Question about Konica Revio KD-410Z Digital Camera
It wont close
I think someone dropped my camera, and i can turn it on, but as soon as i begin to take a picture it says:"system error S0042" And then when i turn it off the lens will not go in. please help
  • KenCarroll Dec 30, 2007
    I have a similar problem after dropping my camera yesterday! :-(
    1.Camera won't close
    2. Reports system error S0042
    I'm looking around the internet for any advice...
    Ken
  • stephenmurph Jul 21, 2008
    After dropping my Revio 410Z it is jammed open and displays the message "S0042".
Okay, the same happened to my camera. The lens stayed open and showed system error on a blue screen when I tried to close it. I checked if this had happened to others and found that it had, and took note of their comments.
I tried first of all pushing the lens back in whilst trying to close the door: seems to work for some but not for me.
I then tried pulling the lens out even further in case it hadn't come out all the way in the first place: didn't work either.
I tried slapping it on the palm of my hand three times quite hard and trying again to close the lens door, then repeating this a few times: seems to work for some, but again not for me.
Finally what did work: I rocked the lens back and forth gently a few times which suddenly brought it back to life - it sprang open a fraction, made the 'taadaa' noise to show it was ready and was delightfully back to normal.
Seems the lens had been stuck somehow and needed a bit of gentle persuasion to return to its normal positon. It may be the combination of all the above that finally did the trick, or just the end one. I will never know. I do know that I love this little gizmo and that it has given me five years of brilliant service. There are cheaper and better spec' camers around now, but I wouldn't trade it for any of them, so its really lovely to have it back up and running.
Hope this works for you and anyone else it may happen to.
Les
Posted on Jun 30, 2009
SOURCE:
My camera lens wont close and says system error s0042 konica revio kd-310z
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Nov 08, 2009 | Konica Revio KD-310Z Digital Camera
Error code S0042, DIMAGE G600
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. Let me know if it worked!
Feb 14, 2008 | Konica Minolta DiMAGE G600 Digital Camera
Sustem Error S0042
Todd, What you can do is to powerit on and try to pull the lens out manually. Do not use too much strength or rotate. But try it a few times and the lens casing may stop touching the camera body. Once the lens comes out fully then the camera will boot up and work.
Sep 12, 2009 | Konica Minolta DiMAGE G600 Digital Camera
Camera lens wont open or close after being dropped. it won't turn on and take pictures
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Jul 06, 2009 | Kodak EASYSHARE M1063 Digital Camera
My fujifilm S1000 keeps saying "Zoom Error"
same problem camera was dropped and have zoom error, since the lens and lcd are FINE i dont think it will be that much to fix
Mar 13, 2009 | Fuji FinePix S1000FD Digital Camera
Dropped fe- 230 camera in sand..spazzing out..help ASAP please
Borrow a friends camera or buy another.
The motorized lens assembly is contaminated, and
your only recourse is to replace the entire assembly.
It has very close tolerances and even replacing it is no guarantee that all the sand particles could be cleaned out of the camera body.
Sorry. No easy fix this time.
Regards Paul
May 30, 2008 | Olympus FE-230 Digital Camera
Minolta G500
your lens mechanism is stuck up! try pulling the lens with slight force, if you are lucky the culprit that is blocking the mechanism will get loose. If you are not lucky theres no way you can remove or fix the problem than sending it to the authorized service center. =-(
Aug 24, 2007 | Konica Minolta DiMAGE G500 Digital Camera
I had this problem with my 600. I noticed that the end, center, part of the focusing mechanism was slightly out of alignment. (The part that usually sticks out furthest.) Once I straightened that piece, it was able to retract and the camera could be closed. Look at the focusing mechanism from all sides to make sure it is straight. The part was very slightly off, but enough to cause the error. My camera has been working fine since.
Aug 14, 2007 | Konica Minolta DiMAGE G600 Digital Camera
Lens wont close.
Damage to the lens Mechanism is a repair shop job- or contact Kodak tech support for further advice.
May 13, 2007 | Kodak EasyShare CX7430 Digital Camera
Lens is stuck
Hello Gruntny, in order to repair this Camera you will have to replace the OPTICS UNIT (ED13A). Please contact your nearest Sony Service. Best regards, Arpad
Dec 21, 2006 | Sony Cyber-shot DSC-W50 Digital Camera
Konica Revio KD-410Z Digital Camera Logo
159 people viewed this question
Top Konica Cameras Experts
myxelpyxel
Level 1 Expert
Ekse
Lawrence Oravetz
Are you a Konica Camera Expert? Answer questions, earn points and help others
