Question about Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio C420DN only prints one copy
Help! No matter how many pages I tell the print box to print it wil only print one copy! I am on a huge deadline and need help fast!
  • Roderick Mcmahon
    Roderick Mcmahon May 11, 2010
    From what application are you printing?
5 Suggested Answers
Touch2Heaven
  • 145 Answers
SOURCE: RICOH AFICIO MP 2000
you must clean developer and drum section. after that you must put new developer and initialize it. After that place in correct toner.
Posted on Oct 15, 2008
  • 68 Answers
SOURCE: Ricoh Aficio MPC5000 -- need to find setting to
user tools system settings copy setting is where you find all the relevant settings unless you are using a fiery then you will have to go into fiery settings for adjustments to be made
Posted on Sep 16, 2009
Ickoajnc
  • 183 Answers
SOURCE: i have a ricoh aficio sp c420dn, when and turn on
You may try first to reset the SC 542 before calling a technician!
That you can do by following method:
1.Turn the machine off and then after 5 second turn it on while pressing the “On Line” key and “Escape” key together until “SYSTEMver x.xx/1. Service” shows on the display.
2.Use the “Up/Down arrow” keys to scroll through the menu listing.
3. Press the (OK) key while
on the display writes " 2. Engine " .
4.go to "[5810 001] - Fusing SC Reset" by scrolling the “Up/Down arrow” keys and press the [OK] key (on the display should write execute or done) press [OK] again if is needed to press it.
5. After this turn off and than after 5 second turn it on the machine.
Please do not change nothing else in this menu only reset the fusing unit SC code, because if you change some other values and settings you might to regret that and pay high price for that.
So only reset the Fuser SC code SC542 by the upper mentioned method and do nothing else, if the SC code appear again then do not try this again because you might burn some parts.
If this do not help than call the technician.
Please answer do this is helpful for i to know do the problem was solved.
Regards
Posted on Jan 13, 2010
  • 903 Answers
SOURCE: Using the PCL drivers for our Ricoh Aficio MP 3350
Try using the RPCS (Ricoh's proprietary print driver) for printing from Word, and see if that works any better. You could also try another version of PCL -- if you're using PCL6, try PCL5, for example.
All of the 3350 drivers can be downloaded here (just choose the correct operating system):
http://ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb/html/dr_ut_e/rc2/model/mp33/mp33en.htm
Posted on Jun 07, 2010
My Ricoh Aficio SP C420DN Laser Printer shows color tone SC366 and some time SC365, any ideas?
You just have a problem with colour PCU (SC 365 - magenta, SC366 - cyan). The main reason is that toner density is abnormal. Sometimes, when you replace toners, printer receive to much toner for a short time, and after that you have an abnormal toner density (higher). You can check in service mode (hold up and down arrows for 6-7 sec, release them and press ok button) following thing :
choose 2. engine
then with arrows choose 3. process
then choose Vt display,
for each color by default there should by somewhere arround 2.4V. If you see for some colors, for example 0.02V, then this is a problem(to much toner). In this case the only thing that you can do is to restart printer and try to print enough pages, filled with problem color. Usually you can print max 3 pages. Then restart printer and try another 3 pages. Print until the you will be able to print at least 4 pages continuously.
Good luck and remember that this is a technical problem and you should ask someone qualified for the job. I am sure that 80% of service engineers can't repair this issue. But I can.
Apr 17, 2015 | Ricoh Aficio SP C420DN Laser Printer
How to clear functions
Open left printer cover. Open PCU cover. Pull Magenta, Yellow and Cyan PCU units and check which one has blocked!!! Probably you will need to replace color PCU (type 145). Good luck
Sep 30, 2014 | Ricoh Aficio SP C420DN Laser Printer
What could be the problem on ricoh printer sp c420dn its given me error code sc 364
Probably you have just replace some of the toners (black). The toner density is too high. Restart printer and try to print full A4 black page.
Aug 30, 2014 | Ricoh Aficio SP C420DN Laser Printer
Ricoh aficio c420dn wont print black
Hi, my experience with this machine is that the gear that drives the black pcu breaks or cracks. Usually caused by the pcu being too hard to turn. I always turn the developer gear in the pcu before installing it just to loosen the toner.
Mar 15, 2017 | Ricoh Aficio Office Equipment & Supplies
Color Laser Printer Pink Tint
have you tried cleaning the charging wire and the transfer belt
Feb 17, 2014 | Ricoh Aficio SP C420DN Laser Printer
I am looking for thresdhold when the Ricoh aficio sp c420dn printer sends out the toner low message. Is it 15%? I cant find this anywhere. There are other Ricoh models also.
Ricoh sense toner in the following methods:
Toner Near End
To detect the toner near-end, the machine uses:
Pixel count (memory chip on the AIO)
AIO rotation distance (memory chip on the AIO)
Toner End
To detect toner end the machine uses:
Output from the TM sensor (center)
After near-end, it is estimated that 200 pages (A4, 5% coverage) can be printed until toner
end occurs.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Apr 01, 2011 | Ricoh Aficio BP20N Laser Printer
Help, my ricoh printer will only print one copy, when I need 60, yesterday :-) It's an Aficio MP C3000 Many thanks,
Hi, there is an option for how many copies to print in the printer driver. When you hit Print in the program you want to print from, a box of printer options should appear, including which printer you want to print to. There will be a field, probably about halfway down the screen, asking for the number of copies you want to print. Change this to 60 before proceeding and you will make 60 prints of your document or image. Hope that helps!
Nov 13, 2010 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio SP C811 DN only prints one copy
Sounds like under printer prefferences is set to sample or some such. -Carl (you are using a postscript driver right?)
May 13, 2010 | Ricoh Aficio AP3800C Laser Printer
When it prints it only prints garbled letters
usually when it prints Garble it means the wrong driver is installed for the printer or PC. Make sure you have the correct driver and unistall the one you have and reinstall the new one.
Dec 30, 2009 | Ricoh Aficio SP C410DN Laser Printer
Printing from the wrong tray on the Ricoh C410 DN
these settings need to be done with the RPCS printer driver, go to properties and then custom settings from there you can tell the printer where to print from.
http://www.websitetoolbox.com/mb/copierquestions
Dec 30, 2008 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio AP3800C Laser Printer Logo
480 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
