My kodak 750 slide projector has a thin piece of sheet metal blocking the lamp so that nothing projects out the lenz. It looks like it is suppose to move somehow but I cant figure out how to get it out of the way. Can you help?
  • JDax Feb 03, 2009
    I have the same problem.  Help please???
    Problem Solver:
  • 6 Answers
Put a small drop of oil & see if that fixes the problem I hope this helps.
Posted on Feb 07, 2009
  • StevoT1 Feb 07, 2009
    Push the selector button sometimes it sticks I hope this helps.
I have a Kodak Ektagraphic with no model listed on it at all. How can I find a replacement bulb, all I can find look wrong.
Supplied with 82V, 300W EXR lamp Projection Lamps Quartz-halogen 82 V projection lamps- Here is service manual link http://resources.kodak.com/support/pdf/en/manuals/slideProj/manual/ektagraphic_sm.pdf Several different Models all say EXR 300W As CORRECT Bulb : EXR, 300 W (35-hour lamp life at full lamp/medium-brightness) Sampling of other lamps: EXY (200 hours/less brightness) EXW (15 hours/maximum brightness) FHS (70 hours/medium brightness) Use combinations of lamp brightness, plus half- and full-lamp settings to approximate image brightness in multi-projector presentations. Lamp Tips • Projector operation on line voltages above 125 volts greatly reduces the lamp life. • Unplug the projector before changing the lamp. • Allow for unrestricted flow of air to the exhaust vent to prolong lamp life. • Gently wipe off any fingerprints with a soft cloth moistened with rubbing alcohol.
Jun 27, 2016 | Kodak ATS Ektagraphic Slide Projector
Kodak carousel 760h projector
Yes, there is a fix. It's a pretty straight-forward adjustment. You can go to this web page: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-locale=en_US&pq-path=6499
The Service Manual there will detail the the adjustment.
Good Luck !! Jim
Mar 11, 2014 | Office Equipment & Supplies
Where can I get a spare heat shield for a Kodak S-AV 2055 projector? I think it is a heat shield - it fits between the two condenser lenses and is a square piece of thick glass in a metal mount. It...
Hi - If you are still looking for a heat filter, I have some spare ones of these in stock as I buy and sell these projectors on ebay. You can contact me on stevescarousels@btinternet.com.
Jul 31, 2013 | Kodak Carousel 4600 Slide Projector
Kodak carousel 600 slide projector thermal fuse replacement
If the FUSE is still available (this model could be as much as 50 years ago!!), the fuse is wired into the 120 volt circuit near the projection lamp. Check with: www.micro-tools.com
for availability. good Luck!! Jim
Feb 22, 2013 | Kodak Carousel 600 Slide Projector
I need a new bulb for a super 8 movie projector GE projection lamp 150W incandescent projection lamp
Be sure you have the specific 3-letter code from the burned out lamp, in addition to the model name/number of the projector. Armed with that, go to www.bulbman.com They have lamps for just about anything !! Good Luck!!
jim
Nov 15, 2011 | Kodak Office Equipment & Supplies
Plastic door/off w/4 screws removed, pushed/pulled the hinge bar and removed the metal door plate. 10Q for help. Now the lamps of modules (3) do not lite, fan works . No light Lo or Hi.
If the lamp modules do not light (assuming good lamps), then your problem has to be the lamp thermal fuse. The lamp thermal fuse is located on the back wall of the cavity when you remove the lamp module. It is a small, silverish cylinder with wires coming out of each end. It is held in place by a screw that can only be accessed by removing the bottom cover of the slide projector. Specific instructions can be found in the service manual posted on the Kodak website (search under "support" then "slide projectors"). Parts are no longer available from Kodak, but you can get most parts from: www.micro-tools.com
I hope this helps !!
Oct 24, 2011 | Kodak Carousel 5600 Slide Projector
AF-3 carousel, lamp on but light guard prevents picture
Based on your description, I suspect the coil spring that tensions the "dark shutter" has either broken or has popped off it's mount. To be absolutely sure, take your projector to a factory-trained repair dealer.
Feb 13, 2010 | Kodak Ektagraphic III E Plus Slide...
How do I open my Kodak Instamatic M70 projector?
I have a Kodak Instamatic M70 Super 8 movie projector. How can I stop the film from continously jumping? I have adjusted every nob and looked inside to find nothing out of the ordinary.
May 16, 2009 | BenQ (200NSH-LAMP) Projector Lamp for...
Kodak Slide Projector
sounds like the screen darking shutter is stuck up remove the lens and push it down with a screw driver sotf ly if it does not move go thru the open ing on the top of the unit and push down on the bar that operates the shutter
Sep 07, 2007 | Kodak ATS Ektagraphic Slide Projector
167 people viewed this question
jasbo
jasbo
