open recycle bin and paste the following link. http://www.winhelponline.com/articles/105/1/File-association-fixes-for-Windows-Vista.html
you will got a table on this page, and in that you have to select exe As you click on exe, it will ask you for open, so open it. In that there is 1 file, run that and it will fix the issue.
if still not try to create a new user account from control userpasswords2 and restart the computer. after that try to work in new user account.
I think you need to get the latest firmware and load it. You should be able to stop the bootup as soon as you power it on. HP Support can be reached at 1-866-my-procurve. Their support group should be able to help out.
Hi, you need to add following entry to maker.ini file present in C:\Program Files\Adobe\FrameMaker7.0 location Under section API Client add following line WWPPE7=Standard,WebWorks Professional Edition Plugin,C:\Program Files\Quadralay\WebWorks Publisher Professional Edition 7.0\bin\wwpfm7.dll,all
Please note that path given to wwpfm7.dll may defer depending upon your webworks installation directory
Thanks Rohit
i suggest you an alternative method to open the turboc++ programme you can create a batch file for the tc executable file by opening the dos prompt and creating it( c:\\edit tc.bat
c:\turboc\bin\tc.exe) and send this shortcut to the desktop
go to your folder with the files you want to share, open the folder select all of the music files copy them. Open up your brothers flash drive then paste them onto it.
If you have made a shortcut to these files on your desktop then copying them it maybe trying to copy the shortcuts and it won't work.
Another thing to check is that the music files are in the right format for the flash drive.
This file contains only information about "where" your photos are on your harddisk. If you moved or deleted them, they cannot be found anymore, and if you emptied your recycle bin, they might be lost forever.
This error occurs because Windows CE first moves the file to the recycle bin before deleting it, and if there is insufficient space, the error message is displayed and the system appears to hang.
To resolve this issue, use one or more of the following methods.
* Empty the Recycle Bin
Use the following steps to empty the Recycle Bin:
1. Depress the "Alt" key and tap the Recycle Bin.
2. Tap "Empty Recycle Bin"
3. Tap "Yes" when asked to confirm the file deletion.
* Change the Properties for the Recycle Bin so that files are deleted instead of being moved to the Recycle Bin.
Use the following steps to change the properties of the Recycle Bin.
2. Tap "Properties".
3. Tap the check box for "Do not move file to the Recycle Bin, remove immediately on delete".
* To make additional space available for the Recycle Bin.
3. Tap the slider to the right.
