Question about Philips Magnavox 9P6034C 60" Rear Projection Television
No sound or pic on my 60 inch. rear proj. - Philips Magnavox 9P6034C 60" Rear Projection Television
  • Philips Master
  • 8,617 Answers
The most common problem with that model is the LSB or the main filter board. You can go to the following link and leave them a email with you r model number and they will help you decide which board is causing you the problem. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jan 16, 2009
9P6034C 60-inch rear proj TV = works great but beginnng to have picture "yellow-out" - kind of looks like brown-&-white photo - especialy at first, then perfect picture. This has gradually...
Coolant in crts needs changed. May not be cost affective. You need special equipment and much skill. If you can find servicer that can do it ask them before you schedule the call for what thie wouls cost. I would charge around $350.00. Go view a new set at 1080i and it this set at it;s best is not even close.
Aug 30, 2011 | Philips Magnavox 9P6034C 60" Rear...
My Sony Grand WEGA KDF-60WF655 60 in. Rear Proj. HDTV would black out no pic., no sounds every 5 to 10 mins. with the power light still on. Ive changed the power saver mode to low and it stop blacking out...
There is a know issue with certain Sony models where one or two parts fail over time due to heat. Check the site www.TvRepairKits.com to see if they have a blinking green light kit for your model. Its a fairly common problem.
Oct 28, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have a sony 60 in rear proj. lcd that has no red in the picture other than faint red vertical lines all the way across about an inch apart. any ideas ?
It sounds like you do not have the red component cable firmly inserted. I had this problem on my first HD TV, when the green component cable popped out when I moved the TV back in place, and the picture was desaturated of any green, causing my wife to remark, "That sure doesn't look like HD..." I reinserted the green component cable, and the picture was excellent. Check those component cables.
Feb 06, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Phillips Magnavox Proj. TV only makes cyclic chirping sound
Most common reason is shorted convergence chips. Goto the site www.TvRepairKits.com and get their "chirping set" repair kit.
Feb 01, 2009 | Philips Magnavox 9P6034C 60" Rear...
No pic. or sound but power light is on
Most likely the blue picture tube arched and shorted out the horzontal output transistor.Very common problem with this chassis.Now if you have an electronics background you can most likley fix it, if not you will be dealing with finding a high voltage leak consisting of 31,000 volts which can kill you.That pop you heard was the high voltage leaking to ground.
Jan 16, 2009 | Philips Magnavox 9P6034C 60" Rear...
Pic bad
Repair the hyper module.... See some of the previous posts for this problem...
Bill
Oct 28, 2008 | Toshiba 42H81 42" Rear Projection...
Big screen out of focus
ok you have to open the tv intill you see the 3 bulbs and the big mirror
the around each bulb is a wheel u have to turn that for the pic and focus
Jul 20, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 60" HDTV Rear Proj NO POWER
Is the led flashing or just steady light? Also do you hear a click when you hit the power button?
Apr 07, 2008 | Philips 60PP9202 60" Rear Projection...
C Color is way outta wack on my 56 inch pilips rear proj tv. HELP
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 28, 2007 | Philips 60PP9352 60" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
46 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
