Question about Vacuums
Sebo automatic x1.1 loss of suction
my sebo upright vacuum cleaner has lost suction from the main head, the hose seems ok. the clog light is not showing.
please help
Knee-High in DogHair
  • gailcrumpet Jan 28, 2009
    thank you. tried all of that but still no suction. off to the repair shop...
  • 328 Answers
Check that the dust channel from the sole plate/brush head isn't clogged. Open the trapdoor (usually orange in colour on the base) and inspect the dust channel - sometimes dog hair can get trapped between the main dust channel and the feeder. Other than that take off the main hose and see if there's a clog down there as well as the main part where the wand locks in at the back. Its reasonably easy to get a clog out from a Sebo X range model.
Posted on Jan 23, 2009
The suction is not working
some machines have a 'safety' built in where if the belt is broken, other items like the lights don't work. Check and replace the belt first. It's also very important to keep the tubes that suck air unclogged, and clean the filters EVERY time you use it
Dec 31, 2014 | Sebo Felix Classic Bagged Upright Vacuum
How do I clear a blockage
Try removing your hose from the bag housing (pinch retaining ring and pull out) and re-inserting in reverse order. Turn the vacuum on and suck the clog into the bag. This will usually clear a clog from the hose. If the clog is in the power head (base), you can usually access it from the top side of the swivel neck or the orange access door on the bottom of the chassis.
Sep 23, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo upright barged hoover- good suction using hose, brush wont turn, sounds fine when running, nasty wineing noise when stopping?? help!! i love my hoover, have checked for bolckages....
The real clue seems to be the brush is not turning, a bad belt is possible or a blockage at that head, if you cannot get the brush moving the rest does not matter.
Dec 03, 2012 | Sebo Felix Classic Bagged Upright Vacuum
The vacuum seems to have lost a lot of suction power and it is only a month old. Seems like there is a clog or something, all filters are cleaned and after a vacuuming session, nothing is in the...
sounds like there is blockage in the suction hose -- lay the machine down and remove the lower floor plate and clean out the hose area where it bends down to the floor unit ( use a wire coat hanger to fish out the blockage ). also check the main hose for any obstructions.
Feb 17, 2011 | Bissell Cleanview Helix Deluxe Bagless...
Light on for "full bag or clog." I changed bag,
Check the airflow tube behind the brush. This is a common place for clogs. The hose is more common, especially at elbows, like where it attaches to the tank. Another possibility is a dirty filter. Check this first to rule it out, then check the rest.
Jan 26, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
Panasonic MC-E468 vacuum cleaner loss of suction
HI If the cleaner is loosing suction make sure to check all inspection tubes and the dirt channel hoses after the spinning brush. Also check the main hose for any clogging. One of the worst faults of this model is clogging hoses. Hope that helps you.
Feb 27, 2009 | Panasonic MC-E583 Bagged Upright Vacuum
Sebo automatic x1 -
Check the hose for a clog, also check the dirt inlet by the brush roll, it may have a clog also.
May 20, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
SEBO vacuum cleaner
Take the hose off and see if the light is still on or is it off. If it is off, then there is a clog in the hose. While the hose is off, drop something thru it and see if it comes out the other end. Press the retaining clip and the hose will disconnect. Separate the power head from the handle unit to make sure there is no clog by the brush roll. If it is still on then probably the computer controller, part # 5740ER has a problem. It is located in the power head.
Feb 15, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Sudden loss of suction.
Check the inlet down by the brush roll to see if it is clogged. Also check the belt to be sure it is ok. Is there suction at the hose? If not then it is still clogged.
Oct 30, 2007 | Kenmore 33721 Upright Vacuum
Vacuums Logo
122 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
