Kodak EasyShare V1003 Digital Camera Logo
Posted on Jan 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unable to install software on computer
When I attempt to install the program on my computer whiich has window 2000, I get the message " This version of Kodak easy share is not supported on your operating system" What does this mean?
Anonymous
Level 2:
Sergeant:
  • Expert 367 Answers
  • Posted on Jan 20, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
367
Questions
Helped
121838
Points
829
This means the software for the camera is not able to be installed on your computer. It was designed for a newer version of windows. Such as windows xp or vista.
CLick this link it should take you where you need to go for your version of windows. Just download the file pick your desktop and double click the icon once it is done downloading. Follow steps for installation
How to fix and repair a not valid win32 application?
Often this error message will be similar to the below error message.
C:\Program Files\myprogram\program.exe is not a valid Win32 application.
Cause
This issue can be caused by any of the below possibilities.
File is corrupt, bad, or missing.
File is not designed for your version of Windows.
File is a virus, worm, or other malware file.
Hardware incompatibility.
Answer
If the file or program you're attempting to run is corrupt or missing, Windows will be unable to execute the file properly and sometimes generate this error message.
Download files
If you downloaded this file and verified it is complete and compatible with your version of Windows, delete the file and try downloading and running it again. It's possible during the download that the file became corrupted.
Finally, if the second download does not work, try downloading the file from a different webpage. It is possible that the person or company maintaining the website mistakenly uploaded a corrupt version of the file you're attempting download.
Installing a program from a CD or other disk
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install or after the program has been installed because it was not copied properly onto the computer.
Running a program from the computer
If you're running the program from a shortcut on the computer, verify that the program is still on the computer. In some cases if the program is no longer installed on the computer you may get this error.
If the hard disk drive is corrupted or bad it can also cause working programs to fail either because not all the data can be read from the hard disk drive or because the program has become corrupted while on the drive. Run scandisk and defrag on the hard disk drive to check for any potential errors.
Long file name issue
Make sure the program or file you're attempting to run does not contain the same name as the long file name directory it is contained in. For example, executing a file named "program" in the "program files" directory can cause errors in some versions of Windows.
Additionally, if you're attempting to install a program and after the install the program does not work, you may also want to try installing the program in a different directory.
Bad file
Any file can be changed or renamed to be a .exe file. If you're downloading the file, make sure the file is supposed to be a .exe file and that it's not being changed. If you're attempting to create a .exe, file make sure you're compiling the file for Windows and never just rename a file to a .exe file. For example, renaming a .bat file to a .exe file will not make the file an executable file. For a file to become an executable file it needs to either be compiled or converted through a software program designed to convert the file.
If you're trying to run a program that is not designed for your version of Windows you may get this error. Although many older programs designed to work in older versions of Windows will work with new versions of Windows, unfortunately, not all programs will work.
If the program is an older MS-DOS program or early Windows program you may get this error.
If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
Getting old MS-DOS games to run in Windows.
This error can be generated by a file that is a virus, worm, Trojan, or other malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus or infected.
If the file has been checked and is clean, it is still possible that the virus protection program or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue.
If you're getting this error during the installation of a program it's also possible that the CD-ROM drive or the drive you're installing the program from is not compatible with Windows or has drivers that are not compatible with Windows.
Download the latest drivers for your CD drive or other drive through our drivers page.
Source : ( http://www.computerhope.com/issues/ch000726.htm)
I am running Windows XP Pro on a used home desktop I purchased about a year ago.It is a Dell computer/Pentium 4 CPU 2.80 G Hz/2.79 G Hz/512 Mb RAM. This computer is used by two other people in my home.My...
Try going to dll-files.com and download the necessary file. Copy that file to C:\Windows\System. Hopefully this works for you. If not, you could also reinstall Windows which will reinstall the necessary files.
I still can't download itunes 10. I have tried everything I think, uninstalled the old version, made sure I have admin access on this computer, tried downloading with different program other than int...
I presume you are either downloading the 64-bit version on a 32-bit Operating System, this message you are indicating usually only comes up when you are attempting to run a 64-bit program on a 32-bit OS, or you are installing the MAC version.
