Question about Dell Dimension 3000 PC Desktop
Blank screen when computer is turned on
My dell dimension 3000 has a blank screen when the computer is turned on. When first turned on it will show the dell logo and the windows logo but then after that only shows a blank screen with the pointer of the mouse on it. How can I fix the problem so that I am able to use my computer again. I would like to be able to keep everything that is already on the computer. Thanks!!
  • 5 more comments
  • julie_christ Jan 16, 2009
    Ok that didn't work either. When I done that it shows safe mode in the left and right hand lower corners and it's doing nothing. Nothing happened to the computer as far as power outage or anything. Is it true that windows automatic updates were causing viruses on computers??
    Do you have any other suggestions?? I have a disk to reboot the computer but it doesn't do anything when I put it in the hard drive.
  • BillW50 May 11, 2010
    Well you can try going back to the menu (that you can select safe mode with F8) and select last known good configuration. Hopefully that will work.
    No I don't believe it is true that Automatic updates installs viruses. Although it is possible that an update screwed something else up.
    That should be by repeatably pushing F8 just before and as Windows starts to load. If that doesn't work, try holding the CTRL key down. As either or should get you into the menu.
  • Dan rogers
    Dan rogers May 11, 2010
    push the button combination's before you see the loading page for windows
  • Dan rogers
    when windows is booting try to push shift F8 or F10 or ctrl F8 or F10 or something close. This should bring you to a list of options to boot. Boot into safe mode and update your drivers and re boot. If it is not the drivers you may have a hardware issue. Try this and get back to me
    Novelist:
    Champion:
  • 233 Answers
When you get the Dell splash screen press the F2 key to get into setup. Use the arrow keys to go down to Drive Configuration and press enter. Go down to Primary Master Drive and press enter. Is the Hard Drive listed there? If not, that is your problem. Press Escape then use arrows to go down to Memory Information and press Enter. Is all of your Memory listed? If not, that could be the problem. Press "esc" to get out of setup. If the Computer does not freeze while in setup I would suspect the Hard Drive is bad. Is the Pointer responding to Mouse movement or does it lock up? In your situation I would first try to Boot from the Windows CD. Write back and I can explain how to do this. If that does not work I would begin to test Hardware. Do you hear any Beeps when the unit is turned on? If you can, E-mail back with more Info.
Posted on Jan 17, 2009
I have a DELL imension 3000 that is showing a blank screen when booted up. I have ran an express diagnostic check and it has given me the following error: Error Code:0f00:136C IDE Device Failed: Blank...
1.If there's a cd or dvd in the cd/dvd drive, remove it and try booting again.
2.press DEL at the start up screen to go into BIOS. go into BIOS and change the boot sequence options, set it to boot from the hard drive.
May 22, 2011 | Dell Dimension 3000 PC Desktop
My Dell turns on. screen goes blank.
1st problem..... its a dell
2nd problem.....its winnders.
your software is corrupt or there is a hardware conflict.
Its like asking .........My car won't start...why not?
i
Nov 24, 2009 | Dell Dimension 3100 PC Desktop
My dell dimension 3000 goes to blank screen after it shows windows xp logo and seems to stop there, how do I fix this?
Have you tried starting in safe mood and then ran a scan of the hard drive, it could possably correct any file errors that the start up files may have Hope this Works Steve
Oct 01, 2009 | Dell Dimension 3000 PC Desktop
My hadr drives does not turn on or make any sound.
There are 4 small lights on the back of the PC and these will tell you what is wrong. You can find the code meanings here:
http://support.dell.com/support/edocs/systems/ws450/en/ug/advanced.htm
Let me know what you find - it sounds like a power supply issue.
Jon
Apr 13, 2009 | Dell Dimension 8400 PC Desktop
The screen went blank while the computer was on, we restarted it, the screen shows the Dell sign & the white bar then it goes blank, it won't go into safe mode, the light is green on the monitor, what...
If there is a faint image in the background it is the coils on the planar if no image it is either the invertor or the backlight
If you have a faint image resolder the coils or replace them
Dec 15, 2008 | Dell Dimension B110 PC Desktop
My screen goes blank immediately after initial DELL startup image
You can either try to reset the BIOS, or have the restore cd fix it for you. By the way, what does the message say?
Nov 27, 2008 | Dell Dimension B110 PC Desktop
Dell Dimension 3000 PC Desktop Logo
724 people viewed this question
Alun Cox
