Question about Panasonic KX TC1501 Cordless Phone
Setting the number of rings before answering machine kicks in
Hi, I bought this phone second hand without a manual. While it works well, I have had a terrible time with the answering machine kicking in after 5 or 6 rings. Once its been automatically activated, teh phone answers every incoming call within two rings. This is really annoying. I am sure that there must be a way to control the number of rings before the answring service is allowed to start up. Can someone lead me through the steps involved to increase this number? Thanks Max
  • 5 more comments
  • Anonymous Mar 15, 2014
    answering machine doesn't recognize ring settings and picks up after only two rings
  • Anonymous Mar 17, 2014
    how do i change number of rings before answering machine come on uniden dect 6.0
  • Anonymous Mar 18, 2014
    you can see someones number but cannot hear it ringing
  • Anonymous Mar 26, 2014
    My phonr will only give out four rings before the anwserong machine kicks in I want it to ring for longer.
  • Anonymous Mar 30, 2014
    Phone rings once then stops on an incoming call
  • Olga Murgatroyd
    Olga Murgatroyd Apr 27, 2015
    go to answer machine then scrole down to settings then answer and record , select then set arrows left for less rings and right for more rings up to 10 before answer machine kicks in, hope this helps
  • Olga Murgatroyd
    there is an answer only setting but i opted for answer and record
  • 944 Answers
Here is the link to the user manual; http://service.us.panasonic.com/OPERMANPDF/KXTC1501B.PDF Check page 19 - you can set the answer rings from 2 to 7 Hope this helps :)
Posted on Jun 19, 2007
SOURCE:
How can i limit the number of rings before the answering machine kicks in on my panasonic 6.0 phone
Answering system settings Number of rings before the unit answers calls You can change the number of times the phone rings "Ring count" before the unit answers calls. You can select 2 to 7 rings, or "Toll saver". The default setting is "4". "Toll saver": The unit's answering system answers at the end of the 2nd ring when new messages have been recorded, or at the end of the 4th ring when there are no new messages. If you call your phone from outside to listen to new messages , you will know that there are no new messages when the phone rings for the 3rd time. You can then hang up without being charged for the call. 1 {MENU} i {#}{2}{1}{1} 2 {V}/{^}: Select the desired setting. i {Save} i {OFF}
Jan 17, 2018 | Panasonic Lands Phones
How do you change the number of rings before machine kicks in
Press and hold the STOP/SET button for two seconds. After the time and day you can change the rings to answer.
Full details are in the "Changing the Settings" section in the third column of the manual. If you need a manual, you can download one at
http://www.home-electronics.net/USER-GUIDES/29888_DOM_EN_AN_IB.pdf
May 27, 2011 | GE 29888GE1 Digital Answering Machine
Setting number of rings before answering machine kicks in
Probably a cordless right?If it is,there should be a function button on the handset.Without pressing to dial out,press or hold down the function button.If there is a directional type button,you may have to press down or keep pressing the function button to cycle through the options.Once you find the ring set,it will probably require the directional button up or down to change the number of rings.Function could also be on the base,but it's usually on the handset.You may have to play around with a couple other buttons if there is no directional button but most seem to have the directional button these days. Good luck!
Jul 22, 2010 | Uniden Lands Phones
How do you set the number of times the phone rings before the machine picks up on my GE answering machine? I can not find the manual
Hi kcee
I think I did find the manual here :
http://157.254.235.130/public/347A8329-0001 (Rev. 1 E&S).pdf
and here :
http://phone.manualsonline.com/manuals/mfg/ge_appliances/29827.html
you can find more types here :
http://phone.manualsonline.com/manuals/mfg/ge_appliances/ge_appliances_answering_machine_product_list.html
You can find General Electric home page here:
http://www.geappliances.com/electronics/
I suggest you contact GE on the link to get the manual and understanding your answer machine with a reply :
http://www.geappliances.com/service_and_support/contact/form_operating.htm
FOR Thomson Consumer Electronics :
you get there homepage here :
I did try to find the manual for your specific phone, but could only find these answer machines here (previous and next model number) :
http://www.home-electronics.net/ge/pc/IB/29871GE3_IB.pdf
http://www.home-electronics.net/ge/pc/IB/29869GE2_IB.pdf
source :
http://www.home-electronics.net/ge/pc/user-manuals.asp
on the second manual here on page 9 you find the settings to answer. I think they have used the same shortcuts for these models. They write ;
### This feature is used to set the unit to answer a call after
a specific number of rings.
