Question about Lands Phones
We have a phone TRU9585 Series and it has been working well until yesterday the message on the screen reads: Handset Out of Range. It is sitting on the base !!
    Sergeant:
    Champion:
  • 435 Answers
Try resetting. Check the battery on the handset. Check if sits properly. I mean, the contact between them is clean.
Posted on Jan 16, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
A couple of ideas you can try:
unplug the base and remove battery from handset for say 30 mins to an hour or even more. The idea is to reset the system. of course it is possible that stored phone numbers, memories and user settings would be erased reverting unit back to factory default. After said time, plug in the base, re-connect the handset's battery and proceed with registering/setup/pairing.
If the above is not corrective, then possibilities are:
  • defective transmitter section of the handset;
  • defective receive section of the base;
  • handset and base are not on the same channel.
Pls post back result(s). Good luck and Thank you for using FixYa.
    Brigadier General:
  • Lands Phones Master
  • 3,614 Answers
0n y0ur user manual, f0ll0w the steps 0n h0w t0 register again the handset t0 the base
  • 535 Answers
U have to do this just power off your phone 10 min then power on it
The display screen is showing the word "SEARCHING" on the screen, can't get the phone to work, cannot pick up an incoming call, the display also displays "HANDSET OUT OF RANGE" WHEN ANY BUTTON IS...
From the Uniden support site.
You can first try a Basic Reset.
A reset is done by following the below steps:
1. Disconnect the battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect battery into handset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base
reference
Mar 13, 2015 | Uniden DECT 6.0 Cordless Phone ID
What is meant when screen says out of range
You will need to take your handset closer to the base because the signal is weak and out of range. Try locating the charging base in a more central location. If this doesn't work try this.
For more info go to this site
Customer Support
Feb 27, 2015 | Uniden Dect6.0 Digital Answering Syst W...
My uniden phone says - out of range
Uniden wxi477 out of range fix
This problem arises when the handset does not communicate with the base.
These are the steps:
1: Deregistering the handset
2: Registering the handset to base
Deregestering clears the stored (incorrect) base information on the handset.
Reregestering allows the base to assign a new ID for the handset.
Deregistering- press and hold the OFF (red button) and the # button on the handset for 5 seconds. select base unavailable and press OK. Are you sure appears. select yes and press OK. you will hear a confirmation tone. The handset will delete its own base information without trying to contact the base. It will now display MODELS VARY PLACE HANDSET ON THE BASE FOR REGISTRATION.
Registering the handset with the base- Make sure the tel. line and power is plugged into the base.
Press an hold the register button under the base (located between the tel. line and yellow power socket under the base) for 5 seconds until the red light flashes. At the same time press and hold the # button on the handset for 5 secs. You will hear a tone and It will now display REGISTRATION COMPLETE.
If it says registration failed: Retry the registration steps. Make sure the handset have enough battery power. If not charge for 15-20 hrs.
Check your connections on the base and make it is getting power.
The Steps above was my fix for the uniden wxi477 out of range problem.
Good luck.
May 25, 2010 | Uniden TRU9585 Cordless Phone
Phone message reads
If you are not too far away-not "out of range" then try rehoming/pairing the handset with the base unit. You probably need the phones together to do this. Your manual will explain how-it will have been done in the original setup.
Oct 03, 2009 | Uniden TCX905 Cordless Accessory Handset...
Handsets read Handset Out Of Range
Disconnected power and phone line, reassembled and then had a dial tone.
Mar 23, 2009 | Uniden TRU9585-4 Quad Cordless Phone
Unable to register handset TWX955 Series
I have a TRU9585 Base.
On the BASE press menu/select, scroll down to register handset using the button to the right of the display, and press select. The LED on the base will flash quickly.
Now pick up the TWX955 handset (the one that won't register), and press and hold # until it registers.
Worked for me.
Mar 15, 2009 | Uniden TRU9585-4 Quad Cordless Phone
Handset out of range - message
We totally unplugged the phone, made sure the battery was charged and reset the phone as though it was brand new, in other words started from scratch. It seemed to work and the phone is O.K. now
Jan 16, 2009 | Uniden TRU9585 Cordless Phone
My handset reads "out of range" but it is sitting on the base.
It could be faulty phones or try replacing the batteries
Jan 10, 2009 | Uniden Cordless Phone
TRU9480 Won't unregister - get "out of range" message. I have followed the instructions implicitly. Jerry
Same manual as lethean but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold "Hang up"and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Oct 24, 2008 | Uniden TRU9480 Cordless Telephone
Lands Phones Logo
41 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
