SVA Color TFT LCD is white on start up but goes blank.
In middle of work session monitor went blank. I unplugged it and plugged it back in and it came up with white screen and small red light, second from left came on. The usual monitor green light remained on.. I can operate with another monitor. Any advice?
Jerry
  • Anonymous Jan 16, 2009
    i have the same problem except i unplugged it and plugged back in but the monitor still wont turn on. what can i can?
When i turn the computer on the light on the monitor blinks green but i cant get it to turn on..i have a black screen.
Posted on Apr 03, 2010
My DELL flatcreen just went blank and is now flashing yellow light, won't turn on
Check and make sure your connections on the back of the PC are snug...and make sure you have a good connection at the back of the monitor.
Flashing light...is loss of signal.
Good Luck,
Mike
Nov 06, 2009 | Dell 1702FP UltraSharp 17" TFT LCD...
Gateway Monitor goes blank after a few seconds after startup.
Sounds like the inverter is broken or have a short circuit. This is a common failure on TFT displays.
Here is a website explaining this kind of failure:
http://josepino.com/?howto-repair-dell
Oct 09, 2009 | Gateway FPD2275W LCD Monitor
Dell flat screen started flashing, green light was blinking then screen went blank and green light is on. Tried unplugging etc...time for a new one?
No. It is not a Flat Screen issue. It is a CPU issue. You CPU is not sending signal to your flat screen so the green light is flashing. Try to:
1. Reset OR
2. Unplug the CPU case, Open the CPU, the interchange the RAM modules, OR
3. Same with step 2 but unplug and then plug back in all expansion cards like audio, video cards, etc.
It seems that your system needs discharging from a frozen state.
Regards!
Jul 26, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
SVA 17" flat monitor screen color is pink.
It's not a "windows" problem. At the bottom of your monitor there should be a 'menu' button. Push the button and use the up and down, right and left arrows on your keyboard to scroll to color. Get the "red" color and adjust it down. You can also scroll through to 'contrast' and adjust that. You don't need to pay a bunch of bucks to have this fixed.
Apr 10, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Two monitors blank, but on
<table x:str="" style="border-collapse: collapse; width: 124pt;" border="0" cellpadding="0" cellspacing="0" width="165"><col style="width: 124pt;" width="165"> <tr style="height: 14.25pt;" height="19"> <td style="height: 14.25pt; width: 124pt;" height="19" width="165">http://www.wholesaleeshop.com.au/LCD-Monitor/10.4-inch.php</td> </tr></table><br />I wish you problem can be solution. <table x:str="" style="border-collapse: collapse; width: 54pt;" border="0" cellpadding="0" cellspacing="0" width="72"><col style="width: 54pt;" width="72"> <tr style="height: 14.25pt;" height="19"> <td style="height: 14.25pt; width: 54pt;" height="19" width="72">&lt;a href="http://www.wholesaleeshop.com.au/LCD-Monitor/10.4-inch.php"&gt;10.4 inch LCD Monitor&lt;/a&gt;</td> </tr></table>
Mar 24, 2009 | Acer AL2216WBD LCD Monitor
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
SVA Monitor stuck in Analog Mode or Sleep Mode
Actually it was quite easy. I rebooted my computer in "safe mode" by restarting it and pressing the F8 key. At the start up windows gives you an option to toggle down to "enable VGA mode" and select it. After that, my computer recognized my monitor and it has worked fine ever since!
Mar 09, 2008 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Feb 07, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Sva 15" flat screen monitor
You have a bad power supply capacitor or two. Very common. Not worth fixing, these are free on craigslist *replacement monitors like this
Oct 27, 2007 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
Computers & Internet Logo
328 people viewed this question
David Payne
David Payne
