Question about Nikon COOLPIX L18 Digital Camera
Cannot open battery case
I received the camera for Christmas and put in a new battery and the memory card. Now it says the batteries are exhausted, but I cannot open the battery case. I push the button forward, but it doesn't automatically pop open. I've tried pulling it open with a fingernail, but it doesn't budge (and almost broke the nail). I don't want to force it, but I'm worried it could be jammed somehow. Is there a trick to opening it, or will I have to send it back to the factory?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Put your thumb on the cover, push it toward the back of the camera and then toward the near end of the camera, and then it will swing open. The directions are indicated on the bent arrow on the cover.
See the illustrations in the "Insert the Batteries" section of the manual (page 12 in my copy).
Posted on Jul 20, 2012
SOURCE: Battery EXTREMELY Exhausted
As the other person says Nimh rechargable batteries are the best....Also somewhere in the menu system you will find that you need to define which type of battery you are using, this may be the cause...Nikon UK have an excellent after care team if all else fails.
Posted on May 25, 2007
SOURCE: camera wont turn on even with new batteries.
I have the same problem as well. I have had my camera for a bout 2 years. The first time this happened was in March 2007. We had been using regular AA batteries, then we decided to go lithium and bamm! The camera started working. I was elited. Then in the beginning of December 2007, it let me take one last picture and then it wouldn't come on again. The lithiums wouldn't even work. We recently took it to a camera shop and they suggested the same as the other posts. I think it would be cheaper just to buy another camera and I think there should be a recall on this camera, if there are so many other customers having the same issue. I really did enjoy it while it lasted, though.
Posted on Dec 29, 2007
SOURCE: Battery Problem
can someone fix the exhausted battery problem?
Posted on Feb 17, 2008
  • 4924 Answers
SOURCE: I keep getting "Battery Exhausted" messages, with new batteries
you have to use only very good quality batteries ...I have a philips..and if I do not put alcaline quality bateries in it do not even power up ....and even with this expensive ones it eats 'em like snacks...
by the way ...keep the batteries inside only when you shoot cause all this new cameras with display and so ...consumes the batteries even when they are powered off ..
my advise is to buy some accumulators the kind you charge on the home power in this way .. you will always have strong power into them ..and the cost its worthily ..
Posted on Jun 08, 2009
  • 12 Answers
SOURCE: Blurry Photos & Batteries Exhausted
I may be able to help with the battery problem. Two suggestions: 1) With a WHITE eraser (preferably at the end of a pencil) rub the metal tabs in the camera that makes contact with the batteries. They may be slightly corroded. DON'T use a pink eraser. A fine sandpaper will also work, but is more difficult to work with inside a small space. 2) The metal tabs may be pushed in too far. You may need to pry them out with a small flat-head screw driver or needle nose pliers. Do so gently.
Posted on Sep 07, 2009
Camera does not recognize batteries.
Your batteries are worn out and need replacing for new fresh ones. They are charging, but not holding the charge. If they are new, they are fakes or worn out.
You can buy batteries which have a higher capacity, more MaH (milli-amp hour) than your current ones.
Having a quick Google, it is a known problem.
try this ... i had the same problem with the same camera and this fixed it.
remove the battery, and remove the memory card ... then re-install the battery & turn on the camera.
this process seems to reset the camera, if the battery ran too low.
now you can re-install the memory card & battery and resume normal operation.
be sure to check for the small flashing green light on the back of the camera (next to the "flash" indicator symbol). it should be blinking when the camera is charging.
i hope this helps you.
nikon coolpix battery exhausted message Google Search
Feb 10, 2018 | Nikon Coolpix 4600 Digital Camera
My camera will not turn at all. I have brand new batteries and changed them with other new batteries (just in case). Before the camera did not turn on at all it showed on the screen "problem with...
Remove the batteries. Remove the memory card.
Install batteries only, paying close attention to inserting correctly. (Possible one was put in wrong.)
Does it start?
Yes - Power off. Insert memory card. Power on. Does it work? Memory card may be defective. Try formatting it.
If cam does not power on, return it under warrenty for replacement or refund. Or warrenty repair..
Feb 06, 2011 | Polaroid i1036 Digital Camera
The batteries always seem to drain shortly after putting them into the camera, no matter what type or brand of battery I use. Help!!!
?? Drain as in leaking. If the camera makes the batteries leak you should contact KODAK immediately and they will make a HSE case for you. Contact KODAK: If you mean the camera is drinking batteries try these steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 20, 2010 | Kodak EasyShare C633 Digital Camera
I have a Kodak Easyshare C180 digital camera. I open ity, take a picture and then it closes. I then cannot get it open again. I see the on/off button but nothing happens
Is the camera LENs won't retract? Try to use a brand new different recomended batteries like alkaline batteries or lithium batteries. If your using a rechargable batteries make sure that they are fully charge. You can also try to turn the camera ON without using memory card. Remove the memory card on the camera. Then put a new recomended battery, try to turn it ON if the camera will not turn ON or stay ON call kodak support line. Support in English and Spanish is available at 1-800-235-6325 (23KODAK)
Nov 15, 2009 | Kodak EasyShare C180 Digital Camera
Memory card
Try to check the Memory card if it is compatible with your new camera. To know this you need to read the owners manual and try to check the directions on putting your memory card. Your memory card must be check also from a computer if it is still functional. If you have files like old pictures try to save to that card. if the save files are opened then your memory card is working. But if is not then your card needs to be reformat. if it cannot be formatted thats the end of its life. You need to have a new one.
Please reply if it works or not. To give you more advices.
Jan 02, 2009 | Cameras
Nikon Coolpix 4600 lens extended and won't turn on
Go to store and purchase a memor card reader/writer. It will allow you to put your memory card in it and download the pictures to the computer via the usb port. Make sure the reader/writer is made to accept your type of memory card.
Dec 27, 2008 | Nikon Coolpix 4600 Digital Camera
Battery Problem
ITS NOT THE BATTERIES -- check out the internet (google "nikon coolpix battery exhausted" and you'll see hundreds of people are experiencing this glitch. best fix i've found so far: remove batteries and memory card, then replace batteries and try again. Maybe firmware update works too, but this fix is not confirmed.
Jun 24, 2008 | Nikon Coolpix L11 Digital Camera
New camera won't work!
That message is probably because you have not saved any images in the camera's internal memory. Whatever pictures you took are on the SD card. Try taking a couple of pics using the SD card and try the review. If you are able to review, then all is well. If you cannot review, then one of 2 things:
1. Faulty SD card..Replace or format it.
2. Remove the SD card and take a pic. The pic will be saved in the camera's internal memory. If you still cant preview, probably a fault with the camera, and you'll need to service it.
Jun 02, 2008 | Kodak EasyShare C340 Digital Camera
Polaroid i631 digital camera
Daughter received camera as Christmas gift. Camera beeps three times and does nothing. I guess this camera is only good until the warranty runs out, 90 days. We have tried several new batteries and the expensive rechargeable type also. VERY UNHAPPY!!!!!
Jan 31, 2008 | Cameras
Grey screen
Clean , outside of lens, go to menu reset to factory defaults, try another new battery, take out memory card and wipe lightly with alcohol. If none of this works contact or call customer support for brand. You may have dead pixels, if that is the case it's time to buy a new camera. Jimmy
Dec 31, 2006 | Canon PowerShot A300 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
54 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
