Question about Jenn-Air JFC2089HE French Door Refrigerator
JFC2089HES Refrigerator too cold!!
My refrigerator thermostat is set to 38 degrees...but the refrigerator is reading 30-31 degrees..and everything is freezing.
Had the ''authorized'' repair person out once...he just moved some bottles in the back of my fridge..said it was ''blocking the vents''...that did absolutetly nothing.
so, they came back out again, this time it's a control board..that's $300..plus $200 installed...so $500 bucks (+ the 150 on the original call)...that's crazy to me.
The technician, nor A&E Factory service, will tell me the part number for the board...so I have no way of checking the price. I downloaded the whole parts list...there are only 2 control boards...one is 50 bucks..and the other is like 110 bucks if I buy direct..but I don't know which is the right one?????
Can anyone help? Which board would be the right one to replace? Again, the set point is 38 ... but the reading (and actual temp) is like 31.
I'm very dissapointed with Jenn Air and A&E factory service...
the dr
  • 447 Answers
SOURCE: jenn air french door refrigerator broken by repair company
Ill be glad to shed some light on this for and stand behind this as I too am a Factory authorized dealer. These units did come with faulty compressors failing about 80% of the time. What happens is the compressors get worn and stop starting properly. You can make them work temporarily by installing a 3n1 (basically makes the compressor have more starting torque). However they eventually get so worn that even a 3n1 cant start it. Ive never read any bulletins from any major company (Frigidaire used this same compressor) saying a 3n1 voids warranty. It certainly didnt damage the compressor it was already damaged when the tech installed the 3n1. Also these compressors are failing at such a high rate its not even questionable that the 3n1 damaged anything. Honestly it really sounds to me like the tech is nit-picking not wanting to do the labor intensive job of changing the compressor. He may not even be able to. Also the new compressor should be a 8201555 (I just did one this afternoon ---thats how common this is) and its a much more reliable Embraco compressor. Once its installed you should have no more compressor issues for many years. Feel free to have anyone who questions my solution to call anytime 850-510-9563 (Joey Shearer, Precision Appliance, Tallahassee, FL)
Posted on Jan 15, 2008
  • 2336 Answers
SOURCE: jenn-air JFC2089HES french door
Check the water hose and make sure is not kinked.
The hose might be frozen as well.
Posted on Mar 31, 2008
  • 1122 Answers
SOURCE: jenn-Air Refrigerator JCB2059GES freezes
your thermostat is bad,get the model number from inside and call your local appliance store and get a new one,let me know,thanks-mike
Posted on Jun 23, 2008
  • 1214 Answers
SOURCE: Fridge keeps freezing
Chances are, they replaced the wrong parts, or didn't replace all the parts, assuming they replaced an electric motor kit. I would need to know the P/N of the electric motor kit to confirm what was replaced.
Based on the fact that it froze the drinking water tank, and if they replaced the electric motor kit, the problem is more likely the temperature sensor or the control board.
Let me know what the P/N is of what they replaced and we can be more precise.
Posted on Jan 14, 2009
  • 13 Answers
SOURCE: My Jenn-Air JSD2695kes. The refrigerator side is not cooling.
You most likely have a defrost cycle problem. Either a bad defrost heater, timer or thermostat. Jenn Air has put an Adaptive Defrost circut in the top of the Refrigerator section. You can find troubleshooting directions at ACMEHowTo.com
Posted on Jun 03, 2010
My refrigerator is a double door and top portion is not cooling yet it reads 38 degrees. Why is it not cooling?
unplug the power cord for 10 minutes, then set again the thermostat at your temperature required.plug it again and wait for two hours.
Dec 31, 2014 | Refrigerators
What should the temperature inside the refrigerator be, I have it set at 37
On the fresh food side you have it set at the proper temperature. Most thermostats have a scale from 1 to 7 or 9. If you set the thermostat at 5 this equates to about 37 degrees. Thermostat do lose sensitivity after a while and need to be replaces. The switch inside the thermostat wears out and the sensing bulb sometimes loses the fluid inside the sensor and the thermostat stops controlling temperature. So sounds like you have it set properly.
Oct 14, 2014 | LG LFX25960ST Stainless Steel French Door...
What degree should it hbe set on
What? Proof read your question. What is a hbe? Set the freezer at, at least, zero. Set the refrigerator at 38, if there are separate thermostats. I hope, I answered your question. Good luck.
Sep 07, 2014 | LG LRFD22850 Bottom Freezer Refrigerator...
What does 34F ER mean
Put a freezer thermometer in the freezer and see if it reads +34 degrees, then put it in the refrigerator. If the freezer reading is above 0 degrees, say +34, then the freezer is too warm. If the refrigerator is reading 34 and the freezer is way cold, then the refrigerator is getting too cold. This could be either a thermostat setting too cold or the sensing isn't reading properly or a much more serious issue. Generally a refrigerator should be no warmer than +40 but not freezing either +32 degrees and a freezer should be about 0 degrees. Make sure nothing is blocking the air flow duct work or where the sensors are located.
Aug 14, 2014 | U-Line Echelon Combo® CO2175DWR Compact...
Refrigerator thermastat set to 37 degrees but registers at 28. Freezer set at 0 degrees but registers at -2. Frig/freezer do not feel that cold but vegetable bin (produce bin) in refrigerator is...
i have never seen the problem
my idea is the thermostat is bad. but won,t both of them be bad.
you try to check the damper motor swithch and damper motor
good luck
Jan 12, 2011 | Frigidaire FRS26R4A Side by Side...
How to set fridge temp
    1. The first thing you must know is that your refrigerator should be set at 37-38 degrees. Anything at 40 or higher and you are risking food born illness (food poisoning) or spoiling your food. Place your magnetic thermometer in the refrigerator.
    2. Set your dial on your refrigerator to the second lowest setting. (If your refrigerator is already equipped with a digital thermostat, simply set it for 37 or 38 degrees and do not move on to the next step)
    3. After 2 hours, check your thermometer reading. If your reading is 38 degrees, there is no need to go higher and you are ready to put your groceries in. Be sure not to open and close your refrigerator during these two hours or your temperature reading will be incorrect.
    4. If your reading is higher than 38 degrees, move your dial up to the next coldest setting and repeat the steps every two hours until you reach the correct temperature for your refrigerator.
    5. Once you have reached the correct refrigeration temperature for your refrigerator, place the magnetic thermometer in the refrigerator permanently and watch for changes.
    Typically, your refrigerator temperature will need to be adjusted with the seasons, a higher setting in the summer and a lower setting in the winter.
Dec 19, 2010 | Freezers
How to set a temperture
By keep your refrigerator or freezer too cold, it unnecessarily wastes electricity. The recommended temperature is 37 to 40 degrees for the fresh food compartment of the refrigerator. The recommended temperature for the freezer compartment is 5 degrees. If you have a separate freezer for long-term food storage, it should kept at 0 to -5 degrees.
The following steps below is how to set the temperature of your refrigerator.
Step 2
Step 3
Step 4
Step 5
Hope this helpout and take care.
Aug 12, 2010 | Refrigerators
Produce freezing in fridge
check your door seals and replace the thermostat controll and adjust the vent door cables
Jan 14, 2010 | Maytag MTB2456G Top Freezer Refrigerator
Can this refrigerator be used in an unheated garage?
Yes, You can use most any refrigerator in an unheated area. Just be aware that if it is in a below freezing area for a long period of time that the cold may penetrate enough to get the refrigerator temperatures below freezing also.
Nov 18, 2009 | Refrigerators
Jenn-Air JFC2089HE French Door Refrigerator Logo
166 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
