Question about Nintendo Wii Console
Wii remote- A button not working, plastic piece over sensor crack
I have a small crack in the dark plastic over where the infrared sensor is. My A button will not function and the motion of the remote is not picked up. The 1 and 2 button and B button still seem to work. Any ideas that will help me save 40 bucks on a new one?
    Problem Solver:
  • 7 Answers
I would try to glue it back together.
Posted on Jan 16, 2009
Incripted wii remote
1. Ensure that the Sensor Bar cord is plugged to the back of the console, and is placed properly at the center of your TV screen. For detailed directions on setting up the Sensor Bar, please click here.
2. Check to be sure the Wii Remote is synced to the console, by using the Power button on the Wii Remote to turn the console on. (The power button is the small white button with the red symbol in the top-left corner, just above the Control Pad). If this doesn't work, try to sync the Wii Remote. Once synced, try to turn the power on the console on and check for proper response.
3. Make sure that the Wii Remote is being used between 3' and 10' directly in front of the TV and that there are no bright light sources affecting the Wii Remote's operation (review Game Play Guidelines for more information), and that the Sensor Bar is placed properly (see Sensor Bar setup). Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
If you are still experiencing problems after trying the steps above, there could be a problem with your Sensor Bar.
Dec 01, 2011 | Nintendo Wii Console
Tip
Wii Cursor is off-center, jerky, erratic, disappears, etc.
  • Verify that the Wii Remote's pointer lens is free of obstructions and contamination (stickers, heavy smudges, etc.). The pointer lens is the tinted rectangle at the end of the Wii Remote. If the Wii Remote Jacket is being used, verify that it's securely in place on the Wii Remote. If the Wii Remote Jacket is askew, it might be partially blocking the infra-red sensor on the front of the Wii Remote.
  • Try a new set of batteries. Occasionally weak batteries can cause this type of behavior.
  • Reset the Wii Remote:
    1. Take the batteries out of the Wii Remote, wait for one (1) minute, and then re-insert them.
    2. Wait a few seconds before pressing any buttons to wake up the Wii Remote.
    3. Re-sync the Wii Remote by using the steps listed above in the white box titled "Try these steps!".
  • Check the Directional Sensor Functionality by holding the Wii Remote with the button side down. Without using much force, tap the button side of the remote against the palm of your other hand. Doing this does not take a lot of force, so be sure not to tap the Wii Remote very hard.
  • Verify Sensitivity Setting dots:
    Go to the Sensor Bar's sensitivity setting in the Wii menu.
    • If only one or no dots appear on the sensitivity screen, there is likely a problem with the Sensor Bar.
    • If there are more than two dots, then it appears there is an additional light or infrared heat source being picked up by the Wii Remote. Avoid sources of infrared light in the gameplay area such as electric, propane or kerosene heaters, flames from fireplaces or candles, and stoves or other sources of heat.
    • If both dots appear and the erratic behavior continues even when you move closer to the TV, there is likely a problem with the Wii Remote and it will need to be repaired.
on Mar 04, 2010 | Video Game Consoles & Games
Tip
I have an apex flat screen that will not respond to remotes, including the original remote
Look for the remote control sensor window on the TV. It's usually a dark magenta-tinted window - often it is a square about 15-20 mm on a side and is usually near the power button. On some models, the sensor is barely visible as a 5 mm circle behind a large trim piece around the control buttons made of this material. Make sure the window is clean in front of the sensor - use a small amount of dish soap on a soft damp cloth or tissue. Be careful not to scratch the plastic; it is relatively soft material, and don't get liquid running into the control buttons.
If the sensor is exposed to bright light with high infrared content (sunlight, hot fireplace or an incandescent flood lamp), it may be saturated and unable to see the remote control until the bright light is blocked or otherwise removed from its field of view.
If these steps don't help, the remote sensor needs internal repair.
I'm assuming you've tried known good remote controls with codes for your specific model or had the chance to test them on other sets of the same model.
Mar 08, 2011 | Televison & Video
My pointer just started jumping around, I have changed no settings or the position of my sensor bar ans my batteries are good
Try reducing the amount of light or glare in the room. If light bounces around the room it can affect the sensor.
Feb 28, 2011 | Nintendo Wii Console
Cant get past language screen
Here are instructions from Nintendo on how to fix this issue. It's most likely related to the sensor bar. Good Luck!
If your screen appears frozen at the Language select screen, we have found that to be related to the Sensor Bar. Please try the following:
Ensure that the Sensor Bar cord is plugged snugly to the back of the console, and is placed properly at the center of your TV screen. For detailed directions on setting up the Sensor Bar, please click here.
