Question about RCA 27F530T 27" TV
Tv wont stay on channel
Ok trun tv on then few minutes later tv jumps of channel and just flips through like its channel surfing
  • jhlittle Nov 28, 2007
    i had the same problem i took the board out and took it to the local tv repair man he put 6 new switches in it and only charged me $16.00 and the tv works like new.
  • tn_tiger Jan 11, 2008
    My TV has started doing the same thing. I think the solutions sound good but how do I find and remove the circuit board you've mentioned?
Same thing: tv self powered on, channels and volume went randomly up and down. The problem was due to bad contacts in front buttons (not the infrared controler) and solved by simply shaking and releasing the pression on the front buttons. Thanks to joshv
Posted on Jan 14, 2008
    Scholar:
  • 77 Answers
This TV actually has bad buttons I've seen many of them, usually those switches never go bad but on this tv they do. The easiest thing to do is remove them, and use the remote, who uses those buttons anyway. You can slide out the circuit board and you will see the small switches in front if you can solder just remove remove them if not you can cut them out just be careful none of the pins remaining in the board are touching one another.
Posted on Jun 19, 2007
SOURCE:
My Maxent 58 plasma tv turns off by itself somethimes after hours of playing sometimes after minutes
Sounds like some loose contact with any of the connectors inside. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
May 11, 2014 | Maxent MX-42V1 42 in. Plasma Television
Element elchw321
Firmware corrupted. Re-install it with the latest one. Contact any service technician. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 25, 2014 | Televison & Video
2003 EXPEDITION CHARGING SYSTEM OK BUT STILL WONT STAY CHARGED
Go to AUTOZONE,they will test you electrical system for free,takes only a few minutes.
Nov 25, 2012 | Ford Expedition Cars & Trucks
My Dell W3707C LCD TV won't quit flipping. The only button that works is the power button. I can hold the channel button down and flipping stops for about 2 minutes and then it starts flipping a
one of two basic things here, unplug set to see if after a while it helps, and if channel scanning up or down on its own suspect the button associated with the direction it changes is a bad one.
Oct 29, 2012 | Dell W3707C 37 in. LCD Television
98 Buick Regal won't run unless hooked for a jump.
you may have a bad ground, or the ignition switch needs to be replaced.
Jul 28, 2012 | 1998 Buick Regal
RCA P56950 Powers on then 10 mins later powers off, repeats cycle. Then channel display in TV changes by itself
may be some thing is stuct on the controt pannel power button or others check. try this it may work
Jun 04, 2012 | RCA P56950 56" Rear Projection Television
My Vizio plasma TV won't change channels with the remote or side buttons, but if I input a channel number, it will change that way.
Try unplugging the TV for a few minutes and then doing an auto channel search through the menu button. That has solved my problem, at least for the time being.
Aug 11, 2008 | Televison & Video
My tv is getting on my nerves! it has clouding/blotchiness in dark scenes and it mixes up/ looses chanels,what can i do?
TRY AUTO PROGRRAMMING AL YOUR CHANNELS AGAIN. IF THIS DOES NOT FIX IT YOU NEED A MAIN TOTAL ASSY THE BLOTCHINESS IS A LCD PANEL PROBLEM. THE PANEL NEEDS REPLACING.
May 26, 2008 | LG 42LC7D-UB Television
Tv won't stay on
MY SAMSUNG 27# MODEL TXT27820 ONLY NINE MONTHS OLD SHUTS OFF BY ITSELF AND WILL NOT START AGAIN
May 10, 2008 | Samsung TXJ2754 27" TV
RCA 27F530T 27" TV Logo
81 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
