Question about Western Digital Caviar WD1600BB 160 GB Hard Drive
I have a western digital (WD1600BB) harddrive that i want to install into my pc so it replaces my 17.2gb one that i have at the moment. I have a windows XP disc, but everytime i hook it up to my computer it doesnt work. ive tried with and without the old harddrive attached. how can i install my new harddrive????
  • 298 Answers
OK... Either your PC uses CS (Cable Select) or MS (Master/Slave) designation to ID drives found on the internal cablesets. Find yours for the 160gb here: http://www.wdc.com/en/images/products/drives/10_pin_jumper.gif
OK, you can't mix types, and you cant put 2 Masters or 2 Slaves on the same cable. Soooooooo
You need to find out what the current HDD uses... so pull the current HDD out, turn it so that you are looking at the backside (where the cable and power plugs in) and look for a group of 6, 8 or 10 tiny pins in a row ( Jumpers)
i have a western digital - moz-screenshot.jpgLook where the Plastic pin(s) are if any and then look on the BACK, Top, PCB and Rear cover for the diagram that explains the position of each.
If your current Drive is CS, then just set your new drive to CS and plug it in (on the same cable)
If your current drive is all alone on the cable and there is a free connector hanging loose, it is most likely set to SINGLE MASTER, and will have to be changed to DUAL MASTER... then set your new drive on DUAL SLAVE and plug it in (on the same cable)
If your current drive is NOT all alone on the cable and there is CDROM attached to it too, it is most likely set to SINGLE MASTER, andyou will leave it alone and you will set your new HDD to SINGLE MASTER as well, and put it on the OTHER cable.
You may have to alter your BIOS settings to see the new 160Gb HDD IF your motherboard is capable of handling that size. Press F2 or DEL or Cntl-S or F12 during boot to get there, then make your changes, save and get out
Once you can SEE both HDD in your system, then you either use a program like GHOST and do a bit-by-bit copy of the old HDD to the NEW, and then make IT MASTER and the OLD one SLAVE (and reset BIOS settings to reflect this) or just leave it in there as 2nd BIG HDD with lots of space.
Good luck
Posted on Jan 16, 2009
Hard drive failure
It's just a Western Digital 320GB SATA harddrive,
http://www.ebay.com/itm/WESTERN-DIGITAL-320GB-WD3200BPVT-22ZEST0-HHBVJHNB-SATA-/170612627298
$229??????
I almost fell out of my chair! lol!
A 320GB SATA harddrive that is 2.5 inches across in width, (Regular laptop size) is W-A-Y cheaper than THAT!
http://www.ebay.com/itm/WESTERN-DIGITAL-WD3200BEVT-22ZCT0-See-list-for-DCMs-320gb-2-5-Sata-HDD-/200882121314?pt=US_Internal_Hard_Disk_Drives&hash=item2ec581ea62
Regards,
joecoolvette
Jan 23, 2013 | Packard Bell Computers & Internet
Windows7 wont read wd1600 caviar as a external drive ???
Did you install the western digital drive softare? There should have been a disk with the drive, which you run when you have installed the drive. It tells the computer there is a new hdd in town. If you don't have the disk, google Western Digital, find their website, and search for HDD driver software, with the model number of your drive. You should be able to download the drivers to your computer, and install them that way.
Nov 05, 2012 | Western Digital Caviar WD1600BB 160 GB...
Jumper settings to connect to mac
If the hdd is a 3 1/2" version you need a power supply to run it. The usb will only power a mini SATA 2 1/2 or smaller as the 3 1/2 needs 12volt supply as well.
Jul 02, 2017 | Western Digital Caviar WD1600BB 160 GB...
My Western Digital Caviar WD1600BB 160 GB hard drive in my dvd recorder is making a clicking sound, how do I test to see if it is the heads that are faulty or the circuit board?
Welcome to Fixya. If you are hearing a loud ticking or high pitch noise on the hard drive it means that the hard drive will be defective anytime soon. If you can take out the hard drive and backup the files on you computer and replace the hard drive on the computer. Loud noise can be caused by a bad spindle or the hard drive or the hard drive is frying inside the dvd recorder.
If you have questions please let me know. Thanks
Oct 10, 2011 | Western Digital Caviar WD1600BB 160 GB...
I bought this HP Pavilion a1610n and it had a dead 250 gig sata harddrive(western digital).I installed a new 250 gig harddrive western digital sata drive in this computer(motherboard is a A7VBX-LA)I cannot...
Here are the original drivers for Xp on top and Vista on bottom not sure which you have or need.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=3239117
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=2093&lc=en&cc=us&dlc=en&sw_lang=&product=3239117
Sep 14, 2011 | HP Pavilion a1610n PC Desktop
My WD3200AAJS will not spin up. I think the PC board is fried. where do i get a replacement for it. I need to get the information from the hard drive.
Just a suggestion;
I would buy another Western Digital WD3200AAJS, remove the circuit board, and install it in the one that needs it.
Copy off the needed info, then discard the drive. Install the circuit board back into the one it came out of, and have a good 320GB SATA Harddrive.
http://www.directron.com/wd3200aajs.html?gsear=1
http://www.iunitek.com/iunitek/index.cfm?fuseaction=shop.dspSpecs&part=1916995
Oct 20, 2010 | Western Digital Caviar SE WD3200JS...
My hard drive could not be detected by my computer. ive tried using other cable and it still wont work. the white led lamp is still blinking and its still vibrating. please help thanks
If you still hear your hard drive spinning inside, running smoothly the same the time you first purchased your hard drive. Here the possible solution
-Replace power cable and Sata/IDE cable
-Try to reset your cmos, possible that you disable your harddrive
-try to slave you hard drive to other PC for the final check if your hard drive is the real problem
Feb 05, 2010 | Western Digital Caviar WD1600BB 160 GB...
Can wd 1600bb be replaced with alternative
Generally your hard drive CAN be replaced with almost any other, just make sure you get the same type, as in IDE or SATA drive for a replacement.
Oct 06, 2009 | Western Digital Caviar WD1600BB 160 GB...
Western Digital Caviar WD1600BB 160 GB Hard Drive Logo
332 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
