 2014 | Computers & Internet
My monitor is blank and the light flashes green and amber. i've tried checking the plugs, all is plugged in ok... driving me crazy
Verify monitor operation by UNplugging it from the computer and turning it on. A "Self Test Screen" shall appear (if it doesn't, the monitor is faulty and must be repaired).
Assuming it worked, plug it again and turn it on. After half a minute or so, turn the computer on. You should be able to see at least the BIOS POST screen: if you don't, there could be something wrong in the computer video board (maybe misconfigured, or set to output to a different, possibly internal, head - I saw it once with a Matrox VGA). Refer to the VGA manual for that.
If the POST screen appears, the problem is perforce in the OS VGA configuration. Assuming it's Windows, you can get into the safe mode boot screen by pressing the F8 key at boot, and once booted, access the video resolution configuration from the Control Panel. Set it back to something surely working, in your case 1024x768, and work it up from there.
Oct 30, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Tower turns on fan runs lights on BUT NOTHING >>>>>>>
If the CD drive door won't open, odds are that at least you know the drive is without power. Have you had the case opened up at all? With what you've described here your computer needs the tender, loving care of a technician.
Sep 20, 2009 | 3G Technology GM-171B 17" Flat Panel LCD...
Monitor won't start when I boot up - without a lot of fiddling!
First try to do monitor self test.Disconnected the blue cable VGA or white colour connector from monitor to the computer. Turn on the monitor and check if you are able to see colours or line on the monitor.Indicating self test monitor is working fine. If you are using Video card on computer connect monitor directly to onboard video and check. Good Luck.
Aug 19, 2009 | Computers & Internet
I had a similar problem with a Dell Computer. It turned out to be a bad memory card. If you have more than one memory card in the machine, take all of them out except for one. If that does not solve the problem, try swapping memory cards.
Jan 16, 2009 | E-Machines eMachines Desktop PC
Flat Panel Monitor: 1907FPt
Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of computer.
  3. Turn on the monitor.
    The floating 'Dell Self-test Feature Check' dialog box should appear on-screen on a black background if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green. Also, depending upon the selected input, one of the dialogs shown below will continuously scroll through the screen.
    1. This box also appears during normal system operation if the video cable becomes disconnected or damaged.
    2. Turn off your monitor and reconnect the video cable, then turn on both your computer and the monitor.
    If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jun 04, 2017 | Dell E173FPb 17" TFT LCD Monitor
Installing Acer monitor to run with Dell Desktop
Unrelated to monitor, you have a hard drive problem or you have a flash or a floppy drive plugged in and it is tryint to boot off one of them
Dec 07, 2008 | Acer 22" X223w LCD Monitor
Laptop monitor goes black
If you're working on the computer when that happens, it's not probably a power setting. Try to update your BIOS to the most current version at the toshiba support website (support.toshiba.com) & see what happens. Fixes the issue most of the time
I hope this helps.
Aug 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
No signal on first boot
I think is a power supply problem,,
Mar 10, 2008 | Nokia 445 Pro 21" CRT Monitor
Dell P1110
Hi, The part where you see some color bars and blinking green led is what we call MONITOR SELF TEST. A diagnostic pattern consisting of four colors (red, green, blue and white) appears, and the LED flashes slowly. this happens when signal cable from the monitor is disconnected from the tower and leaving the power chord for the monitor plugged in. If the monitor works properly on a different computer. then its a problem with the computer's video card sending out signal. im 85% sure that its a problem with your video card.
Oct 02, 2007 | Dell UltraScan P1110 21" CRT Monitor
E-Machines eMachines Desktop PC Logo
64 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
