Question about Reddy Portable Forced Air Propane Heater w/ Variable Heat Ouput
Rlp50 Runs fine untill release automatic control valve button. Yes, regardless of how long I hold it in, as soon as I releae I get flame out. Thanks, Steve
The thermocouple is bad
Posted on Jan 31, 2009
Broken stove knob
simple flame sensors at fault eg thermocouples replace bad sensors and dsi box (direct spark ignition )
Apr 01, 2014 | Ovens
Atlanta Stove AIT3 model wall stove. will not light unless pilot light is held down...
Most pilot flames for gas burners are controlled by a safety valve. This model has a pilot safety valve. The safety valves function is simple, if the flame goes out for whatever reason the vale shuts the gas flow to the pilot light. The safety valve is controlled by a device that sits right next to the pilot (small cylindrec tube ( thermopile) that senses the pilot flame either by heat or dc current. To ignite the pilot light you have to manually hold down pilot light button until the the thermopile is hot enough (usually 5 to 20 secs), after that time, the thermopile will allow the safety valve to open. Check to see that the pilot's flame is making contact with the thermopile. If it is not, the pilot flame will require cleaning and or adjustment. If it is making contact, the you might need to replace the safety valve and the thermopile.
Feb 17, 2018 | Kitchen Ranges
First, Change your technician.
There is a part that senses the heat from the ignited gas, usually quite close to the flame on the oven burner where it first ignites. It is called a generator and it produces about 1/3 of a volt, that holds the gas valve open only while the flame is lit, as a safety device. Pressing the knob at the time of ignition bypasses this by holding the valve open, after releasing the knob then the system relies on the presence of an oven flame to hold the valve open. Check the generator at the point it enters the oven control valve, is it loose? Maybe it is faulty or the oven valve is faulty. Any real technician can identify the the problem easily.
Oct 31, 2017 | Candy Washing Machines
Brand new heater installed according to manual yet unit shuts off randomly after running - some times in less than a minute, sometimes after a day and a half of running fine. How do you test the...
I doubt if the ThermoCouple (TC) should have failed this soon!
However-- Here is a page I wrote to help others trouble-shoot and replace the TC
One possibility is that the Thermo Couple is beginning to fail'
What is a Thermo Couple? (TC)
The Thermo Couple (TC) is a small Rod-shaped device with a couple wires coming out the bottom.
The TC actually generates a small electrical current from the heat of the Pilot.
This electrical current is sensed by the control board, or the Main Gas Valve.
As long as there is a pilot, it is safe for the Main gas valve to open, and admit the large amount of gas into the heating burner.
Now-- What helps this TC work the best?
It needs to be just at the edge of the pilot flame--- Not too much in the flame, or the resulting poor combustion of the pilot flame, results in soot forming on the TC-- which insulated the TC from sufficient heat.
Obviously the TC has to be clean (of soot) in order to receive enough heat, to generate the needed voltage to tell the valve that it is safe to open.
And age does deteriorate the TC-- some last a few years, but that is about the end of life for most.
Replacing requires getting down where the TC is, and with a screw driver (usually)-- loosening the bracket that holds the TC. Pay attention to where the wires are routed, and any polarity indicated on the old wires, and duplicate on the new one. Duplicate routing, and polarity, and position the new TC at the edge of the pilot flame.
Pilot flame is maintained by pushing some over ride button-- for a minute or two, until when you begin to release the button, you can feel that the voltage generated by the TC is now holding the pilot valve open, instead of your pressure on the 'start' button.
Any further Questions, let us know..
Mack B
Jan 26, 2011 | Heating & Cooling
Model rlp50 50,000 propane heater fan will run, will light, but won't stay lite when you release button, fan still runs
i have the exact same heater with the exact same problem. tested the thermocouple seems to be fine, tested the relay, it seems to be fine, could it be the gas valve????
Jan 12, 2011 | Reddy Heater-30-55,000 BTU Variable
I need to know how to light the pilot light on my gas furnace.
What needs to happen that may not be obvious is that you have to heat the thermal tube long enough for it to expand and open the gas valve. No heat and the system should shut down flow immediately.
The thermal tube is copper in color and runs between the gas valve and the pilot flame.
So, there is an override. usually spring loaded (heavily) and you press some button or know, this manually opens the fuel valve.....You light the pilot, still holding button......Pilot lights, holding, holding...maybe 10 to 15 seconds.
Then the secret is that you SLOWLY let up on the button, observing the pilot....If it starts to go out, push the button all the way in and continue heating the thermal tube. Soon, you should be able to release the button, and the pilot remains lit. You are good to go, and you can open the gas valve the rest of the way, for normal use. (usually past the pilot position.
Nov 06, 2010 | Fedders Heating & Cooling
My pilot light went out and when I try to relight it, the flame will light when I press down on the red button by the gas control valve. I hold it down for about a minute like the instructions say but when...
Hi you will need to replace the thermocouple. This is the copper tube that screws in to the gas valve and goes back and mounts along side of the pilot. Most will pull straight out. When they go out, the pilot will light when you hold the red button down, but as soon as you release it off it goes. You can but this thermocouple at any hardware store. They come in different lengths, But I would get a 36" one. They will coil up so they wont be in the way. Its better to have a longer one then one that's to short. Make sure the tip is in the flame, or it will do the same thing. It has to get very hot to keep and produce milivolts to keep it on.Please don't forget to rate me on this as I know you will be kind. This will solve your problem for sure.
A/C, Heating Contractor
Sep 10, 2010 | Heating & Cooling
Heater won't stay lit after releasing yellow button
you need to replace the thermocouple at the burner tip it will be a copper line with a bulb in the flame tip with a copper tube leading back to the gas valve and it senses the flame and keeps the gas valve open
Dec 24, 2009 | All-Pro Propane Garage Shop Heaters - All...
How do i get universal remote to "learn" from other remotes ? i know it had something to do with pressing and holding the learn key
Press and hold CODE SEARCH button until the red indicator turns on,then releas the button. Press and reaease the desired mode button(TV,VCR,etc.)the red indicator blinks then stays on. Press and release the LEARN button,the red indicator blinks thenstays on
Nov 19, 2009 | Gemini 1 Device Universal Television...
Reddy Portable Forced Air Propane Heater w/ Variable Heat Ouput Logo
186 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
