Question about Back to Basics CC500 12-Cup Coffee Maker
Leaking back to basic coffee maker model cc500
I need a replacement for the glass container
it has a leak around the bottom
where can i contact back to basic to get a replacement?
  • Anonymous Feb 24, 2009
    I bought this coffee pot and within three months had to replace the pot. I had the new pot about four months and it leaks again. I called yesterday and replacing the pot is about $20 with shipping. I will not ever purchase any of these products due to the poor customer service. Their coffee pot is terrible. I am sorry, the gasket around the inside of the pot leaks within just months of use. Does not matter if the coffee is hot or cold. I have tried hot and cold water and it still leaks.
Need gasket or seales that go in the bottom part of the the pictcher
Posted on May 25, 2009
Why does the coffee maker shut off automatically?
the automatic shut off mechanism is not working right,not sure if you can get this part.Try-searspartsdirect.com
Oct 11, 2010 | Back to Basics CC500 12-Cup Coffee Maker
I need a new cup for my coffe maker!
If you mean the carafe, you're out of luck getting the original. A company called focus electrics handles replacement parts for this brand. Their parts page for this model lists nothing at all.
If you need a new carafe because yours is leaking, join the club. This seems to be a pretty common problem. You can try tightening the screws holding the gasket to the bottom.
If you don't mind losing the one-hand dispensing feature, you might try a universal replacement carafe which may fit. These are usually found with the coffeemakers at retail stores. Or you can buy a new coffeemaker. Sometimes the difference in price between parts and a new machine is pretty small.
Good luck, and thanks for using Fixya!
Feb 13, 2010 | Back to Basics CC500 12-Cup Coffee Maker
Water leaks out from underneath coffee maker
Well they don;t give these away for sure. Lets see if we can help you out. ? are you over filling it.This happened to me because I was reading the fill line wrong. {got new glasses} . If not may be you could try makeing less. But if only 1/2 cup comes out and no more, that wouldent indacate a leak in the tank, if there was it would all leak. Try backing off on the coffie and water, and see if it still leaks. if it does get back to me. DFD
Apr 12, 2009 | Bunn 10 Cup Home Coffee Brewer
Leaking caraf for model CC500 back to basics coffe maker
mine too - it temporarily helps to tighten the screws underneath (the magic doesn't last long)
Apr 03, 2009 | Back to Basics CC500 12-Cup Coffee Maker
Water Tank Leak
i had the same problem what i suggest to you clean where the water tank were its sit very good put the tank back me i never remove the water tank i clean regualy i put the tank empty on the machine and fill it with a glass never leak again pierre
Dec 08, 2008 | Saeco Vienna SuperAutomatica Coffee...
Our Bunn was a gift and it has a leak. The tank leaks out from under the maker. It always has and we have to keep a towel around it.
It sounds like you have a defective seal/gasket. If you will get the model and date code from the bottom of the brewer and contact customer service, your brewer can be replaced. If the machine is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a reduced price.
Apr 09, 2008 | Bunn NHB Coffee Maker
Help
I finally found the phone number for Back to Basics, and they said they re-designed it and sent me a new carafe free of charge. It lasted for a couple months and it's doing the same thing. You can continue to use it. My husband says the metal expands and contracts, so if after it brews you pour it into a coffee container before the heater turns off, you can still use it. It only leaks after the coffee cools and the metal contracts. Hope this helps. Here's the phone number. We all need to call and I'll call again as well. 866-290-1851 The model number is: CA0307
Nov 27, 2007 | Back to Basics CC500 12-Cup Coffee Maker
Leaking
Well, I see this is an old posting but I have a CC500 with a leak problem and it's only a few months old. Upon removing the screws which hold the seal housing on the underside of the carafe, I found a small crack in the plastic seal surface around the hole. I am going to repair the crack with superglue but have no faith that this will stop the leak. I searched the internet for a replacement carafe and haven't been able to find one. I suspect this unit will hit the garbage can as no generic carafe would work with this unit. Sorry, I think the solution is to purchase another coffee maker.
Nov 25, 2007 | Back to Basics CC500 12-Cup Coffee Maker
Back to Basics CC500 12-Cup Coffee Maker Logo
285 people viewed this question
Top Back to Basics Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Back to Basics Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
