Question about Jabra GN 9120 Midi-boom Microphone-Headset Bluetooth
My GN9120 does not connect ...
I have a GN9120 DECT/GAP with a new battery pack. It Loads fine (blinking green LED) but in spite of staying green, the LED gets black after appx. 20 minutes and I cannot synchronize the headset with the DECT base station, the headset gives no noise, the red LED on the headset does not blink or anything. It look like it is completely dumb and dead. Is there any way to reset the headset? Does anyone have an idea that could point me to a solution ?
I solved this over the weekend: I found out, that the GN9120 comes with slightly differing battery sizes. I had to push the contacts deeper inside the housing so they got in touch with the new battery again. I used a very small flat screwdriver to achieve that. You have to be careful not to destroy anything surrounding.
This was an easy solution to a stuoid problem, but the contacts are barely visible in the inside of the GN9120 so i needs to have the idea to search for that as the source of trouble,
Posted on Jan 18, 2009
18v 12 cordless trimmer/edger. Why won't it start?
the trimmers switch may be faulty.
CHARGING THE BATTERY PACK
Battery packs for this tool are shipped in a low charge condition
to prevent possible problems. Therefore, you should
charge them until the green LED on the front of the charger
comes on.
NOTE: Batteries will not reach full charge the first time they
are charged. Allow several cycles (operation followed by
recharging) for them to become fully charged.
CHARGING A COOL BATTERY PACK
See Figure 3.
If battery pack is within normal temperature range, the red
LED on charger will come on.
NOTE: If the charger does not charge the battery pack
under normal circumstances, return both the battery pack and
charger to your nearest Ryobi Authorized Service Center for
electrical check.
n Charge the battery pack only with the charger provided.
n Make sure the power supply is normal household
voltage, 120 volts, 60 Hz, AC only.
n Connect the charger to the power supply.
n Place the battery pack in the charger aligning raised rib
on the battery pack with the groove in the charger.
n Press down on the battery pack to be sure contacts on
the battery pack engage properly with contacts in the
charger.
n Normally the red LED on charger will come on. This
indicates the charger is in fast charging mode.
n Red LED should remain on for approximately 1 hour
then the green LED will come on. Green LED on
indicates battery pack is fully charged and charger is
in maintenance charge mode.
NOTE: The green LED will remain on until the
battery pack is removed from the charger or charger is
disconnected from the power supply.
n If both yellow and green LEDs come on, this indicates
a deeply discharged or defective battery pack.
Allow the battery pack to remain in the charger for 15
to 30 minutes. When the battery pack reaches normal
voltage range, the red LED should come on. If the
red LED does not come on after 30 minutes, this may
indicate a defective battery pack and should be
replaced.
n After normal usage, a minimum of 1 hour of charging time
is required to fully recharge battery pack.
n The battery pack will become slightly warm to the
touch while charging. This is normal and does not
indicate a problem.
n Do not place the charger and battery pack in an area of
extreme heat or cold. They will work best at normal room
temperature.
NOTE: The charger and battery pack should be placed
in a location where the temperature is more than 50°F
but less than 100°F.
n When batteries become fully charged, unplug the
charger from power supply and remove the battery
pack.
Source(s):http://toolboyworld.com/eBay/Ryobi_P110/...
Jan 23, 2016 | Ryobi Garden
My Brand new Ryobi 18v lithium-ion battery P104, I bought this three years ago and just now needed it. I opened it from the blister pack it was in and I tried to charge it. When in the charger the red...
get the new charger; and consider returning to store or manufacturer.
if you have the black charger, throw it out
you need the green/two-tone charger for ryobi one 18v
Mar 18, 2017 | Drills
Blinking green led even D90 is off
I couldn't find a reference to a blinking green led when the d90 is off.
I would refer you to Nikon tech support for this one.
http://imaging.nikon.com/products/imaging/worldwide/index.htm
The above link has 1-800 numbers for Nikon.
Jul 23, 2010 | Nikon D90 Digital Camera with 18-105mm...
I have a question about the JDSU battery pack. i have an HST 3000 battery pack. The connector for the charger was broken, i replaced the connector and the batteries. when i charge the unit the red LED is...
Had a similar problem, it shouldn't take that long to charge. Try reseting the battery gauge, you'll find this under Power management. Only reset when you think the battery is full.
Feb 05, 2010 | Computers & Internet
Toshiba A75 - S209 Power LED Blinks non stop, no boot
Here are some troubleshooting steps. From your description, my impression is a bad motherboard.
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
Jan 13, 2010 | Computers & Internet
Both green and yellow light stay on and batteries will not charge 18v
replaced.
Oct 19, 2009 | Ryobi Multi-Volt Battery Charger
I have a shure ULX-1m1 transmitter with full battery but will not work. screen comes up green nothing on the display and the battery light is red, what could this be? and how do I fix it
First, sometimes LCD screens have an intesity/angle control and at extreme range of these characters are sometimes not visible. Check you manual to see if your unit might have such a setting.
Also this unit has some control lockouts so make sure it is unlocked so the automatic frequency selection can be made.
Verify the status of the LED in your manual. MANY Shure mics display the LED red when battery is low.
DO NOT trust a battery as being full because it is new.
ALSO DO NOT USE rechargeable batteries in these as the rechargeable battery does NOT produce 9 volts... usually only 7.2 volts (in spite of the labeling) which is insufficient and will give a low battery indication.
Sep 29, 2009 | Shure ULX1 Body-Pack Transmitter...
On line and on battery LED is blinking simultaniously
Sound like you may have a problem with the new battery.
Check the water level on the new battery.
Check all your connection and if you are still having the same problem, Try removing the existing battery and jump of your car battery.
You can do this without the computer on line and will tell you if your existing battery is at fault.
P.S. You must disconnect the existing battery to do this test.
Good luck.
I have used Tractor battery's from H/D, cost about $24.00 and will do as good a job. Only problem is the size.
Sep 11, 2009 | APC Back-UPS® XS 900 (BX900R) UPS System
Both green and yellow lights come on and stay on.
replaced.
Jul 12, 2009 | Ryobi Multi-Volt Battery Charger
Blinking Green LED on Dell Dim. 2350 won't let system stay on.
once check the ram and keep it in other slot and check it .clean the ram and keep it
Jan 13, 2009 | ASUS A7V8X Motherboard
Jabra GN 9120 Midi-boom Microphone-Headset Bluetooth Logo
1,329 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
