Question about HP Pavilion a420n PC Desktop
Antec Power supply 480 watts
How can you test the psu outside of the computer box
  • 36 Answers
At work we have a voltage meter we can hook it up to - or if we suspect its bad we have a spare one we know works that we put in to try.
Posted on Jan 16, 2009
Turn on the computer nothing happen then smell burning from the power supply! turned off right away.
That power supply is probably dead. try your motherboard witha known-to-be-good power supply to determine if your system has survived. IN my experience the failrate for antec sp450 watt psu is close to 40% over 4 years (300 pc:s at university), so there is a high probability that your psu is unrecoverable.
Feb 13, 2011 | Antec SP-400 400-Watt Power Supply
5VSB IS MISSINIG FROM MOTHERBOARD CONECTOR . COMPUTER WILL NOT BOOT WHEN POWER SWITCH ON FRONT PANEL IDEPRESSED . NEED A SCHEMATIC AND COMPONENT DIAGRAM FOR THIS UNIT .
specs are here
http://www.antec.com/specs/SP500_spe.html
This includes 5VSB
There is more info here
http://www.newegg.com/Product/Product.aspx?Item=N82E16817103937
the ATX spec and 20+4 connector pinout (wich locates 5VSB got you) can be found in the Wikipedia article (section 3 in http://en.wikipedia.org/wiki/ATX#ATX_power_supply_revisions has pin out details for ATX rev 2.1).
If your psu is missing 5VSB it is defective and should be returned to manufacturer or retailer if within warranty period. See testing psu articles also.
Jan 19, 2011 | Antec SmartPower SP-500 (ASKU37152)...
Cooling fan for antec power supply pp 303xp does not come on when computer is switched on. Is this a replaceable item or do I have to buy a new power supply?
I THINK I REMEMBER reading that Antec had introduced a feature on some of their psu s where essentially the fan(s) were thermally controlled - if the psu was not working very hard it remained cool and the fan remained off but as the psu got warm with additional load it gradually increased fan speed. Perhaps this the issue you are seeing and nothing is wrong ?
PSU's are generally difficult to open and contain few accessible parts. some you can actually change the fan. I don't know about yours though.
Jan 04, 2011 | Antec PP-303XP 300WATTS ATX12V ATX POWER...
The fan turns on and off for the SL350
you might have a faulty PSU power supply unit or a faulty power point or lead
test the power point first by trying another electrical device then test the lead if these fail you will have to test the PSU using a multimeter making sure your psu is getting the correct amount of voltage and wattage
hope this helps
Nov 13, 2010 | Antec SL350 (smartpower sl350) 350-Watt...
Re: PSU Antec NEO ECO 520C 520W RT This power supply was purchased through Newegg.com on 5 August 2010. It was installed into an Antec 200 Case in the same month. It has operated flawlessly until 1...
I agree with you about the power supply being faulty. Unfortunately FixYa is not affiliated with Antec nor sells or service any computer components.
You need to contact the supplier who sold you the power supply or contact Antec.
Nov 09, 2010 | Antec Computers & Internet
Ive antec pc case with twin 550 psu's there are five sockets
The Power supply willhave to pin #16 connected to pin #15 for an ATX power connector. It would bebest to purchase a Power Supply Tester for about $20.00, which will test allvoltages with a load and give you a go or no go signal. If you want to use ameter to check voltages, here is a link for the pin outs.
http://www.google.com/imgres?imgurl=http://www.smpspowersupply.com/ATX-connectors.JPG&imgrefurl=http://www.smpspowersupply.com/connectors-pinouts.html&h=368&w=478&sz=30&tbnid=nhDjb8Eq1fhorM:&tbnh=99&tbnw=129&prev=/images%3Fq%3Datx%2Bpower%2Bsupply%2Bpinout&hl=en&usg=__4IVO2NEw5aG-llLitG7OvnQVAsY=&sa=X&ei=seVFTL7uEcP7lwehzcHOBA&ved=0CDQQ9QEwBg
Jul 20, 2010 | Antec Neo HE 550-Watt ATX CPU Power Supply
Connection question
It is for the Fan RPM Monitor according to Antec.Check your motherboard for a psu fan connection. Hope this helps & please take a moment to rate this solution. Thanks.
Mar 11, 2009 | Antec Solution Series SL400PEC - Power...
Upgrading power supply
The next time you get a PSU. Tell them what you have. Apparently you got one that is not compatible with your compaq.The power (500 wattage) will work with your MB.
Get an OEM PSU from Compaq(HP).
Dec 02, 2007 | Compaq (253219-002) Motherboard
HP Pavilion a420n PC Desktop Logo
169 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
