Question about Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control
Transmitter or receiver stopped working.
Transmitter has a new battery and the red light goes on but nothing happens.  My baby grand daughter had played with transmitter before this happened.
The Hampton Bay ceiling fan is the 52" Mediterranean, model 740 154.
  • rjansen887 Jan 18, 2009
    My grand daughter would have had to open the remote to change the code. This did not happen and I have already checked the code to be sure the codes matched. I need another solution.
    Rob
    Genius:
  • 1,011 Answers
Dear,
is remote working with any other device as it universal. if not then remote can be faulty itself or having some issue.
regards,
Posted on Jan 18, 2009
  • 10,515 Answers
  • 45 Answers
hi rjansen887,
Adjust the dip switches:
Each fan/remote combination is set to work on a specific frequency, much like tuning in a specifc radio station. Some fans allow you to set this frequency by means of a set of small switches called "dip switches". There is one set located inside the remote, and the other set would be position on the fan, with the remote receiver electronics. This would be either on top of the motor, or inside the switch housing or ceiling canopy. These switches "tune" the remote and fan (received) to the same "station" and therefore must be set to the same setting. If a fan is not responding to the remote you can check to make sure that the switches are set to the same setting in both locations, and/or try a different setting. They are also useful if you have two remote fans, you will want to be sure each fan is set different so the remotes do not interfere. Lastly, if some other wireless device is interfering with the fan (causing it to turn on and off seemingly at random) such as a garage door opener or cordless phone, you can try a different setting on the dip switches.
good luck n please rate this solution
  • 98 Answers
Hi.
Maybe your granddaughter has changed the code that remote controller needs to communicate with other devices.
Check your manual on how to change the code and what exact code do you need.
If you need further assistance, feel free to ask.
Your responses are intended to improve the level of service provided. Please rate your experience.
Remote for ceiling fan light stays on
Sounds like you need a new transmitter. The light is a battery indicator light.
Mar 06, 2014 | Savoy House Dryers
Tip
Genie Intellicode Remote Transmitter Programming Instructions
USE ONLY WITH SERIES II ELECTRONICS.<br /> Older Transmitters and Receivers will not work with these new electronics. There are no Security Code Switches inside the Door Operators, Transmitters and Receivers.<br /> <br /> <br /> To Program Receiver <br /> Step 2-1 Locate the Learn Code Button and Radio Signal Indicator on the Power Head Receiver of your Door Operator.<br /> <br /> Step 2-2 Press a Transmitter Button once within 30 seconds.<br /> <br /> Step 2-3 Press and release the Learn Code Button<br /> &bull; The Radio Signal Indicator will blink approximately 2 times per second.<br /> &bull; The Radio Signal Indicator stays lit - SOLID.<br /> <br /> Step 2-4 Press the same Transmitter Button within 30 seconds.<br /> &bull; Radio Signal Indicator will go out.<br /> <br /> NOTE: If a second Transmitter Code is not confirmed within 30 seconds or if a different Transmitter Code is sent, the Radio Signal Indicator will blink approximately 4 times per second, then programming will stop. If programming stops, repeat Steps 2-2 through 2-4.<br /> <br /> Step 2-5 Repeat Steps 2-2 through Step 2-4 for each Transmitter, Wireless Keypad or other access device to be learned.<br /> <br /> NOTE: A maximum of 7 Transmitter, Wireless Keypad and other access device Codes can be stored into Receiver Memory at one time. If a Transmitter becomes lost or if you want to delete a Transmitter, Wireless Keypad or other access device, proceed to ERASING ALL RECEIVER MEMORY.<br /> <br /> <span style="font-weight: bold;">Multi-Button Transmitters</span><br /> <br /> NOTE: Only ONE button of a Multi-Button Transmitter can be programmed into a single Receiver. The other buttons are to control other Door Operators.<br /> <br /> NOTE: If you are replacing a lost or stolen Transmitter:(1) Erase ALL Transmitter Codes from the Receiver memory. (2) Reprogram the Receiver with the remaining Transmitters Codes.<br /> <br /> <span style="font-weight: bold;">Erasing All Receiver Memory</span><br /> <br /> Step 4-1 Press and HOLD the Learn Code Button for 10 seconds or until Radio Signal Indicator goes out.<br /> <br /> <span style="font-weight: bold;">ALL Transmitter Codes are erased from Receiver memory.</span><br style="font-weight: bold;" /> <br /> Step 4-2 Reprogram the Receiver with the remaining Transmitter Codes (Repeat Steps 2-2 through 2-4).<br /> <br /> <span style="font-weight: bold;">Step 5-1 Battery replacement</span><br /> &bull; Slide Battery Cover off of Transmitter back.<br /> &bull; Replace with new batteries.<br /> &bull; Slide Battery Cover back on.<br /> <span style="font-weight: bold;"><br /> Step 5-2 Visor Clip installation</span><br /> &bull; Slide Visor Clip into back of transmitter until it snaps into<br /> place.
on Jun 21, 2011 | Genie Company IntelliCode GICT390-1BL...