1helpful
2answers
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
1helpful
Not a valid Win32 application
Answer:File is corrupt, bad, or missing
Download files
If you're attempting to install a program and are getting this error, verify that the CD is clean. If the CD is dirty or bad, you could get this error during the install and/or get this error after the program has been installed because it was not copied properly onto the computer.
  • Additional information about cleaning a CD can be found on our cleaning page.
Bad file
  • If the program is an older MS-DOS program or early Windows program you may get this error.
  • If the program is designed for a 64-bit version of Windows and you're running it in a 32-bit version of Windows, it will not work and generate this error.
If you're attempting to run an older computer game in a new version of Windows, see document CH000587 for additional suggestions about getting older games to work in Windows.
This error can be generated by a file that is a virus, worm, trojan, or other type of malware file. Often, this will be caused because the virus scanner installed in the computer will not allow the file to be installed or run. Try scanning the file to verify it is not a virus and/or infected.
If the file has been checked and is clean, it is still possible that the virus protection program and/or another program installed on the computer is causing issues during the install or execution of the program. Boot the computer into Safe Mode and try running the program; booting the computer into Safe Mode will make sure nothing is running in the background that could be causing this issue. Additional information about Safe Mode can be found on document CHSAFE.
Unable to install , maybe my computer is too old.its etower 566 i2. any suggestions
There are a few reasons why a program will not install. I will try to help you resolve each.
1. Lack of privileges. Do you have local Administrator rights to install software? If not, can you login as the local Administrator to install the software?
2. Do you have the minimum Operating System requirements for the software? If you are running an old Operating System (Windows 95/98/2000/ME) then many new software programs will not install. If you are running at least WIndows XP or Vista, then you may need to install the latest service pack depending how new your utility software is.
3. On the flip side the Utility software may be too "old" for the Operating System! If this is possible, look on the web for a new version that is supported by your Operating System.
4. Do you have the minimum Hardware requirements? Do you have the minimum Memory/Disk Space for the software to install/operate?
5. Expired software. Is this software a time limited evaluation that is now expired? If so, this should be apparent when you attempt the install.
Use the above ideas to find the reason/solution to the problem you are having. :-)
Error Message 'F:\ setup.exe is not a valid win32 application'
  1. File is corrupt, bad, or missing.
  2. File is not designed for your version of Windows.
  3. File is a virus, worm, or other malware file.
  4. Hardware incompatibility.
Answer: File is corrupt, bad, or missing
Download files
Bad file
Unable to run Professor teaches Microsoft Office 2003 on Windows Vista
click start menu setting control panel. add or remove program. remove that software. then. insert the cd try to install again and. finish the setup process. then click startmenu programs. see thre your program icon wil appear. click on it start using it. if any error comes. send error message. thanks
2answers
Unable to install a new powerdvd version
I imagine that it's trying to uninstall the older version to install the newer one, which it can't. NOTE: This is a desperate step. Delete the Cyberlink folder in C:\Program Files\; Go to Add/Remove Programs and attempt uninstall - it will say it can't uninstall, and ask you if oyu want to remove it from the program list. Click yes. Go to start->Search (or Find) and search for Cyberlink (make sure that Hidden and System files are being searched). Delete all Cyberlink files. Do the same, but with PowerDVD. Download and run CCleaner. Attempt to reinstall PowerDVD.
What is an ISSET_SE error?
When you attempt to install the PhotoMAX software from your CD-ROM drive, you may receive the following error message: "ISSET_SE caused a general protection fault in module (FILENAME) at (ADDRESS) where (FILENAME) is the name of the program file you are trying to run, and (ADDRESS) is the memory address at which the error occurs." This is an error that can occur with Windows 95 and 98 under certain conditions -- it does not indicate an error with the PhotoMAX software. This (error message) can occur if any of the following conditions exists: * Norton AntiVirus version 4.04 is installed and Norton AutoProtect is enabled. * You use LiveUpdate for Norton AntiVirus to download an updated version of Norton AntiVirus. * Microsoft IntelliPoint software is installed on your computer, and the Point32 program is currently running. * Microsoft IntelliMouse or Microsoft IntelliMouse Trackball software is installed on your computer, and the Mswheel program is currently running.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
