Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
The blower motor went bad.
Where to find a blower motor for Toyo laser heater ?
    Novelist:
  • 126 Answers
Toyotomiusa.com/
they have a dealer locator
Tom Hawkins
Posted on Jan 16, 2009
When i turn on my monitor it read E-08. What does that mean?
If it's a Toyo stove it means blower motor. It may just need cleaned or might need to be replaced.
Mar 05, 2011 | Rinnai Toyostove Direct Vent Heater: Laser...
I need an exploded view of the toyo 30 heater. Some thing is loose in the fan and it makes a racket when running... I suspect a vole (I live in Alaska) tried to build a nest....
Go to www.toyostove.com . Click on owner's manuals and look for the pdf file for the LR-30. The parts break down is on page 7. Part #40 is the blower motor, part# 41 is the fan, and the cover it shows behind the fan doesn't give a number. You should be able to just remove the screws from the back and open the blower.
Nov 06, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyo laser 73 error code EE8. What does that mean?
All error codes are explained on the lower left side of the heater. The EE8 message is for the combustion blower motor. If your stove has been unused for the summer you may get away with just spinning the blower wheel by hand to free it up. If this does not work you are in for a new motor or assembly. Either way you need to clean the blower and heat exchanger.
Tom
Aug 23, 2010 | Rinnai Toyostove Direct Vent Heater:...
My laser 73 heater has an error of ee8
Hello
An ee8 message refers to the combustion Blower motor
Unplug unit
Take off front cover
There is a rubber hose from blower case to the base of the unit
Take it off carefuly
Use your finger or a Pencil to try to move the intake fan
Resemble unit
If this doesn't work you may have to replace Blower motor or just clean it up.
If you can't figure it out gimmie a call Total Toyo (907) 488-9179
Dec 13, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyo Stove Laser 30 will not work
The EE-8 indication means there is insufficient air flow to the combustion pot to atomize and ignite the fuel. Check your air switch for a closed condition when the blower is operating.
Oct 13, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyo 55, igniter gets hardened build-up
Gartyl,
Your Laser 55 burner mat has erroded away. The fuel is pooling someplace in the burner rather than spreading smoothly over the bottom. The stuff on the igniter may be hardened carbon from a poor flame. Bottom line is some burner work. A new mat, ring and cleaning the burner air holes is in order. Don't be surprised if the heat chamber is cracked beyond repair when you get it off. NOW for the bad news. The Laser 55 and 72 are older heaters. You will find just about all the electrical parts are going to be hard to find. They are no longer being made. Your 55 will be able to use the newer 56 blower, mat and burner ring. You will also be able to use the heat element off a 56 as well. If there is a problem with the fuel pump causing your poor flame you will be out of luck.
Good luck,
Tom Hawkins
hawkins111@gci.net
Mar 02, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Need a service manual for laser 30 toyo stove
Remove the flex hose from the back of the stove. If there is a small hole in the back of the stove, stick a pencil in there and spin the motor. Try to start the stove. If the motor won't spin at all or if it spins freely and the stove still shows an EE8 you need a new motor.
You or your local dealer can change the motor in 30 minutes.
Tom Hawkins
Bethel, Alaska
Jan 15, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyo 73 makes constant noise when running
Could be the blower or fan motor if you haven't had it cleaned in a while.
Nov 24, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyo 73 don't work
Take a look at this...
http://www.rural-energy.com/publications/catalog/document/338
This site says there is a problem with the blower motor assembly.
Apr 28, 2008 | Rinnai Toyostove Direct Vent Heater:...
EE2 code for toyo laser 56
Hi sammysamual,
My business is Laser Heating Service in the North Pole/Fairbanks areas of Alaska. An EE2 error code is usually fuel related. What does your Toyo do before the EE2 code shows up? If you let me know the sequence of events, I can trouble shoot the problem for you. toyotech
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
151 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
