Question about Asko W660
ASKO w660 Parts
Where can I get a new soap despenser tray for an ASKO W660 washing machine
  • 333 Answers
Lick on this link and contact the parts warehouse they will be able to help you. http://www.askousa.com/buy-asko/contact-us/
Posted on Jan 16, 2009
Asko washing machine w660 "Temperature stop failure"
DOES THIS MODEL WASHER ACTUALLY HEAT THE WATER? OR JUST ALLOWS A CERTAIN AMOUNT OF HOT WATER TO BE RELEASED OR MIXED WITH COLD WATER? U CAN CHECK THE SWITCH WITH A MULTI METER FOR OHMS OR CONTINUITY NO NEED FOR A TECH GUY
Jan 10, 2014 | Asko Washing Machines
Door won't open. tried to turn it on and off.
Try a hard reset of the op system by unplugging the machine and waiting a few minutes then plugging it back in. If this does not work, your door lock mechanism may need to be replaced.
Dec 29, 2010 | Asko W660
My asko frontloader squeeks when the drum turns
It may be the seal needs to be greased (waterproof grease) where the drum shaft goes into the support bearings in the outer drum case--major tear-down! Check the front bearing for looseness or roughness while you are there. Make sure the motor drive belt is not causing the squeak first. Good luck!
Dec 16, 2009 | Asko W660
Washer 660, water dose no stop, and runs out of the machine?
Try pressing P1 five times and then press the door button (with the key symbol). This resets the rinse sensor. If it overfills again, you probably have a bad cpu.
Apr 05, 2009 | Asko W660
Asko front load washing machine
The door lock mechanism. You have to quote your model and number while ordering.
Sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Mar 31, 2009 | Asko W660
Asko W660 Quattro Front Load Washer - WATER INLET FAULT. Checked the troubleshooting guide, which recommends disconnecting the hose and cleaning the strainer in the water inlet of the machine. WHERE IS THE...
check the inlet valve solenoid there are three of them one might be o/c,also using to much soap can cause this or a coin stuck in the sump hose near the pump.the filter is in the valve but normally isnt the problem
Aug 28, 2008 | Asko Washing Machines
Washing Machines Logo
468 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