I have a Harbor Breeze White 3-Speed Combination Fan and Light Control (Model #: WC-100L) that has stopped working. The red power light does not even light when I push the buttons. Any idea on...
First of all, you bought a cheap store brand fan! The red light is a battery indicator light, so check your battery. If that doesn't work, then you probably need a new transmitter or receiver or both.
Oct 17, 2013 | Dryers
Skytech 1410 fireplace remote (8 yrs. old) has stopped working. Replaced batteries in the transmitter. The red light lights up when
It may need to be re-synchronized:
Make sure the receiver's slide switch is in the REMOTE position.
Press and release the LEARN button on the receiver.
When you hear the "Beep", press and hold the ON or OFF button for about 2 seconds on the transmitter.
You will then hear a series of beeps that indicate that your new transmitter has been accepted by the receiver.
If you press the LEARN button on the receiver and you hear no beeps, the receiver is unable to retain any more transmitter codes
(make sure the transmitter battery is properly installed and fully charged).
To delete all of the transmitter codes on your receiver, press and hold the LEARN button for 10 seconds. Then you will hear a
series of beeps, indicating that the receiver's memory has been cleared.
It could also be dead after 8 years. A new unit can be purchased here: Skytech Remotes. I would even suggest on of the new styles with a built in timer or thermostat.
Nov 08, 2012 | Skytech 1001-A Fireplace Remote Control...
Just replaced the battery remote will NOT work.... I have a very high ceiling.... this is getting annoying.... when I press the remote I get a red light wether I ask for fan or light.... light just blinks...
Some remotes have a learn button in them, when it lose its power you need to relearn it. Hold the small button for about 5 seconds, to reprogram it with the receiver. If it doesn't work ,then your receiver may need to be replaced.
Sep 03, 2011 | Hunter Ceiling Fan Remote Transmitter...
Remote does not do anything, it has a brand new battery. red led works, but no action on the fan or light. thank you
when you remove the battery cover, there is a set of white switches called dip switches. they can be up or down. the transmitter and receiver have to be set to the same code. both have to have the same combinations of up and down switches. the receiver is usually mounted behind the canopy on the fan where the downrod goes into the electrical box. if the remote came with the fan, check hunters website to download an owners manual to tell you where the receiver switches are.
Nov 20, 2010 | Hunter Ceiling Fan Remote Transmitter...
I have wireless speakers and the transmitter stopped working. Nothing happens when you plug it in--??? It's only a month old. AW872
Hi I also post in here , so that you can let me know how it goes.
Try unplugging the transmitter from power adapter, if it also has batteries remove them. Also unplug transmitter audio cable.
Then remove batteries/unplug adapters from speakers.
Wait few minutes and reconnect the system.
This is a proper hard reset, and can fix minor problems.
If when you re connect the transmitter does not glow, or you do not have sound on one or both channels then there is a fault.
Check the transmitter audio cable, a short in there can cause troubles.
If you find no problems , then unit is defective, as it is under warranty contact Acoustic Research to validate the warranty here and get the transmitter or the whole set replaced.
http://www.acoustic-research.com/homedecor/HomeDecorInfo.do?ACTION_TYPE_ID=ACTION_TYPE_CONTACT_INFO
Feb 13, 2009 | Audio Players & Recorders
Re: Tevion Sound Wireless Headphones - Model No 82010 I puarchased the above on the 31.7.08 I can recharge the 2 NMH AAA batteries rated 500mah (as supplied) on the transmitter o.k. I have however,...
CHARGE THE NEW AKUS IN ANOTHER CHARGER AND THEN USE THEM AS USUALY.
SEE THE CURENT SUPPORTED BY THE ORIGINAL GHARGER,
IF IT IS AT LEAST 100mA , IT SHOULD CHARGE YOUR NEW AKU ! BUT MAYBE THE CIRCUIT INSIDE TX DO NOT SUPPORT
AKUS BIGGER THAN 500mAh .
YOU SHOULD RESPECT THE SPECIFICATIONS GIVEN BY THE PRODUCER AND IT WILL BE OK !
Aug 05, 2008 | Audio Players & Recorders
Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control Logo
106 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
