Question about Maytag PAV2300 Top Load Washer
Maytag Performa pav2300 spins slow does not agitate
Cant remember how old the machine is but recently it stopped agitating, and will spin slowly for awhile then stop all together. The belt is intact and has minimal slack. When I rotate the pully underneath it moves the basket but when i rotate the pully in reverse the basket doesnt move. ( I read that the motor goes in one direction for spin and reverse for agitating) Ive read a few forums and answers but am confused about what it might be. The basket moves with some force when the lid is open and the dial is on spin, but it does not spin freely. What next?
My performa 2300 makes a loud screech when it stops spinning. What is going on?
Posted on Jan 03, 2009
  • 164 Answers
Are you missing any sox? you might have a sock (or other garment) wedged between the inner and outer tub.
Posted on Jun 22, 2007
SOURCE:
PAVT920AWW Noise in wash cycle no agitation
Your Belt still needs replacing or to be scuffed up with sand paper. If thes fails you need either new tub bearings or a transmission. either a 250-300.00 repair so tr the belt and rotate drain pump rotation while the belt is off
Mar 29, 2009 | Maytag PAV2300 Top Load Washer
Agitates but won't do anything in spin mode, won't drain
If it has a mechanical timer, that's most likely your problem. Not a hard fix. Most any "Do It Yourself" book can be used to show you how to swap timer. Getting one may be your biggest problem.
If it agitates, it's not the motor. You said the time seems to stop.
Feb 16, 2009 | Maytag PAV2300 Top Load Washer
Agitator
A serious transmission problem, I doubt that it is worth the cost of repair, sorry.
Aug 21, 2017 | Maytag Performa PAV2200
Does not spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Sep 24, 2007 | Maytag PAV2300 Top Load Washer
Maytag won't spin or agitate
I have had the same problem and found that the teeth on the under side of the agitator had been worn down to nothing... I assume this is from years of over loading (not from me) and so the agitator could not spin any more... i would tighten the bolt that holds th agitator on and it would come loose after a few loads. So my solution was to get a little bit longer bolt and newer plastic washer and tighten it as tight as i could and it seemed to work. Versus buying a new agitator base that would cost about $20-$30 and would have to wait for the part to be ordered. hope this helps
May 26, 2007 | Maytag PAV2300 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
985 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
