Question about Kenmore 62602 Electric Dryer
Dyrer cutting off motor making straining noise then cuts off
DRYER CUTS OFF WITH IN 10 MINUTES AFTER STARTING THEN WILL NOT START UNTILL COOLS DOWN..
  • 535 Answers
U r moter bering is jaamed tahts y moter taking so much load tahts y moter stoped due to over hting so u need to do this open the moter put gress on the barring
Posted on Jan 16, 2009
    Genius:
  • 2,920 Answers
The motor is trying to go out on you. you need to have it replaced before you end up with a fire
  • 124 Answers
Call the manufacture and tell them what is all going wrong you can find there info on their website
Kenmore electric dryer 70 series - it starts, motor sounds horrible, turns, gets hot, almost a burnt smell. what do i do?
Greetings,
it sounds like its bad...they usually will drag slightly when you push start. in other words, you can hear a delay in it starting...almost a hum, but not always...if its smelling like burnt wiring..it usually cuts off and will not come back on until it cools down..
Are you sure its the motor thats making noise?? if a roller goes bad..it will go thump,thump, thump and they make alot of noise too...does it stop during the cycle? if you have more question, let me know and hope this helps
Feb 03, 2011 | Dryers
It starts and heats up after 20 minutes cuts off and makes sound like it wants to start. then shuts off completely and starts back in about an hour for 20 minutes and cuts off.
You have a bad motor there is a safety feature built into the motor to where when it gets hot it will shut off so it wont start a fire. After the motor cools off in the time frame you listed it will come back on but repeat the same thing all you can do is have the motor replaced by a qualified service technician or buy a quality used machine or a new one if the dryer is 10 to 15 years old not worth putting a motor in it will run $125 to $150 for just a new motor but sorry for the troubles.
Jan 05, 2011 | Dryers
My kenmore dryer 66512692 runs for approx. 10 minutes and cuts off. I can come back to it usually a couple of hours and it will run for another 10 or 15 minutes and stop. It will complete the Air Dry...
Sorry to read about your problem, I hope this helps you out.
Clean your dryer vents, and lint filters. You may need to clean vent from wall to outside. to test this.. unhook vent pipe from wall..and run dryer and see what happens.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
wer
Dec 25, 2010 | Kenmore Dryers
Dryer cuts off after 10 minutes
Agree with you. Make sure the lint collector is clean and ditto for the vent. If it goes up to roof have to check it there also to make sure there are no obstructions whatsoever in vent line. Unit is turning off because it is overheating. If lint collector and vent is squeaky clean and unit blows out like crazy then the temp switch is opening up prematurely and might need replacement or jumping - your call. If you want to check for part go here Search Over 2 1 Million Appliance Parts
Sep 06, 2017 | Whirlpool LER4634J Electric Dryer
Dryer cuts out
Either a bad motor or power problem . If dryer has been there for a while and worked fine , then motor is bad . If dryer has recently gotten there , check the cord to make sure it's connected properly , and the wall receptical has 240 volts where it should be ( both 1/2 " straight terminals ) The " L " is ground .
Aug 20, 2009 | Kenmore 659 Electric Dryer
Our Whirlpool dryer runs, then cuts out. After a
Sounds as if your motor is defective. It has an internal thermal switch which cuts the motor off before it gets too hot. After it cools, the switch makes up and the unit is able to run again.
Aug 01, 2009 | Dryers
Kenmore 90 series gas dryer
possible motor overheat ..if unit has a lot of lint or has had vent problems now or in past lint may have accumilated around motor and caused it to overheat and shut off.. probably to late to save motor
Sep 29, 2008 | Kenmore 73952 Gas Dryer
Kenmore king size capacity 90 series
could be thermal overload in motor its a motor protector in the motor when the motor gets hot it cuts power to the motor when motor cools it closes and resets age of drier counts some times you can take drier apart and blow dust out of motor and will fix now if the door is not closing tight vibration can cause door switch to break contact that will do it too most of time motor or relay must be replaced
Jan 06, 2008 | Kenmore 63942 Dryer
Kenmore 62602 Electric Dryer Logo
20 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
