Question about Canon PIXMA MP780 All-In-One InkJet Printer
"Wrong Cartridge" I suddenly started getting this error "Wrong Cartridge" on Pixma Mp780. I changed all of the cartridges (oem) but it has not helped. I am disabled on on a very limited income so I really need to know what the problem before I start spending a lot of money I don't have to fix it.
  • 2 more comments
  • Kathi Rohde Jun 19, 2007
    I cleaned the pins still says wrong cartridge
  • Kathi Rohde Jun 25, 2007
    I DID replace the print head, $100.00 later the error message remains the same
    I replaced the print head and put new oem cartridges in it and cleaned the pins as directed. I have reseated the print head and restarted the unit multiple times. The nearest authorized repair place is nearly 100 miles away from me and I am disabled, so I guess I will just have to throw it away.
  • Anonymous Mar 05, 2008
    Wrong cartridge message. I changed the cartridges but sill get the message
  • 624 Answers
There really aren?t but three options per Canon: -Reseating the print head -Replacing the print head -Press the ON/OFF switch to reset the device. Cleaning the pins as mentioned and trying new genuine Canon cartridges) are good to try as well; however, the next thing to check is if this printer is still covered by the warranty. If it?s less than one year old or if you?re not sure call Canon and see what they will do, it doesn?t cost anything except time. Everyone wants to save money on labor but the relatively small amount of money you?ll save you could easily loose by experimenting. I?m hoping you don?t flame me for this (I post to help, not make money) but a new print head is going to cost around $50 and might not even fix your problem. Unless you have access to a printer you can use for parts my suggestion is to not invest any money on buying parts unless you are absolutely sure the part will fix the problem. Instead I would suggest you have a local authorized shop take a look at it. Most will change a modest evaluation fee ($30-$40 that typically is applied to the repair cost) and they can tell you what it will cost to fix. Add to that the typical 90 day warranty as well.
Posted on Jun 25, 2007
  • Anonymous Jun 25, 2007
    A $100 part for a $200 printer?
    New Friend:
Canon never released what caused this however it was NOT resettable or servicable. It affected around 1 in 3 mp780s & also similar units that used the same circuitry, needless to say tens of thousands were just thrown out & Canon got a get out of Jail free card but it didn't do the next couple of years sales much good.
Having said that, there is NO manfacturer that hasn't had a similar problem on a specific model at some time, naturally they don't advertise that fact.
Canon was lucky because many units failed out of warranty.
Happy printing all
Posted on Feb 19, 2011
  • 203 Answers
Your print head is bad. You can purchase a print head straight from Canon @ 1-800-828-4040 and install it yourself.
    You can continue to say that the suggested actions are not solving your issue but the truth of the matter is that you're not going to find a 'magic' solution. You're going to have to replace the print head an that's the only solution to this issue.
    I'd actually cal Canon as this problem can be related to an issue they cover even if out of warranty.
    Call that 1-800 number and talk with them about checking the unit out....and be persistent. They do concessions on out of warranty items....see what they'll offer....
  • 97 Answers
Remove the ink cart and the print head for all of the colors. Reseat and reinstall all colors then run the printer maitinence. If it still comes up with the error, replace the print head. Cannons are known for the head problems. Hp and Lexmark always have new head with new cart to avoid this issue.
Posted on Jun 22, 2007
  • 102 Answers
Ok, Now open up the printer where you put the cartridge, get a dry peace of cloth and start cleaning the metal pins that align to the printer cartridge. You may use some perfume to make more clean. This what have caused the printer to prompt "Wrong Cartridge" Good Luck
Posted on Jun 19, 2007
SOURCE:
Hi, I see others have had this problem but can't find an answer (I am not still under warranty). Pixma MP780 suddenly giving a "wrong cartridge" error message. Have only used genuine Canon but have...
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Nov 23, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MP780
You get that message when the printhead goes bad. It's not the ink cartridges. You need a new printhead
# QY6-0049-000 around $60.00
Nov 18, 2009 | Canon PIXMA MP780 All-In-One InkJet...
"Wrong cartridge" error when in fact it is the right cartridge
On this machine it means the printhead is bad. QY6-0049-000 around $40.00
Jul 19, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Mp780 wrong cartridge error
Try to reset to factory .
Remove ink cartridges and print head.
Power off machine and unplug for 10-15 minutes.
Restart machine and install head and cartridges.
Jun 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Receiving message stating "wrong cartridge"
Overnight I started getting the "wrong cartridge" message on my Canon MP780. I use only OEM cartridges. As the Canon website suggested, I replaced the printhead with a new one (Empire Office Machines for $48.25 plus shipping) and it works great. Prints better than ever. Easy fix for my machine. I did read that using refills can cause more problems than just the printhead.
Oct 14, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MP780 "Wrong Cartridge" Error Message
I have two Pixma 780's. After getting the "wrong cartridge" error one day when I turned it on, (I knew it was the right cartridge) I tried switching ink tanks, and the print head cartridge several times between the two printers. the problem followed the black print head cartridge, so I am guessing I need a new one. From that experience, I would recomend swithing the print cartridge if you get this error. Does anyone know how to do a reset on this machine? A Canon tech told me once, but I lost the info.
Jun 05, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Pixma780 wrong cartridge
If it is new, just call technical support. Chances are if it is in warranty, you'll get it replaced. I'd say do that before anything. Let me know otherwise
Jun 19, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
918 people viewed this question
Clive
Clive
old marine
old marine
Ekse
