Question about 450-R Deluxe Remote Starter with Keyless Entry
I think i have disabled the remote how do i enable it
I thought you hit the start button three times but that doesnt seem to work.
  • 95 Answers
You have to hit the star or start button twice...if that doesnt work try hitting the trunk button three times...each press should be a second long and a second inbetween presses...hope that works
Posted on Feb 15, 2009
Unit starts to run and then goes into rs online mode disabling unit. checked for loose wires etc. rest button to go back to manual mode but goes back to rs online mode. is there way to bypass this and what...
make sure aqualink has heater enabled if not enable it if still doesnt work turn heater to off hold up button and down button and menu all at same time for 7 sec then you should be able to take it off remote and put on manual
Oct 07, 2013 | Jandy Laars LX Pool Heater / 250,000 BTU /...
How do I enable my touchpad scrolling feature?
Right-click on the desktop, then click "Personalize."
Click "Change mouse pointers." This opens the mouse properties window.
Click the "Gestures" tab in the mouse properties window.
Click the "Use Vertical Scroll Function" and "Use Horizontal Scroll Function" check boxes.
Click "OK."
or you might
click "Start" button in the lower left corner of your desktop.
Scroll up and hit "Control Panel."
Choose "Mouse."
Click the "Device Settings" tab.
Highlight the touchpad in the list of devices. Hit the "Enable" button.
Hit the "Apply" button and hit the "OK" button.
to disable
Go to the control panel to the Mouse options and click on the Gestures tab and there is an
option that under Virtual Scrolling "Enable Virtual Scrolling" disable that option and that
should stop the auto scroll.
hope this helps
Sep 01, 2012 | Dell Inspiron 1520 Motherboard
2001 Mercury Villager keyless remote is malfunctioning
Keyless Entry
The keyless entry system consists of the following:
  • smart entry control(SEC)/timer module
  • keyless entry remote transmitters
  • power door lock actuators
  • body side door power door lock actuator
  • liftgate actuator
  • power door lock switches
  • door ajar switches
  • Principles of Operation
    All doors can be locked at once by turning the door key lock switch to the locked position. An individual door can be unlocked by moving the door key lock switch to the unlocked position and turning it again within five seconds; all the doors (including the liftgate) will unlock.
    The smart lock system is designed to keep the driver from locking his keys in the car. It will lock and then unlock all the doors if the smart entry control(SEC)/timer module detects the following conditions:
    • The ignition key still in the ignition.
    • A front door is open.
    • A door lock switch has been pushed to the lock position.
    The panic feature has a duration of 30 seconds from the last time the PANIC button is pressed. When locking the doors from the remote transmitter, the horn chirp/lamp flash feature can be disabled or enabled by holding the LOCK and UNLOCK buttons for two seconds. The hazards will flash three times to confirm that the feature has be enabled or disabled.
The control module probably see's an input that shouldn't be there . lock Switch , door ajar etc... Don't think it has anything to do with the remote . Some part stores have a tester to see if signal from the remote is working . Or the dealer ! Take it an see if your remote is sending a signal without you pressing any buttons .
If it is you need a new one .
May 19, 2017 | Cars & Trucks
I put new batteries in my camera-but doesnt do anything. I left camera on,I think and then thought batteries died so then replaced with new nothing works.
This happened to me as well. I took the batteries out and put new ones in three times (same batteries). The third time the camera started working again as soon as I closed the battery compartment and tried on "on" button.
Mar 20, 2011 | Kodak EasyShare C533 Digital Camera
Blue light is on and a blank screen on tv remote does nothing tryed hard reset with no change
Hello! Daniel Busa here with Dish Network customer service. The blue light simply means tv2 is up and running, you need to get the green light on. If it's still down hit th sat then power. If that doesnt work, hit the channel up button on the box system info should appear hit record three times, and then select, then power and it should start running again.
Dec 11, 2010 | DISH Network 322 DTV Receiver
2005 Chevy Uplander Remote Starter
check in your owner manual it will tell you the problem was the check engine light is remote starter does not work
Feb 15, 2010 | Chevrolet Uplander LT Cars & Trucks
My horn used to honk when I locked my 1999 Jeep with the remote
If you have your owner's manual, there is a section that will tell you the exact sequence to press to enable/disable the horn bonk. It has three settings, chirp, honk, and off. The chirp is a really quick chirp of the horn. Honk is a longer honk. Off seems to be what you've set.
I hope this helps.
Aug 20, 2009 | 1999 Jeep Cherokee
I have a 2006 G6 and the remote starter recently stopped working. The remote will lock and unlock the doors but when I hit the lock and then starter button on the remote the lights will just flash and you...
you can only start the car starter three time before pcm disables the function must start agin with key to get working. also may have diabled car starter by dic comands on radio also if you have engine light on will not operate car starter due to light.
Jan 02, 2009 | 2005 Pontiac G6
My GPS system is having seizures
The solution is listed on the garmin site but it is not clear
The problem is with the infra red remote reciever on the unit
Sometimes the sun acts like the remote is being pressed and that is when it shakes
the solution, and I hope you still have the unit cause there is nothing outthere like it.
Answer: from garmin site Normally this issue is caused by sunlight from certain angles hitting the Infrared (IR) port on the unit. This makes the unit react as if the remote control was communicating with it. This makes it switch in between screens just like if you were using the remote.
You can disable the remote IR port on your StreetPilot® 26xx unit by:
  1. Powering your unit ON
  2. Press the Menu button
  3. Touch Options
  4. Touch the General tab
  5. Press the Menu button
  6. Touch Disable remote
If you wish to use the remote again you can enable the remote IR port on your StreetPilot 26xx unit by:
  3. Touch Options
  6. Touch Enable remote
Dec 26, 2007 | Garmin StreetPilot 2610 GPS Receiver
450-R Deluxe Remote Starter with Keyless Entry Logo
279 people viewed this question
Top Alert Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Alert Vehicle Part and Accessory Expert? Answer questions, earn points and help others