The unit announces the rings to answer. To change,
press NEXT or PREVIOUS. To set and go on to the next
item, press SET.
1. Press and release NEXT or PREVIOUS until the unit
announces and displays the correct number of rings
for the answerer to pick up.
2. Once the rings to answer is set, press SET. The unit
announces the rings to answer, then enters the
incoming message length menu.
TOLL SAVER
The toll saver is the final setting in the Rings to Answer..........####
For the GE model you find these features on page 17
One last thing, you can contact Thomson Consumer Electronics for more specific answer or get the manual here :
http://www.home-electronics.net/ge/pc/contact.asp
they have also a phone :
"For customer service assistance, dial 1.800.448.0329. Our hours of operation are Monday thru Friday, 8am to 8pm Eastern, Saturday and Sunday 10am to 7pm Eastern."
Hope that helps
IF NOT then try to return here
Have a nice time over there
Please rate my answer
Jan 02, 2010 | GE Cordless Phone & Answering Machine...
My mobile goes direct to answer machine without ringing
your service provider will provide you with a code to alter the settings for the answer phone , you can adjust how long before the answer phone kicks in and whether the answer phone is on or off
Jul 19, 2009 | Cell Phones
Can I set the ringtone to ring for longer?
Try typing the following into your phone, then hitting SEND - replace the words in brackets with the relevant numbers):
**61*(voicemail or diversion phone number)**(seconds delay before diverting)#
This works for "Divert on No Answer". To check the status of this diversion use *#61#
Jan 20, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
I have a GE29869GE2 Answering machine, no instructions anymore. How do I change the number of times the phones rings before receiving the greeting kicks in?
1. Press set button
2. Use next and previous buttons to select number of rings setting and press set.
3. Select the number of rings you want.
4. press set again to save setting.
I hope this helps. Here's the manual:
29869GE2 Digital Answering Machine
Dec 13, 2008 | GE 29869GE2 Digital Answering Machine
Have to be near fax machine to recieve fax
The Rings to Answer feature might not be set to answer after the
appropriate number of rings for your office setup.
If you have a voice mail service at the same phone number you use
for fax calls, you must receive faxes manually, not automatically. For
information on how to receive faxes manually, see receive a fax
manually from a phone
on page 48.
If you have a PC modem on the same phone line with your
HP Officejet, check to make sure that the modem’s software is not
set to receive faxes automatically. Modems with this auto fax
receive feature turned on will take over the phone line to receive all
incoming faxes, which will prevent the HP Officejet from receiving
fax calls.
If you have an answering machine on the same phone line with
your HP Officejet, you might have one of the following problems:
Your outgoing message might be too long or too loud to allow
the HP Officejet to detect fax tones, and the calling fax machine
might disconnect.
Your answering machine might not have enough quiet time after
your outgoing message to allow the HP Officejet to detect fax
tones. This problem is more common with digital answering
machines.
The following actions might help solve these problems:
a. Disconnect the answering machine and then try receiving a fax.
If faxing is successful without it, the answering machine might
be causing the problem.
b. Reconnect the answering machine and re-record your outgoing
message. Make sure the message is as short as possible (no
more than 10 seconds long), and that you speak softly and
slowly when recording it. Try again to receive a fax.
If you have a special ring pattern for your fax phone number (using
a distinctive ring service through your telephone company), make
sure that the Answer Ring Pattern feature on your HP Officejet is set
to match. For example, if the phone company has assigned your
fax number a double ring pattern, make sure Double Rings is
selected as the Answer Ring Pattern setting. For information on
changing this setting, see change the answer ring pattern
(distinctive ringing)
on page 63.
Note that some ring patterns cannot be recognized by the
HP Officejet, such as those with alternating short and long ringing
patterns. If you are having problems with a ring pattern of this type,
ask your phone company to assign a non-alternating ring pattern.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 20, 2008 | HP Officejet 4215v All-in-One Printer
Phone rings many times with no answering message coming on and no messages recorded
I can't seem to get the security code entered.  It won't change.  None of the numbers will change when I try to set it up.
Jan 28, 2008 | GE 29878GE1 Digital Answering Machine
Answering machine atarts working after 2 rings only
Press the 'Change' button
Press the 'Setup' button until you hear the voice say "Number of rings"
Then use the "Skip" and "Repeat" buttons to change the number.
Press the "Change" button to finish.
Jun 11, 2007 | AT&T 9350 Cordless Phone
Panasonic KX TC1501 Cordless Phone Logo
652 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
