Question about Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer
Water constantly in the drum of the washer dryer
We have a hotpoint aquarios washer dryer (WD420). Water keeps collecting in the drum of the machine, we perform a pump out function and the water drains no problem, the pump is not blocked. When a wash cycle is finished the clothes are still sitting in water. These is a buzzing noise coming from the cold water supply which stops when you isolate the water supply to the machine. I'm wondering if the solenoid valves are constantly open and just letting water pass into the machine. Any help on this would be appreciated.
Thanks
Kev Gilbert
  • Hotpoint Master
  • 3,463 Answers
It is possible that the inlet valve is sticking,open
Pull the dispenser drawer right out, and see if you can see water trickling in after it has finished.
If you can, then the valve is not shutting off properly, and you will have to replace it.
The other thing you can do is to remove the top cover, and remove one by one the black hoses that go from the valve to the dispenser, and see if you can see water coming through, if you can then replace valve.
The other possibility is that the valve is getting a permanent feed from the board/timer, to check this you would need a meter to test for voltage.
Plz rate my solution.
Thanks.
Posted on Jan 16, 2009
Water not coming to drum
check the water taps are turned on and there are no kinks in the hoses if the water is on and the hoses arent kinked then the fault lies with the water inlet valve (the valve unit where the hoses screw onto on the machine) to access the valves remove the top cover of the machine and directly behind where the hose goes on you will see the electrical valves
Mar 08, 2012 | Hotpoint Ariston Aquarius WD420 Front Load...
My Hotpoint Aquarius WD420 does not wash properly. It doesn't seem to take in any hot water and the drum does not turn, it just sways from side to side and does not move on from wash to rinse and spin....
For those problems, you have multiple issues and need a service engineer. It may be just the hot water intake solenoid, but may also be a problem with the logic board or both.
Nov 13, 2017 | Hotpoint Ariston Aquarius WD420 Front Load...
Sometimes when using the tumble dryer of my Hotpoint WD420 I get a puddle of water on the floor. Doesn't happen with every use. Do you know what the problem might be?
I suspect your dryer vent is blocked or partially clogged.. Also if your washer is not opperating properly putting wet close in the dryer could also cause this.....hope this helps!
Feb 19, 2011 | Hotpoint Ariston Aquarius WD420 Front Load...
Leaking water if rinse and spin
Check your pump is ok and filter not any blockage as this is common cause/ Fiter located within sump hose...bottom of drum take clip off to remove.
Apr 13, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Not pumping water out
You nead to check the filter.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps.
Dec 14, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Aquarius waher dryer
possible blockage ' filter or could aslo be water coming back from the sink if drain hose too low , you may need to raise this....
Nov 13, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint WD420 Washer/Dryer - Not completing cycle
I WOULD FIRST CHECK THE COLD WATER VALVES ONE COULD BE INTERMITTEN
Jun 25, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Aquarius WD420 5+5Kg
The water level vacuum switch are not working , check hose might lose.
Dec 31, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ariston Aquarius WD420 Front Load All-in-One Washer/Dryer Logo
236 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