If you are still experiencing problems after trying the steps above, there could be a problem with your Sensor Bar. Please read the following:
The Sensor Bar has five infrared lights on each side of the bar that the Wii Remote uses to determine its position. If these lights aren't working, then the Wii Remote cursor will not display on the screen, and you won't be able to navigate the setup screens.
To see these lights, you will need a digital camera or cell phone camera with an LCD display . After making sure the Sensor Bar is plugged in and the power to the console turned on, direct the camera at the Sensor Bar so that it is displayed in the LCD of the camera. If the five infrared lights can be seen on both sides of the Sensor Bar, the Sensor Bar is working. While the position/angle of the camera may need to be adjusted slightly, the lights are fairly easy to see in the LCD display.
Nov 20, 2009 | Nintendo Wii Console
My ******* wii remote wont work. It's synced and everything. I can enter the wii menu, but the hands wont show up on the screen. I am 4 ft. away from the sensor. I have no other infrared things and the...
youo may have a defective Wii remote, and you should take it somewhere like GameStop and have it looked at, or you should take it back to the store and exchange it for a new one.
Nov 14, 2009 | Nintendo Wii Remote Controller
Wii remote will not follow command.
It's problem a radio interference, since the wii controller uses radio frequences to contact the device, try to resync the wii controller.
1. Turn the Wii console on and wait until the "Health & Safety" screen appears (don't press A).
2. Open the SD Card slot cover on the front of the Wii console, just below the disc drive, and press and hold the red SYNC button for 15 seconds. This will clear all synced Wii Remotes from the console.
3. Resync the Wii Remote by removing the battery cover and pressing the red "SYNC" button. Do this for all Wii Remotes you wish to use, and test for proper response.
4. If the steps above do not work, remove the batteries of the Wii Remote and leave them out for at least 2 or 3 minutes. Reinsert the batteries and sync the Wii Remote again. Test for proper response.
If after removing the batteries for several minutes, and resyncing the Wii Remote, your still unable to get the Wii Remotes to work, try syncing another Wii Remote if available.
* If another Wii Remote works, then your previous Wii Remote will need to be repaired.
Feb 09, 2009 | Nintendo Wii Console
We moved our Wii to another location and a new TV and now the remotes point and click is inaccurate and we cannot easily aim at all. I thought it was the bar sensitivity but I think that's fine. Any ideas?
    1. Take the batteries out of the Wii Remote, wait for one (1) minute, and then re-insert them. (How to)
    Go to the Sensor Bar's sensitivity setting in the Wii menu (click here for directions on accessing this feature).
    • If only one or no dots appear on the sensitivity screen, there is likely a problem with the Sensor Bar. Please click here for repair information.
    • If both dots appear and the erratic behavior continues even when you move closer to the TV, there is likely a problem with the Wii Remote and it will need to be repaired. Please call 1-800-255-3700 so that we may assist you further
Nov 27, 2008 | Nintendo Wii Console
Wii
(1)
Verify that the cable bar sensor is plugged into the back of the Wii console and that the sensor bar is properly aligned with the centre of your TV screen.
(2)
Check that the Wii remote is synchronized with the console using the POWER button on the remote control to turn on the Wii console. (The POWER button is the white button with the red symbol which is located in the upper left corner on the Wii remote.) If it does not work, try to synchronize the remote control, then turn the console and controls that respond correctly to commands.
(3)
Verify that the distance between the Wii remote and the TV display to be between 1 and 3 meters, that there are sources of intense light that can interfere with the proper functioning of the remote (read Guidelines game for Wii for more information ) And that the sensor bar is placed correctly (see Setting up the sensor bar). Avoid the presence of sources of infrared light as electric stoves, gas propane or kerosene, candles, fireplaces, stoves or other heat sources close to the console.
If the steps described above do not solve the problem, the sensor bar could have a problem. Read the following instructions:
On each side of the sensor bar are five infrared lights that located the position of the Wii remote. If these lights do not work, the cursor on the remote will not appear on the screen and you can not step through screens of settings. To see these lights, you must look on the LCD screen of a digital camera or a mobile phone. Verify that the sensor bar is connected and that the Wii console is turned on, and then framing the bar sensor so that it appears on LCD camera or cellphone. If you see five infrared lights on each side, the sensor bar works. Maybe you'll need to slightly adjust the position / tilt the camera or the telephone, but is rather easy to see these lights on the LCD screen
Jun 22, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
73 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
