Question about Philips Magnavox 9P6034C 60" Rear Projection Television
No pic. or sound but power light is on
Phillips/magnavox ptv835 60 in. rear proj.
i heard a pop and then there was no sound or pic. but the green power light stayed on. is this a easy fix for me and what can it be?
  • cjduffy8 Jan 18, 2009
    same here, except my tv is an older model not found on the website.
    Model # FP4640W104.
    Sounded like firecrackers going off inside the TV!!
    Then no picture or sound, but power is on and so is green light.
    Wondering what is wrong, and is it worth fixing?!?!?
    Bought the tv in 1996.
    Scholar:
  • 87 Answers
Most likely the blue picture tube arched and shorted out the horzontal output transistor.Very common problem with this chassis.Now if you have an electronics background you can most likley fix it, if not you will be dealing with finding a high voltage leak consisting of 31,000 volts which can kill you.That pop you heard was the high voltage leaking to ground.
Posted on Jan 16, 2009
Have phillips 60 in. rear projection tv have power no picture no sound just green light
If its chirping contantly when powered on take a look at the chirping tv repair kit on the site www.TvRepairKits.com
If its not chirping the next most common failure is the flyback
Apr 14, 2013 | Philips Magnavox 9P6034C 60" Rear...
My Sony Grand WEGA KDF-60WF655 60 in. Rear Proj. HDTV would black out no pic., no sounds every 5 to 10 mins. with the power light still on. Ive changed the power saver mode to low and it stop blacking out...
There is a know issue with certain Sony models where one or two parts fail over time due to heat. Check the site www.TvRepairKits.com to see if they have a blinking green light kit for your model. Its a fairly common problem.
Oct 28, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Magnavox rear proj (model# 8p6044 c102) pic is cloudy/green tint
Yes the coolant gets crud buildup in it over time which will cause the color and clarity to get very poor with obects that will glow around certain bright ojects. You can get the Phillips CRT coolant replacement kit from www.tvrepairworld.com which has the CRT coolant for all 3 CRTs and also includes the Cd with instructions on how to do the replacement.
Mar 27, 2010 | Televison & Video
Phillips/Mag Projection TV-9P5544C102 no pic/sound /pwr light on
John, my thoughts is something in the main power supply. I don't know what an opto chip is but I've heard of Optocupler IC's.
May be a good idea to give a call to some local TV Repair Shops especially ones that work on Philip's and see if you can speak with a tech to see what their thoughts are on what the problem is and what a repair cost may be.
The issue is one of hauling it to the TV shop or having them come out to you.
Blessings,
A/V Media Guy
Nov 20, 2009 | Televison & Video
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
No sound or pic on my 60 inch. rear proj.
the most common problem with that model is the LSB or the main filter board. You can go to the following link and leave them a email with you r model number and they will help you decide which board is causing you the problem. Heres the link.
http://servicemanuals.vstore.ca/
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 9p6040
Sounds like a solder or connection issue on the small signal panel. which is the ciruit baord on the left hand side of the set looking in from the rear of the set.
Jun 13, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips Magnavox
Sounds like your Convertion bord pops. Tv Technical Prop, Take for service.
May 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
261 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
